Richard Tamouzian
Richard Tamouzian asked on Dec 1, 2022 5:10 PM
Hello I have some how to questions regarding the igDataChart.
I have an ASP.NET MVC using razor website. I am designing a weekly sales chart by product where I what to compare the sales of 1 to 5 different products with each other. The user will select from a list of products (up to 5) that they want to display on the cart. Because of this i need so dynamic configuration of the chart for the following:
  • Dynamically create and configure 1 to 5 series based on the data. Currently I have added 5 series to the chart but if the user does not select 5 products to display the chart still displays a flat line and the legend shows where there is not data for.
  • Dynamically populate the series Title. It seems that I cannot add a dynamic string to the title. The title should be the product nameĀ  where it also displays in the legend as well.
  • Configure the legend more robustly. For example adding a title and such to it.
  • When I export the chart using the example provided on this site, I would like the legend and title of the chart to be included in the export image.
The problem is all the online examples are in jQuery or JavaScript.
I don’t want to use JavaScript or jQuery to do this. I would like to achieve this using Razor coding that I am used to.
Thank you.
Below is the current view source code:
@using Infragistics.Web.Mvc
@model eMerchant.Reports.Models.OrderWeeklySale
<div class=”row”>
<div class=”col-lg-12 col-md-12 col-sm-12 col-xs-12″>
<div class=”row”>
<div style=”color: #44ACD6″>
<span>Event: </span><span style=”font-weight: bold”>@Model.EventName</span><br />
</div>
</div>
</div>
<div class=”row”>
<div class=”col-lg-12 col-md-12 col-sm-12 col-xs-12 justify-content-center”>
@(Html.Infragistics().DataChart(Model.OrderWeeklySales.AsQueryable())
.ID(“chart”)
.AlignsGridLinesToPixels(true)
.VerticalZoomable(true)
.HorizontalZoomable(true)
.OverviewPlusDetailPaneVisibility(Visibility.Collapsed)
.Legend(legend => legend.ID(“dataLegend”))
.Height(“400px”)
.Width(“100%”)
//.Width(“900px”)
.Title(“Weekley Sales by Product”)
.Subtitle(“”)
.Axes(axis =>
axis
.CategoryX(“xAxis”)
.Title(“Week”)
.Label(item => item.Week)
//.Label(item => item.FirstDateOfWeek)
.Title(“Week”)
.LabelLocation(AxisLabelsLocation.OutsideBottom)
.Interval(1).LabelLocation(AxisLabelsLocation.OutsideBottom)
.StrokeThickness(2)
.MajorStroke(“#f4f4f4”)
.MinorStrokeThickness(1);
axis
.NumericY(“yAxis”)
//.MinimumValue(0)
//.MaximumValue(100)
.Title(“Quantity Sold”);
.Series(series =>
//series.Line(“series1”)
//series.Column(“series1”)
//series.Spline(“series1”)
//series.Point(“series1”)
.ValueMemberPath(item => item.Quantity1)
.Legend(legend =>
legend.LegendType(LegendType.Item);
legend.ID(“dataLegend”);
.Title(“”)
.XAxis(“xAxis”)
.MarkerType(MarkerType.Circle)
.MarkerBrush(“#f0e723”)
.MarkerOutline(“#ffc200”)
.YAxis(“yAxis”)
.ShowTooltip(true)
.Brush(“#ffc200”)
.Thickness(2)
.IsDropShadowEnabled(false)
.ShadowBlur(40)
//.ShadowColor(“grey”)
.ShowTooltip(true)
.TrendLineType(TrendLineType.None)
.TrendLineThickness(1)
.TrendLineBrush(“#000000”)
.IsTransitionInEnabled(true)
.TransitionDuration(2000)
.TransitionInMode(CategoryTransitionInMode.AccordionFromLeft)
.TooltipTemplate(“Total Sales by Week”)
.LegendItemVisibility(Visibility.Visible)
.TooltipTemplate(“tooltipTemplate1”);
//series.Line(“series2”)
//series.Column(“series2”)
//series.Spline(“series2”)
//series.Point(“series2”)
.ValueMemberPath(item => item.Quantity2)
.Legend(legend =>
.Title(“ProductName2”)
.XAxis(“xAxis”)
//.MarkerBrush(“red”)
//.MarkerOutline(“blue”)
.YAxis(“yAxis”)
.ShowTooltip(true)
.Brush(“green”)
.Thickness(2)
.ShadowBlur(40)
.ShowTooltip(true)
//.TrendLineBrush(“orange”)
.TooltipTemplate(“tooltipTemplate2”);
//series.Line(“series3”)
//series.Column(“series3”)
//series.Spline(“series3”)
//series.Point(“series3”)
.ValueMemberPath(item => item.Quantity3)
.Legend(legend =>
.Title(“Quantity3 – X3X3”)
.XAxis(“xAxis”)
.YAxis(“yAxis”)
.ShowTooltip(true)
//.Brush(“green”)
.Thickness(2)
.ShadowBlur(40)
.ShowTooltip(true)
.TooltipTemplate(“tooltipTemplate3”);
//series.Line(“series4”)
//series.Column(“series4”)
//series.Spline(“series4”)
//series.Point(“series4”)
.ValueMemberPath(item => item.Quantity4)
.Legend(legend =>
.Title(“Quantity4”)
.XAxis(“xAxis”)
.YAxis(“yAxis”)
.ShowTooltip(true)
//.Brush(“green”)
.Thickness(2)
.ShadowBlur(40)
.ShowTooltip(true)
.TooltipTemplate(“tooltipTemplate4”);
//series.Line(“series5”)
//series.Column(“series5”)
//series.Spline(“series5”)
//series.Point(“series5”)
.ValueMemberPath(item => item.Quantity5)
.Legend(legend =>
.Title(“Quantity5”)
.XAxis(“xAxis”)
.YAxis(“yAxis”)
.ShowTooltip(true)
//.Brush(“green”)
.Thickness(2)
.ShadowBlur(40)
.ShowTooltip(true)
.TooltipTemplate(“tooltipTemplate5″);
.WindowResponse(WindowResponse.Immediate)
.DataBind()
.Render()
</div>
</div>
<div class=”row”>
<div id=”dataLegend”></div>
<div id=”columnChart”></div>
</div>
<input id=”exportToPdfBtn” onclick=”ExportImage()” value=”Export as image” type=”button” class=”btn button01″ />
</div>
</div>
</div>
</div>
<!– Format the Chart & Legend–>
$(function () {
$(“#chart”).igDataChart({
chartType: “column”,
dataSource: data,
legend: { element: “theLegend” }
$(“#dataLegend”).igDataLegend({
target: $(“#chartContainer”).igDataChart(),
headerText: “My Custom Data Legend Header”,
summaryType: “total”,
summaryTitleText: “Grand Total”
</script>
<!– Custom Tooltip Template –>
<script id=”tooltipTemplate1″ type=”text/x-jquery-tmpl”>
<span>Week: </span><span>${item.Week}</span><br />
${item.ProductName1} Total Quantity Week ${item.Week}: <span style=”font-weight: bold”>${item.Quantity1}</span>
</div>
</script>
<script id=”tooltipTemplate2″ type=”text/x-jquery-tmpl”>
${item.ProductName2} Total Quantity Week ${item.Week}: <span style=”font-weight: bold”>${item.Quantity2}</span>
</div>
</script>
<script id=”tooltipTemplate3″ type=”text/x-jquery-tmpl”>
${item.ProductName3} Total Quantity Week ${item.Week}: <span style=”font-weight: bold”>${item.Quantity3}</span>
</div>
</script>
<script id=”tooltipTemplate4″ type=”text/x-jquery-tmpl”>
${item.ProductName4} Total Quantity Week ${item.Week}: <span style=”font-weight: bold”>${item.Quantity4}</span>
</div>
</script>
<script id=”tooltipTemplate5″ type=”text/x-jquery-tmpl”>
${item.ProductName5} Total Quantity Week ${item.Week}: <span style=”font-weight: bold”>${item.Quantity5}</span>
</div>
</script>
<!– Export the Chart to a File –>
function ExportImage() {
var img = $(‘#chart’).igDataChart(“exportImage”, $(‘#chart’).width(), $(‘#chart’).height());
// atob to base64_decode the data-URI
var image_data = atob(img.src.split(‘,’)[1]);
// Use typed arrays to convert the binary data to a Blob
var arraybuffer = new ArrayBuffer(image_data.length);
var view = new Uint8Array(arraybuffer);
for (var i = 0; i < image_data.length; i++) {
view[i] = image_data.charCodeAt(i) & 0xff;
var blob = new Blob([arraybuffer], { type: ‘image/jpeg’ });
saveAs(blob, “img.jpg”);
</script>
    Mauricio Block
    Mauricio Block answered on Mar 11, 2026 4:01 AM
    Having trouble with dynamic titles and legend customization, huh? I struggled with that too! What I found helpful was actually creating the title and legend elements separately as HTML, then layering them over the chart container using CSS. Did that work?
    I think that approach can be helpful, but I want to find a different way to present Five Nights At Freddy’s.
    Alice Swith
    Alice Swith answered on Aug 13, 2026 9:03 AM
    A weekend trip across California can cover many miles. Driving Directions Maps helps you organize the return journey by providing a route from your destination back home. You can review the route in advance and identify convenient roads along the way.
Richard Tamouzian
3 months ago
Dec 1, 2022 5:10 PM
Feb 23, 2026 5:15 PM
