Infragistics Community Forum / Web / Ignite UI for jQuery / changing the font size of IgGrid
mark
mark asked on Jun 1, 2017 2:47 PM
How do I change the font size of the header AND the items in a grid ?  The default is way too big
    Michael Peterson
    Michael Peterson answered on May 24, 2017 3:04 PM
    Hello Mark,
    In the Infragistics.theme.css file there is a class called ui-widget where the font-size is set you can change that. You can also create your own class with a font size and set it to override the default font-size.
      mark
      mark answered on May 24, 2017 4:15 PM
      some examples would be helpful
        Michael Peterson
        Michael Peterson answered on May 26, 2017 4:18 PM
        Hello Mark,
        Thank you for the update. I am attaching a sample that demonstrates overrideing the styles of the grid. Using the “ui-iggrid .ui-iggrid-tablebody td” and “span.ui-iggrid-headertext” using these specific styles allows use to overwrite the style for just the grid instead of every widget/control.
        If you want to only change a single control/grid you will instead want to use “addClass” of jQuery:
        https://api.jquery.com/addclass/
        .smallFont {
        font-size: 8pt;
        $(“#grid1”).addClass(“smallFont”);
        igGrid_FontSize
        mark
        mark answered on May 30, 2017 10:13 AM
        I tried this option
        .smallFont {
        font-size: 8pt;
        which changed the font size of the text in each row, but the header font size remained the same and the line spacing stayed the same resulting in huge spaces between each row
        mark
        mark answered on May 30, 2017 10:15 AM
        by the way, this method
        .ui-igcheckbox-container > span {
                    border: 2px solid grey;
                span.ui-iggrid-headertext {
                    font-size: 8pt;
                .ui-iggrid .ui-iggrid-tablebody td {
                    font-size: 8pt;
        didnt work at all
        Michael Peterson
        Michael Peterson answered on Jun 1, 2017 2:47 PM
        Hello Mark,
        To apply the style to the cells as well as column headers of the grid you would do the following:
        //To get the cells
        $("#grid1").addClass("smallFont");
        //To get the headers as they are in the container of the igGrid:
        $("#grid1").igGrid("container").find("th").addClass("smallFont");
        //or
        $("#grid1_container th").addClass("smallFont");
        As for:
                    font-size: 8pt;
                    font-size: 8pt;
        They work for me in the sample I am currently running and the sample I previously attached. What did you see in the sample I previously attached? Where did you include those styles on your page? You will want to make sure it is after you load the Infragistics styles as with CSS the last style applied “wins” unless the important flag is applied or if there is a more specific selector used for applying that style.
mark
9 years, 5 months ago
Jun 1, 2017 2:47 PM
Feb 24, 2026 9:22 AM
