Infragistics Community Forum / Web / Ignite UI for jQuery / Getting Error: Parameter Count Mismatch
Pardeep
Pardeep asked on Jun 3, 2013 8:03 AM
I am binding grid in Razor View with an IQuerable data source of type “DataRow”. I am getting the below specified error.
The Controller Code is :
<HttpPost()>
Function SearchResults(criteria As Infinity.ContactMgmt.Objects.ContactSearchCriteria) As ActionResult
Dim contactsearchResults = Infinity.ContactMgmt.Objects.ContactSearch.Fetch(criteria)
ViewData(“SearchResults”) = contactsearchResults.ContactSearchResults.AsQueryable
Return View()
End Function
View is:
@(Html.Infragistics().Grid(Of Infinity.ContactMgmt.Objects.ContactSearchData.ContactSearchResultsRow)(Model) _
.ID(“grid1”) _
.AutoGenerateColumns(False) _
.Columns(Function(columns)
columns.For(Function(c) c.ContactId).HeaderText(“User Id”).DataType(“Int”)
columns.For(Function(c) c.FileAsName).HeaderText(“Name”).DataType(“String”)
End Function) _
.Width(“100%”) _
.Height(“350”) _
.DataBind() _
.Render())
There are more than 20 columns in Model but we only want to display two columns.
Parameter count mismatch.
Exception Details: System.Reflection.TargetParameterCountException: Parameter count mismatch.
Source Error:
Line 5:          <legend>Contact Search Results</legend>
Line 6:          <p>
Line 7: @(Html.Infragistics().Grid(Of Infinity.ContactMgmt.Objects.ContactSearchData.ContactSearchResultsRow)(Model) _ Line 8:          .ID("grid1") _
Line 9:          .AutoGenerateColumns(False) _
Source File: D:\Test\MvcApplication1\MvcApplication1\Views\ContactSearch\ViewUserControlContactSearchResults.vbhtml Line: 7
Stack Trace:
[TargetParameterCountException: Parameter count mismatch.]
   System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks) +10280741
   System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture) +21
   System.Reflection.RuntimePropertyInfo.GetValue(Object obj, BindingFlags invokeAttr, Binder binder, Object[] index, CultureInfo culture) +61
   System.Reflection.RuntimePropertyInfo.GetValue(Object obj, Object[] index) +19
   Infragistics.Web.Mvc.GridModel.RenderHierarchicalQueryableRecursive(IQueryable queryable, WrappedGridResponse response, GridModel baseLayout) +556
   Infragistics.Web.Mvc.GridModel.RenderHierarchicalQueryableRecursive(IQueryable queryable, WrappedGridResponse response, GridModel baseLayout) +2060
   Infragistics.Web.Mvc.GridModel.RenderHierarchicalQueryable(IQueryable queryable) +359
   Infragistics.Web.Mvc.GridModel.DataBind() +355
   Infragistics.Web.Mvc.Grid`1.DataBind() +47
   ASP._Page_Views_ContactSearch_ViewUserControlContactSearchResults_vbhtml.Execute() in D:\Test\MvcApplication1\MvcApplication1\Views\ContactSearch\ViewUserControlContactSearchResults.vbhtml:7
   System.Web.WebPages.WebPageBase.ExecutePageHierarchy() +197
   System.Web.Mvc.WebViewPage.ExecutePageHierarchy() +81
   System.Web.WebPages.WebPageBase.ExecutePageHierarchy(WebPageContext pageContext, TextWriter writer, WebPageRenderingBase startPage) +88
   System.Web.Mvc.RazorView.RenderView(ViewContext viewContext, TextWriter writer, Object instance) +222
   System.Web.Mvc.BuildManagerCompiledView.Render(ViewContext viewContext, TextWriter writer) +115
   System.Web.Mvc.HtmlHelper.RenderPartialInternal(String partialViewName, ViewDataDictionary viewData, Object model, TextWriter writer, ViewEngineCollection viewEngineCollection) +276
   System.Web.Mvc.Html.PartialExtensions.Partial(HtmlHelper htmlHelper, String partialViewName, Object model, ViewDataDictionary viewData) +108
   System.Web.Mvc.Html.PartialExtensions.Partial(HtmlHelper htmlHelper, String partialViewName, Object model) +32
   ASP._Page_Views_ContactSearch_SearchResults_vbhtml.Execute() in D:\Test\MvcApplication1\MvcApplication1\Views\ContactSearch\SearchResults.vbhtml:11
   System.Web.WebPages.StartPage.RunPage() +17
   System.Web.WebPages.StartPage.ExecutePageHierarchy() +62
   System.Web.WebPages.WebPageBase.ExecutePageHierarchy(WebPageContext pageContext, TextWriter writer, WebPageRenderingBase startPage) +76
   System.Web.Mvc.ViewResultBase.ExecuteResult(ControllerContext context) +295
   System.Web.Mvc.ControllerActionInvoker.InvokeActionResult(ControllerContext controllerContext, ActionResult actionResult) +13
   System.Web.Mvc.<>c__DisplayClass1c.<InvokeActionResultWithFilters>b__19() +23
   System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilter(IResultFilter filter, ResultExecutingContext preContext, Func`1 continuation) +242
   System.Web.Mvc.<>c__DisplayClass1e.<InvokeActionResultWithFilters>b__1b() +21
   System.Web.Mvc.ControllerActionInvoker.InvokeActionResultWithFilters(ControllerContext controllerContext, IList`1 filters, ActionResult actionResult) +177
   System.Web.Mvc.ControllerActionInvoker.InvokeAction(ControllerContext controllerContext, String actionName) +324
   System.Web.Mvc.Controller.ExecuteCore() +106
   System.Web.Mvc.ControllerBase.Execute(RequestContext requestContext) +91
   System.Web.Mvc.ControllerBase.System.Web.Mvc.IController.Execute(RequestContext requestContext) +10
   System.Web.Mvc.<>c__DisplayClassb.<BeginProcessRequest>b__5() +34
   System.Web.Mvc.Async.<>c__DisplayClass1.<MakeVoidDelegate>b__0() +19
   System.Web.Mvc.Async.<>c__DisplayClass8`1.<BeginSynchronous>b__7(IAsyncResult _) +10
   System.Web.Mvc.Async.WrappedAsyncResult`1.End() +62
   System.Web.Mvc.<>c__DisplayClasse.<EndProcessRequest>b__d() +48
   System.Web.Mvc.SecurityUtil.<GetCallInAppTrustThunk>b__0(Action f) +7
   System.Web.Mvc.SecurityUtil.ProcessInApplicationTrust(Action action) +22
   System.Web.Mvc.MvcHandler.EndProcessRequest(IAsyncResult asyncResult) +60
   System.Web.Mvc.MvcHandler.System.Web.IHttpAsyncHandler.EndProcessRequest(IAsyncResult result) +9
   System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +9478661
   System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +178
Version Information: Microsoft .NET Framework Version:4.0.30319; ASP.NET Version:4.0.30319.17379
    [Infragistics] Borislav Traykov answered on Aug 13, 2012 7:46 AM
    I haven't seen this error before so I'm afraid that I would have to ask you to provide us with a simple MVC sample project where the problem is reproducible.
    Feel free to set up just one or two rows of dummy data – me and the other forum members will need to inspect the way the grid is configured in the sample (sorry – the grid's code alone is insufficient in this case).
    Cheers,
    Borislav
      Jason
      Jason answered on Jun 1, 2013 7:38 PM
      I'm experiencing this same issue, but only on one client's machine.  Works fine on my dev machine and other client machines with the same code and same IIS setup (As far as I can tell).  Would be very interested in any fixes or other information available.
        [Infragistics] Borislav Traykov answered on Jun 2, 2013 8:25 PM
        Hey there Jason,
        I'm afraid that unless you or the original poster provide some more details or a sample where the problem can be reproduced, we can't provide you with any further assistance.
        The best (and wild) guess I could wager is that the igGrid's MVC constructor is receiving more than one parameter for some reason when it should expect only one – the IQueryabl that it's data-bound to.
        If you are able to provide such a sample, please post it here or in a new support request so we can take a closer look at the problem and then – provide you with a slick solution :).
        Thanks in advance!
        Jason
        Jason answered on Jun 3, 2013 1:47 AM
        I could provide a sample, but it isn't any different from other examples that work (other than the underlying data, which has many dependencies so I can't easily provide that).  Also, the same exact code works on some systems.
        The only parameter being passed is the IQueryable.
        I guess I was hoping this had been seen and addressed elsewhere, so some direction to hunt in would be available.  Apparently it is rare enough that that isn't the case.  Thanks.
        Martin Pavlov
        Martin Pavlov answered on Jun 3, 2013 8:03 AM
        Hello Pardeep,
        The error appears in generation of the hierarchical column layouts of the grid model. I see that you didn't explicitly configured column layouts, so probably you don't want hierarchical grid. Try to add the following code to your grid configuration in order to disable automatic column layout generation:
        .AutoGenerateLayouts(False) _
        Also in the controller you're saving the data in the ViewData, but in the View you use the Model variable to pass the data to the grid. You should change your controller code code to pass the data to the view.
        Here is an example code:
        <HttpPost()>
        Return View(contactsearchResults.ContactSearchResults.AsQueryable)
        End Function
        Hope this helps,
        Martin Pavlov
Pardeep
13 years, 4 months ago
Jun 3, 2013 8:03 AM
Feb 11, 2026 3:18 PM
