Infragistics Community Forum / Design to Code / Indigo.Design / Ignite Angular Trial & Samples error entryComponents[]
B-IT
B-IT asked on May 16, 2024 12:05 PM
Just downloaded the Ignite trial and extracted the samples. Not any sample is working on 2 machines, one installed from scatch with the latest Angular & Node versions.The error is always the same, please find below. Any help would be highly appreciated.
./src/styles.scss – Error: Module build failed (from ./node_modules/sass-loader/dist/cjs.js):
SassError: Can't find stylesheet to import.
1 │ @use 'igniteui-theming/sass/color/functions' as *;
  node_modules\igniteui-angular\lib\core\styles\base\_mixins.scss 1:1  @forward
  node_modules\igniteui-angular\lib\core\styles\base\_index.scss 2:1   @use
  node_modules\igniteui-angular\lib\core\styles\themes\_core.scss 6:1  @forward
  igniteui-angular\_index.scss 1:1                                     @use
  src\styles.scss 1:1                                                  root stylesheet
./src/styles.scss?ngGlobalStyle – Error: Module build failed (from ./node_modules/mini-css-extract-plugin/dist/loader.js):
HookWebpackError: Module build failed (from ./node_modules/sass-loader/dist/cjs.js):
Error: src/app/app.module.ts:26:3 – error TS2345: Argument of type '{ bootstrap: (typeof AppComponent)[]; declarations: (typeof AppComponent)[]; imports: (typeof CommonModule | typeof BrowserModule)[]; providers: undefined[]; entryComponents: undefined[]; schemas: undefined[]; }' is not assignable to parameter of type 'NgModule'.
  Object literal may only specify known properties, and 'entryComponents' does not exist in type 'NgModule'.
26   entryComponents: [],
× Failed to compile.
    Bozhidara Pachilova
    Bozhidara Pachilova answered on Jul 13, 2023 6:12 AM
    Could you please clarify which samples are you trying to run and how did you download and isntall Ignite UI for Angular? If you are referring to the bundle available on the Customer Portal named “Ignite UI for Angular 2023 Vol. 1 Complete Bundle”, I have tested running these samples on my side by using the following commands:
    In the "Infragistics_Angular_v23-1\igniteui-angular-examples-LOB” directory:
    npm install –force
    npm run start:live-editing
    While loading takes some time, on my side I am able to successfully run the samples and no errors are raised. Consequently, I am wondering what are the steps you have followed, if my assumption about the repo you are trying to run is correct.
    Apart from that, can I ask if you have checked out our “Getting started with Ignite UI for Angular” topic and if you have followed the steps from there?
    Also my suggestion is to check out our documentation, where for each component there are live demos, which can be opened and viewed directly in the browser, as well as forked and edited in StackBlitz. This might be a more straightforward way of quickly referring to our components features.
    If you require any further assistance on the matter, we will be glad to assist you.
    Bozhidara Pachilova
B-IT
3 years, 4 months ago
Feb 18, 2026 5:04 PM
