Infragistics Community Forum / General / Silent Install Infragistics Ultimate 2014.2 Without GUI
BALAJI SV
BALAJI SV asked on Jan 22, 2015 4:13 PM
When I try to install it silently with this command, installation is not triggering but it shows the below log. Kindly let me know the alternate way to install it silently (without GUI).
>Infragistics_Ultimate_20142.exe /qn /key <key> /thirdparty /nodownload /nofeedback
08:54:10: Log file initialized at: 1/20/2015 8:54:10 AM
08:54:10: Version number of the executable is: 14.2.20142.126
08:54:11: Local installer C:\Users\bs47060\Desktop\Ultimate\Setups\Infragistics_ASPNET_20142.msi was found.
08:54:11: Local installer C:\Users\bs47060\Desktop\Ultimate\Setups\Infragistics_ASPNET_20142_Samples.msi was found.
08:54:11: Local installer C:\Users\bs47060\Desktop\Ultimate\Setups\Infragistics_ASPNET_20142_Help.msi was found.
08:54:11: Local installer C:\Users\bs47060\Desktop\Ultimate\Setups\IgniteUI_20142.msi was found.
08:54:11: Local installer C:\Users\bs47060\Desktop\Ultimate\Setups\IgniteUI_20142_Help.msi was found.
08:54:11: Local installer C:\Users\bs47060\Desktop\Ultimate\Setups\IgniteUI_20142_Samples.msi was found.
08:54:11: Local installer C:\Users\bs47060\Desktop\Ultimate\Setups\IndigoStudio.msi was found.
08:54:11: Local installer C:\Users\bs47060\Desktop\Ultimate\Setups\Infragistics_Reporting_20142.msi was found.
08:54:11: Local installer C:\Users\bs47060\Desktop\Ultimate\Setups\Infragistics_Reporting_20142_Samples.msi was found.
08:54:11: Local installer C:\Users\bs47060\Desktop\Ultimate\Setups\Infragistics_Reporting_20142_Help.msi was found.
08:54:11: Local installer C:\Users\bs47060\Desktop\Ultimate\Setups\Infragistics_Silverlight_20142.msi was found.
08:54:11: Local installer C:\Users\bs47060\Desktop\Ultimate\Setups\Infragistics_Silverlight_20142_Samples.msi was found.
08:54:11: Local installer C:\Users\bs47060\Desktop\Ultimate\Setups\Infragistics_Silverlight_20142_Help.msi was found.
08:54:11: Local installer C:\Users\bs47060\Desktop\Ultimate\Setups\Infragistics_WinForms_20142.msi was found.
08:54:11: Local installer C:\Users\bs47060\Desktop\Ultimate\Setups\Infragistics_WinForms_20142_Samples.msi was found.
08:54:11: Local installer C:\Users\bs47060\Desktop\Ultimate\Setups\Infragistics_WinForms_20142_Help.msi was found.
08:54:11: Local installer C:\Users\bs47060\Desktop\Ultimate\Setups\Infragistics_WindowsUI_20142_XAML.msi was found.
08:54:11: Local installer C:\Users\bs47060\Desktop\Ultimate\Setups\Infragistics_WindowsUI_20142_XAML_Help.msi was found.
08:54:11: Local installer C:\Users\bs47060\Desktop\Ultimate\Setups\Infragistics_WPF_20142.msi was found.
08:54:11: Local installer C:\Users\bs47060\Desktop\Ultimate\Setups\Infragistics_WPF_20142_Samples.msi was found.
08:54:11: Local installer C:\Users\bs47060\Desktop\Ultimate\Setups\Infragistics_WPF_20142_Help.msi was found.
08:54:11: Local installer C:\Users\bs47060\Desktop\Ultimate\Setups\Infragistics_VersionUtility_20142.msi was found.
08:54:11: Local installer C:\Users\bs47060\Desktop\Ultimate\Setups\Infragistics_VSExtension_20142.msi was found.
08:54:11: Local installer C:\Users\bs47060\Desktop\Ultimate\Setups\Infragistics_WindowsPhone_20142.msi was found.
08:54:11: Local installer C:\Users\bs47060\Desktop\Ultimate\Setups\Infragistics_WindowsPhone_20142_Samples.msi was found.
08:54:11: Local installer C:\Users\bs47060\Desktop\Ultimate\Setups\Infragistics_WindowsPhone_20142_Help.msi was found.
08:54:11: Validating key 922153006628586131
08:54:11: serialnum matches expression:
08:54:11: Acceptable prefix found. Will validate the key
08:54:11: ASP.NET is queued for execution
08:54:11: ASP.NET Help is queued for execution
08:54:11: ASP.NET Samples is queued for execution
08:54:11: Ignite UI is queued for execution
08:54:11: Ignite UI Help is queued for execution
08:54:11: Ignite UI Samples is queued for execution
08:54:11: Indigo Studio is queued for execution
08:54:11: Reporting is queued for execution
08:54:11: Reporting Help is queued for execution
08:54:11: Reporting Samples is queued for execution
08:54:11: Silverlight is queued for execution
08:54:11: Silverlight Help is queued for execution
08:54:11: Silverlight Samples is queued for execution
08:54:11: Windows Forms is queued for execution
08:54:11: Windows Forms Help is queued for execution
08:54:11: Windows Forms Samples is queued for execution
08:54:11: Windows Phone is queued for execution
08:54:11: Windows Phone Help is queued for execution
08:54:11: Windows Phone Samples is queued for execution
08:54:11: Windows UI – XAML is queued for execution
08:54:11: Windows UI – XAML Help is queued for execution
08:54:11: WPF is queued for execution
08:54:11: WPF Help is queued for execution
08:54:11: WPF Samples is queued for execution
08:54:11: Version Utility is queued for execution
08:54:11: Visual Studio Extension is queued for execution
08:54:11: Visual Studio Template Gallery is queued for execution
08:54:11: Unknown error (0x80005000)
08:54:11: at System.DirectoryServices.DirectoryEntry.Bind(Boolean throwIfFail)
at System.DirectoryServices.DirectoryEntry.Bind()
at System.DirectoryServices.DirectoryEntry.get_IsContainer()
at System.DirectoryServices.DirectoryEntries.ChildEnumerator..ctor(DirectoryEntry container)
at Infragistics.Wrapper.Interface.InfoObjects.Prerequisites.IISDefaultWebSitePrerequisite.Evaluate()
08:54:11: The following requirements must be met prior to executing the installer.
1) The installation of “ASP.NET Help” requires the MS Help Local store to be configured. For Visual Studio 2010, this can be configured by using the Help Settings Manager at Start\All Programs\Microsoft Visual Studio 2010\Visual Studio Tools\Manage Help Settings. For Visual Studio 2012 or later, this can be configured through the Microsoft Help Viewer application by setting a local store path in the “Manage Content” screen.
2) The installation of “ASP.NET Help” requires the installation path to the Help Library Manager used to install the help is set.
3) The installation of “Reporting Help” requires the MS Help Local store to be configured. For Visual Studio 2010, this can be configured by using the Help Settings Manager at Start\All Programs\Microsoft Visual Studio 2010\Visual Studio Tools\Manage Help Settings. For Visual Studio 2012 or later, this can be configured through the Microsoft Help Viewer application by setting a local store path in the “Manage Content” screen.
4) The installation of “Reporting Help” requires the installation path to the Help Library Manager used to install the help is set.
5) The installation of “Silverlight” requires that the Silverlight 5.0 SDK be installed.
6) The installation of “Silverlight Help” requires the MS Help Local store to be configured. For Visual Studio 2010, this can be configured by using the Help Settings Manager at Start\All Programs\Microsoft Visual Studio 2010\Visual Studio Tools\Manage Help Settings. For Visual Studio 2012 or later, this can be configured through the Microsoft Help Viewer application by setting a local store path in the “Manage Content” screen.
7) The installation of “Silverlight Help” requires the installation path to the Help Library Manager used to install the help is set.
8) The installation of “Windows Forms Help” requires the MS Help Local store to be configured. For Visual Studio 2010, this can be configured by using the Help Settings Manager at Start\All Programs\Microsoft Visual Studio 2010\Visual Studio Tools\Manage Help Settings. For Visual Studio 2012 or later, this can be configured through the Microsoft Help Viewer application by setting a local store path in the “Manage Content” screen.
9) The installation of “Windows Forms Help” requires the installation path to the Help Library Manager used to install the help is set.
10) The installation of “Windows Phone” requires that the Windows Phone 8.0 SDK be installed.
11) The installation of “Windows Phone Help” requires the MS Help Local store to be configured. For Visual Studio 2010, this can be configured by using the Help Settings Manager at Start\All Programs\Microsoft Visual Studio 2010\Visual Studio Tools\Manage Help Settings. For Visual Studio 2012 or later, this can be configured through the Microsoft Help Viewer application by setting a local store path in the “Manage Content” screen.
12) The installation of “Windows Phone Help” requires the installation path to the Help Library Manager used to install the help is set.
13) The installation of “Windows Phone Samples” requires that the Windows Phone 8.0 SDK be installed.
14) The installation of “Windows UI – XAML Help” requires the MS Help Content store to be configured. Please configure it using Start\All Programs\Microsoft Visual Studio 2012\Microsoft Help Viewer to configure it.
15) The installation of “Windows UI – XAML Help” requires the installation path to the Help Library Manager 2.0 used to install the help is set.
16) The installation of “WPF Help” requires the MS Help Local store to be configured. For Visual Studio 2010, this can be configured by using the Help Settings Manager at Start\All Programs\Microsoft Visual Studio 2010\Visual Studio Tools\Manage Help Settings. For Visual Studio 2012 or later, this can be configured through the Microsoft Help Viewer application by setting a local store path in the “Manage Content” screen.
17) The installation of “WPF Help” requires the installation path to the Help Library Manager used to install the help is set.
18) The installation of “Visual Studio Template Gallery” requires that at least one of the following versions of Visual Studio is installed: Visual Studio 2012, Visual Studio 2013.
08:54:11: The following requirements must be met prior to install optional features. These features will not be installed.
1) The feature “IIS Components” in the installation of “ASP.NET” requires that IIS is installed.
2) The feature “IIS Components” in the installation of “ASP.NET” requires that an appropriate IIS website is found. The default website searched for is “Default Web Site”. IIS may not be installed.
3) The feature “Help Viewer 1.1 (Visual Studio 2010)” in the installation of “ASP.NET Help” requires the MS Help Local store to be configured. For Visual Studio 2010, this can be configured by using the Help Settings Manager at Start\All Programs\Microsoft Visual Studio 2010\Visual Studio Tools\Manage Help Settings. For Visual Studio 2012 or later, this can be configured through the Microsoft Help Viewer application by setting a local store path in the “Manage Content” screen.
4) The feature “Help Viewer 1.1 (Visual Studio 2010)” in the installation of “ASP.NET Help” requires the installation path to the Help Library Manager 1.1 used to install the help is set.
5) The feature “Help Viewer 2.0 (Visual Studio 2012)” in the installation of “ASP.NET Help” requires the MS Help Content store to be configured. Please configure it using Start\All Programs\Microsoft Visual Studio 2012\Microsoft Help Viewer to configure it.
6) The feature “Help Viewer 2.0 (Visual Studio 2012)” in the installation of “ASP.NET Help” requires the installation path to the Help Library Manager 2.0 used to install the help is set.
7) The feature “Help Viewer 2.1 (Visual Studio 2013)” in the installation of “ASP.NET Help” requires the MS Help Content store to be configured. Please configure it using Start\All Programs\Microsoft Visual Studio 2013\Microsoft Help Viewer to configure it.
8) The feature “Help Viewer 2.1 (Visual Studio 2013)” in the installation of “ASP.NET Help” requires the installation path to the Help Library Manager 2.1 used to install the help is set.
9) The feature “Visual Studio 2010 Plugin” in the installation of “Reporting” requires that Microsoft® Visual Studio .NET 2010 is installed on this machine.
10) The feature “Visual Studio 2012 Plugin” in the installation of “Reporting” requires that Microsoft® Visual Studio .NET 2012 is installed on this machine.
11) The feature “Visual Studio 2013 Plugin” in the installation of “Reporting” requires that Microsoft® Visual Studio .NET 2013 is installed on this machine.
12) The feature “Microsoft Help Viewer Help” in the installation of “Reporting Help” requires the MS Help Local store to be configured. For Visual Studio 2010, this can be configured by using the Help Settings Manager at Start\All Programs\Microsoft Visual Studio 2010\Visual Studio Tools\Manage Help Settings. For Visual Studio 2012 or later, this can be configured through the Microsoft Help Viewer application by setting a local store path in the “Manage Content” screen.
13) The feature “Microsoft Help Viewer Help” in the installation of “Reporting Help” requires the installation path to the Help Library Manager used to install the help is set.
14) The feature “Help Viewer 1.1 (Visual Studio 2010)” in the installation of “Reporting Help” requires the MS Help Local store to be configured. For Visual Studio 2010, this can be configured by using the Help Settings Manager at Start\All Programs\Microsoft Visual Studio 2010\Visual Studio Tools\Manage Help Settings. For Visual Studio 2012 or later, this can be configured through the Microsoft Help Viewer application by setting a local store path in the “Manage Content” screen.
15) The feature “Help Viewer 1.1 (Visual Studio 2010)” in the installation of “Reporting Help” requires the installation path to the Help Library Manager 1.1 used to install the help is set.
16) The feature “Help Viewer 2.0 (Visual Studio 2012)” in the installation of “Reporting Help” requires the MS Help Content store to be configured. Please configure it using Start\All Programs\Microsoft Visual Studio 2012\Microsoft Help Viewer to configure it.
17) The feature “Help Viewer 2.0 (Visual Studio 2012)” in the installation of “Reporting Help” requires the installation path to the Help Library Manager 2.0 used to install the help is set.
18) The feature “Help Viewer 2.1 (Visual Studio 2013)” in the installation of “Reporting Help” requires the MS Help Content store to be configured. Please configure it using Start\All Programs\Microsoft Visual Studio 2013\Microsoft Help Viewer to configure it.
19) The feature “Help Viewer 2.1 (Visual Studio 2013)” in the installation of “Reporting Help” requires the installation path to the Help Library Manager 2.1 used to install the help is set.
20) The feature “Help Viewer 1.1 (Visual Studio 2010)” in the installation of “Silverlight Help” requires the MS Help Local store to be configured. For Visual Studio 2010, this can be configured by using the Help Settings Manager at Start\All Programs\Microsoft Visual Studio 2010\Visual Studio Tools\Manage Help Settings. For Visual Studio 2012 or later, this can be configured through the Microsoft Help Viewer application by setting a local store path in the “Manage Content” screen.
21) The feature “Help Viewer 1.1 (Visual Studio 2010)” in the installation of “Silverlight Help” requires the installation path to the Help Library Manager 1.1 used to install the help is set.
22) The feature “Help Viewer 1.1 (Visual Studio 2010)” in the installation of “Silverlight Help” requires The help requires MSHV 1.1, which is installed with Microsoft Visual Studio .NET 2010 Service Pack 1. Please make sure you have Service Pack 1 installed for Microsoft Visual Studio .NET 2010 before proceeding.
23) The feature “Help Viewer 2.0 (Visual Studio 2012)” in the installation of “Silverlight Help” requires the MS Help Content store to be configured. Please configure it using Start\All Programs\Microsoft Visual Studio 2012\Microsoft Help Viewer to configure it.
24) The feature “Help Viewer 2.0 (Visual Studio 2012)” in the installation of “Silverlight Help” requires the installation path to the Help Library Manager 2.0 used to install the help is set.
25) The feature “Help Viewer 2.1 (Visual Studio 2013)” in the installation of “Silverlight Help” requires the MS Help Content store to be configured. Please configure it using Start\All Programs\Microsoft Visual Studio 2013\Microsoft Help Viewer to configure it.
26) The feature “Help Viewer 2.1 (Visual Studio 2013)” in the installation of “Silverlight Help” requires the installation path to the Help Library Manager 2.1 used to install the help is set.
27) The feature “Help Viewer 1.1 (Visual Studio 2010)” in the installation of “Windows Forms Help” requires the MS Help Local store to be configured. For Visual Studio 2010, this can be configured by using the Help Settings Manager at Start\All Programs\Microsoft Visual Studio 2010\Visual Studio Tools\Manage Help Settings. For Visual Studio 2012 or later, this can be configured through the Microsoft Help Viewer application by setting a local store path in the “Manage Content” screen.
28) The feature “Help Viewer 1.1 (Visual Studio 2010)” in the installation of “Windows Forms Help” requires the installation path to the Help Library Manager 1.1 used to install the help is set.
29) The feature “Help Viewer 2.0 (Visual Studio 2012)” in the installation of “Windows Forms Help” requires the MS Help Content store to be configured. Please configure it using Start\All Programs\Microsoft Visual Studio 2012\Microsoft Help Viewer to configure it.
30) The feature “Help Viewer 2.0 (Visual Studio 2012)” in the installation of “Windows Forms Help” requires the installation path to the Help Library Manager 2.0 used to install the help is set.
31) The feature “Help Viewer 2.1 (Visual Studio 2013)” in the installation of “Windows Forms Help” requires the MS Help Content store to be configured. Please configure it using Start\All Programs\Microsoft Visual Studio 2013\Microsoft Help Viewer to configure it.
32) The feature “Help Viewer 2.1 (Visual Studio 2013)” in the installation of “Windows Forms Help” requires the installation path to the Help Library Manager 2.1 used to install the help is set.
33) The feature “Help Viewer 2.0 (Visual Studio 2012)” in the installation of “Windows UI – XAML Help” requires the MS Help Content store to be configured. Please configure it using Start\All Programs\Microsoft Visual Studio 2012\Microsoft Help Viewer to configure it.
34) The feature “Help Viewer 2.0 (Visual Studio 2012)” in the installation of “Windows UI – XAML Help” requires the installation path to the Help Library Manager 2.0 used to install the help is set.
35) The feature “Help Viewer 2.1 (Visual Studio 2013)” in the installation of “Windows UI – XAML Help” requires the MS Help Content store to be configured. Please configure it using Start\All Programs\Microsoft Visual Studio 2013\Microsoft Help Viewer to configure it.
36) The feature “Help Viewer 2.1 (Visual Studio 2013)” in the installation of “Windows UI – XAML Help” requires the installation path to the Help Library Manager 2.1 used to install the help is set.
37) The feature “Help Viewer 1.1 (Visual Studio 2010)” in the installation of “WPF Help” requires the MS Help Local store to be configured. For Visual Studio 2010, this can be configured by using the Help Settings Manager at Start\All Programs\Microsoft Visual Studio 2010\Visual Studio Tools\Manage Help Settings. For Visual Studio 2012 or later, this can be configured through the Microsoft Help Viewer application by setting a local store path in the “Manage Content” screen.
38) The feature “Help Viewer 1.1 (Visual Studio 2010)” in the installation of “WPF Help” requires the installation path to the Help Library Manager 1.1 used to install the help is set.
39) The feature “Help Viewer 1.1 (Visual Studio 2010)” in the installation of “WPF Help” requires The help requires MSHV 1.1, which is installed with Microsoft Visual Studio .NET 2010 Service Pack 1. Please make sure you have Service Pack 1 installed for Microsoft Visual Studio .NET 2010 before proceeding.
40) The feature “Help Viewer 2.0 (Visual Studio 2012)” in the installation of “WPF Help” requires the MS Help Content store to be configured. Please configure it using Start\All Programs\Microsoft Visual Studio 2012\Microsoft Help Viewer to configure it.
41) The feature “Help Viewer 2.0 (Visual Studio 2012)” in the installation of “WPF Help” requires the installation path to the Help Library Manager 2.0 used to install the help is set.
42) The feature “Help Viewer 2.1 (Visual Studio 2013)” in the installation of “WPF Help” requires the MS Help Content store to be configured. Please configure it using Start\All Programs\Microsoft Visual Studio 2013\Microsoft Help Viewer to configure it.
43) The feature “Help Viewer 2.1 (Visual Studio 2013)” in the installation of “WPF Help” requires the installation path to the Help Library Manager 2.1 used to install the help is set.
44) The feature “Visual Studio 2010 Add-in” in the installation of “Version Utility” requires that Microsoft® Visual Studio .NET 2010 is installed on this machine.
45) The feature “Visual Studio 2012 Add-in” in the installation of “Version Utility” requires that Microsoft® Visual Studio .NET 2012 is installed on this machine.
46) The feature “Visual Studio 2013 Add-in” in the installation of “Version Utility” requires that Microsoft® Visual Studio .NET 2013 is installed on this machine.
47) The feature “Visual Studio 2010 Extension” in the installation of “Visual Studio Extension” requires that Microsoft® Visual Studio .NET 2010 is installed on this machine.
48) The feature “Visual Studio 2012 Extension” in the installation of “Visual Studio Extension” requires that Microsoft® Visual Studio .NET 2012 is installed on this machine.
49) The feature “Visual Studio 2013 Extension” in the installation of “Visual Studio Extension” requires that Microsoft® Visual Studio .NET 2013 is installed on this machine.
08:54:11: The request failed with HTTP status 407: Proxy Authentication Required.
08:54:11: at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall)
at System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters)
at Infragistics.Wrapper.Interface.FeedbackService.FeedbackService.StoreFeedbackData(String feedBackType, String keyName, String data)
at Infragistics.Wrapper.Interface.Program.Main(String[] args)
08:54:11: Infragistics_Ultimate_20142.exe has completed.
08:54:12: Log file complete.
    Mike Bowshewicz
    Mike Bowshewicz answered on Jan 22, 2015 4:13 PM
    Hi Balaji,
    According to the log, the installer was unable to find a compatible version of Visual Studio. Which version of Visual Studio do you have installed on your machine? If you have installed Visual Studio 2010, 2012, or 2013, you will need to run the IDE at least once in order for Visual Studio to create the appropriate directories.
    Please let me know which version of Visual Studio you are using.
BALAJI SV
11 years, 8 months ago
Feb 24, 2026 7:28 AM
