Infragistics Community Forum / Web / Ignite UI for jQuery / How to remove the border of a chart?
Zach
Zach asked on Mar 20, 2014 11:51 AM
Is there any way to remove the border of a chart?
Zach_Shine
    Graham Murray
    Graham Murray answered on Sep 7, 2012 11:00 PM
    Zach, do you mean the internal axis strokes, or the border around the chart container?
      Thomas
      Thomas answered on May 28, 2013 6:38 PM
      He likely means the ugly black border that you insist on drawing around a chart. Same problem here – and the documentation quality does not really help.
      Ever chart is in a nice (or: ugly) black border – which I also want to remove. Nice how there was no answer on that. So, how does one do that?
        Graham Murray
        Graham Murray answered on May 29, 2013 9:25 PM
        There are three css classes that are applied to the chart's container by default. These are:
        ui-corner-all
        ui-widget-content
        ui-chart-container
        The first two are well known classes provided by jQuery UI themeroller. If you were to apply a themeroller theme rather than the infragistics theme, then the components would look different depending on how those well known classes were defined for that theme. The ugly border, as you put it, comes from ui-corner-all. The easiest way to disable it is to override that border color in css:
        .ui-chart-container
        border: transparent;
        Here is an example:
        http://jsfiddle.net/gmurray/SxBKq/
        It is changing the border to be transparent in the ui-chart-container class, which is applied to the chart with higher priority than the themeroller classes.
        Hope this helps!
        -Graham
        gruppo-formula-spa
        gruppo-formula-spa answered on Mar 20, 2014 11:51 AM
        Hi Graham,
        I'm having a look at igPieChart and I also wish to remove the border around the chart and its legend.
        A brief explanation of my CSS architecture: my page uses bootstrap, as it is inside an ASP.NET MVC 4.5.1 project. I used themeroller to download Redmond theme and I added the dowloaded files to themes folder. Then, since charts are not covered by jQuery UI, I added an additional css that merges chart style settings from the two IG files: 'structure\modules\infragistics.ui.chart.css' and 'themes\infragistics\infragistics.theme.css'.
        These are CSS files that I reference from my page:
        <link href="@Url.Content("~/Content/themes/redmond/jquery-ui-1.10.4.custom.css")" rel="stylesheet" type="text/css" />
        <link href="@Url.Content("~/Content/themes/common/infragistics.ui.chart.css")" rel="stylesheet" type="text/css" />
        To make the border disappear, I added this setting to 'infragistics.ui.chart.css' file:
        .ui-widget-content {
          border:0px;
        Simply setting '.ui-chart-container' as you suggested didn't work.
        Am I doing something wrong with CSS files or around?
        Thank you, bye. Maria
Zach
12 years, 7 months ago
Feb 16, 2026 9:42 PM
