Infragistics Community Forum / Web / Ignite UI for jQuery / is there any way to apply display sort icons in javascript?
Annasaheb
Annasaheb asked on Dec 5, 2012 6:47 AM
I am not using remote sorting, Using local sorting & columnSorted event, I would like to retrieve custom sorted data and assign to the grid, I am able to achieve most of the requirements except to show correct icon next to column title (down arrow or uparrow), is there any way to achieve this?
    [Infragistics] Nikolay
    [Infragistics] Nikolay answered on Dec 3, 2012 11:55 AM
    Hi annasaheb,
    The sorting indicator icons are placed inside of a span in the grid headers. You could apply the following css classes to this span: .ui-icon and  .ui-icon-arrowthick-1-s (for down arrow) or .ui-icon-arrowthick-1-n (for up arrow). Here you can find a sample of igGrid local sorting – https://www.igniteui.com/grid/sorting-local.
    Hope this helps.
      Annasaheb
      Annasaheb answered on Dec 4, 2012 11:05 PM
      Thanks, I had to write a code to get the table header and assign class to correct span. here is a code, may be useful for other coders.
      // set sortField & sortOrderDesc  before calling this routine.
      $("#dataGrid").data("igGrid").headersTable().find("thead tr th").each(function() {
          if (this.id.indexOf(sortField) != -1) {
              var sortClass = (sortOrderDesc) ? "ui-iggrid-colindicator-desc ui-icon ui-icon-arrowthick-1-s" : "ui-iggrid-colindicator-asc ui-icon ui-icon-arrowthick-1-n"
              $(this).find(".ui-iggrid-colindicator").addClass(sortClass);
      }).end();
        [Infragistics] Nikolay answered on Dec 5, 2012 6:47 AM
        Hi annasaheb,
        Thank you for sharing your code with the community.
        Let me know if you have further questions.
Annasaheb
13 years, 11 months ago
Dec 5, 2012 6:47 AM
Feb 19, 2026 3:23 PM
