Infragistics Community Forum / Cross Platform / Ultimate UI for Xamarin / How can I align to right the column grid?
Antonio
Antonio asked on Jan 30, 2008 7:00 PM
Example of display data
TEXT         TOTAL
text?1    585
text?1    1.185
text?1    2
It should be:
TEXT         TOTAL
text?1      585
text?1    1.185
text?1        2
styleClass property don´t apply en thesource code
<td class=”igGridColumn”>1.148</td>
Example of code
<ig:gridView id=”grid_processesList”
dataSource=”#{ProcessesListBean.processesList}”
binding=”#{ProcessesListBean.processesListGridView}”
pageSize=”#{configurationWeb.processesList_pageSize}”
bottomPagerRendered=”true” topPagerRendered=”false”
dataKeyName=”id”
selectedRowsChangeListener=”#{ProcessesListBean.onSelectedRowsChange}”
resizableColumns=”true”>
<f:facet name=”header”>
<h:outputText value=”tableHeader” />
</f:facet>
<ig:column styleClass=”right”>
<h:outputText value=”TOTAL” />
</f:facet>
<h:outputText value=”#{DATA_ROW.docsTotal }”>
<f:convertNumber type=”number” pattern=”#,##0″
groupingUsed=”true” />
</h:outputText>
</ig:column>
    [Infragistics] Murtaza Abdeali
    [Infragistics] Murtaza Abdeali answered on Jan 21, 2008 8:48 PM
    You can align the contents of the column by changing igGridColumn style within CSS to include "text-align:right;" This style is defined within igf_grid.css. By default the controls use the blue theme.
    Hope this helps.
    Taz.
      Antonio
      Antonio answered on Jan 22, 2008 6:57 AM
       Of course,
      but this solution will change all columns.
      I want the text aligned to left  and the numbers aligned to the right.
        [Infragistics] Murtaza Abdeali answered on Jan 30, 2008 7:00 PM
        Yes, you are correct, the style will be applied to all the columns inside the grid. It appears the column styles are not applied correctly and would recommend you to notify our support team so that we can fix this.
        In the meantime, you can force the alignment via the column component.
        <ig:column >
        <f:facet name=“header”>
        <h:outputText value=“Company Name” />
        </f:facet>
        <h:outputText value=”#{DATA_ROW.name}” style=“text-align:right;width:100px;”/>
        </ig:column>
        Taz.
Antonio
18 years, 10 months ago
Feb 24, 2026 9:25 AM
