set combo box value onload
Karen Michelle Tecson
Karen Michelle Tecson asked on Jan 31, 2020 7:45 AM
Here is my controller:
 IEnumerable<SelectListItem> tableList = filteredResultFinal.Select(i => new SelectListItem
Value = i,
Text = i,
Selected = i.Equals(tableName)
  return View(tableList);
here is my VIEW:
Combo box:
@(Html.Infragistics().Combo()
.Width(“270px”)
.ID(“combo”)
.DataSource(Model)
.ValueKey(“Value”)
.TextKey(“Text”)
.DataBind()
.Render()
JavaScript:
 $(“#combo”).igCombo({
inputName: “tableName”,
width: “270px”,
filteringType: “local”,
filteringCondition: “contains”,
highlightMatchesMode: “contains”,
valueKey: “value”,
placeHolder: “Select Equipment…”,
dropDownOrientation: “bottom”,
allowCustomValue: false,
loadOnDemandSettings: {
enabled: true,
pageSize: 10
initialSelectedItems:[{ value: $(“#myViewData”).val()}]
    Mihoko Kamiishi
    Mihoko Kamiishi answered on Jan 24, 2020 1:02 AM
    initialSelectedItems option can be set only when igCombo is initialized.
    It looks like your combo is already initialized using razor syntax.
    I suggest you select the item using value method instead in this case.
    https://igniteui.com/help/api/2019.2/ui.igcombo#methods:value
    I have created a sample that selects a combo item on load using the above method for your reference.
    Please let me know if I may be of further assistance.
      Karen Michelle Tecson answered on Jan 31, 2020 7:45 AM
      Thank You. I figure it out hahah… I kept on using select attrib when I should be using value instead.
6 years, 10 months ago
Feb 24, 2026 1:26 PM
