Infragistics Community Forum / Web / Ignite UI for ASP.NET Core / Insert check all/Uncheck all checkbox in template column header at Runtime
Groove
Groove asked on Nov 19, 2009 4:23 PM
I have created a column at runtime that I need to be able to modify and add a checkbox in the header. This checkbox should enable the user to select all / unselect all items in the ultrawebgrid. If anyone knows please tell me how I can add this checkbox to the header at runtime and make this happen. I tried doing
Dim CheckAll As New CheckBox
column.HeaderItem.TemplateControl.Controls.Add(CheckAll)
but this did not work. I have to create this at Runtime since the column is also created in Runtime, all examples I found so far show how to do this in design. Any help is greatly appreciated
    Matthew Kraft
    Matthew Kraft answered on May 15, 2008 8:43 PM
    Alright so to do this we need to add the checkbox to the header template before the column is even created… so before I assigned the datasource property of the grid I needed to setup the template column. <In the snippet you added I am guessing you did that in the InitializeLayout event handler or after you've set the DataSource and called DataBind and that is too late to hook items into the HeaderTemplate, do it in the Page's OnInit instead.>
    So here's the code to do that column setup:
    C#
        protected
    override void OnInit(EventArgs e)
            base.OnInit(e);
            // Create a templated column
            TemplatedColumn col = new TemplatedColumn(true);
            this.UltraWebGrid1.DisplayLayout.Bands[0].Columns.Add(col);
            col.Key = "CheckBoxCol";
            col.Header.Caption = "";
            GridHeaderTemplate tempHeader = new GridHeaderTemplate();
            // Set the header template.
            col.HeaderTemplate = tempHeader;
            this.UltraWebGrid1.DataSource = LoadGrid();
            this.UltraWebGrid1.DataBind();
    VB.NET
    Protected Overrides Sub OnInit(ByVal e As EventArgs)
        MyBase.OnInit(e)
        ' Create a templated column
        Dim col As New TemplatedColumn(True)
        Me.UltraWebGrid1.DisplayLayout.Bands(0).Columns.Add(col)
        Dim tempHeader As New GridHeaderTemplate()
        ' Set the header template.
        Me.UltraWebGrid1.DataSource = LoadGrid()
        Me.UltraWebGrid1.DataBind()
    End Sub
    So now what does my GridHeaderTemplate look like:
    C#
    public
    class GridHeaderTemplate : ITemplate
            // Cast the container to a HeaderItem
            HeaderItem headerItem = (HeaderItem)container;
            CheckBox checkBox = new CheckBox();
            CheckBox cb = new CheckBox();
            cb.ID = "headerCB";
            cb.Attributes.Add("onclick", "HeaderCheckedChanged();");
            headerItem.Controls.Add(cb);
    VB.NET
    Public Class GridHeaderTemplate
        Implements ITemplate
        Public Sub InstantiateIn(ByVal container As Control)
            ' Cast the container to a HeaderItem
            Dim headerItem As HeaderItem = DirectCast(container, HeaderItem)
            Dim checkBox As New CheckBox()
            Dim cb As New CheckBox()
            cb.ID = "headerCB"
        End Sub
    End Class
     Next I setup the Cell Template dynamically in the WebGrid's InitializeLayout event handler:
    C#
    TemplatedColumn
    col = (TemplatedColumn)(e.Layout.Bands[0].Columns.FromKey("CheckBoxCol"));
    PlaceHolderTemplate tempCell = new PlaceHolderTemplate();
    // Set the cell template.
    col.CellTemplate = tempCell;
    // make the checkbox the last column of band 0.
    col.Move(e.Layout.Bands[0].Columns.Count – 1);
    this.ClientScript.RegisterClientScriptBlock(this.GetType(), "CheckBoxKey", "<script type='text/javascript'>var headerCheckBoxID = '" + col.HeaderItem.FindControl("headerCB").ClientID + "';</script>");
    this.ClientScript.RegisterClientScriptBlock(this.GetType(), "GridKey", "var gridID = '" + this.UltraWebGrid1.ClientID + "';", true);
    VB.NET
    Dim col As TemplatedColumn = DirectCast((e.Layout.Bands(0).Columns.FromKey("CheckBoxCol")), TemplatedColumn)
    Dim tempCell As New PlaceHolderTemplate()
    ' Set the cell template.
    ' make the checkbox the last column of band 0.
    col.Move(e.Layout.Bands(0).Columns.Count – 1)
    Me.ClientScript.RegisterClientScriptBlock(Me.[GetType](), "CheckBoxKey", "<script type='text/javascript'>var headerCheckBoxID = '" + col.HeaderItem.FindControl("headerCB").ClientID + "';</script>")
    Me.ClientScript.RegisterClientScriptBlock(Me.[GetType](), "GridKey", "var gridID = '" + Me.UltraWebGrid1.ClientID + "';", True)
    The PlaceHolderTemplate used for the Cell Template should be awfully familiar now that we've seen the header…
    C#
    public
    class PlaceHolderTemplate : ITemplate
            // Cast the container to a CellItem
            CellItem cellitem = (CellItem)container;
            cb.ID = "cellCB";
            cellitem.Controls.Add(cb);
    VB.NET
    Public Class PlaceHolderTemplate
            ' Cast the container to a CellItem
            Dim cellitem As CellItem = DirectCast(container, CellItem)
            cb.ID = "cellCB"
        End Sub
    End Class
    Now I told the Header Checkbox to call a javascript function when its onclick fires… so here's the js I used to toggle the checkbox:
    script type="text/javascript">
        function HeaderCheckedChanged(){
            var headerCheckBox = document.getElementById(headerCheckBoxID);
            var grid = igtbl_getGridById(gridID);
            for (i = 0; i < grid.Rows.length; i++)
                grid.Rows.getRow(i).getCellFromKey("CheckBoxCol").getElement().children[0].checked = headerCheckBox.checked;
    </script>
    The javascript function can be written in several ways and accomplish the same task this is merely one way to accomplish this task.
    Also as you can see in the code behind I registered a script block to render the grid's id to the client for use in my HeaderCheckedChanged function and I also threw the Header CheckBox's Id out to the client as well.  You can use a stringbuilder and do this part a little neater but I think the point of what I've done to solve the task presented has been displayed in these code snippets.
    What have others done in the past to solve this task?
     EDIT: Updated code snippets to handle OnInit instead of Page_Load as page load was again too late in the Page's Lifecycle.
      Amol
      Amol answered on May 16, 2008 10:20 AM
      hi,
        what I have done is added a CheckBox in template column header and called javascript function to check/uncheck all the checkboxes in the cell template this works fine, but I cant access checkboxes inside grid added in celltemplate. here is HTML and C# code which I am using.
      <Bands><igtbl:UltraGridBand>
      AddNewRow Visible="NotSet" View="NotSet"></AddNewRow>
      Columns>
      <igtbl:TemplatedColumn Key="selectall" >
      <Header Caption="Select" >
      <RowLayoutColumnInfo OriginX="1" />
      </Header>
      <HeaderTemplate>
      <asp:CheckBox ID="cbSelectAll" runat="server" onclick="BLOCKED SCRIPTcheckall()" />
      <asp:Label ID="lbl_select" runat="server" Text="Select"></asp:Label>
      </HeaderTemplate><CellTemplate>
      <asp:CheckBox ID="CheckBox1" runat="server" Value="False" />
      </CellTemplate>
      <CellStyle HorizontalAlign="Center" ></CellStyle>
      <HeaderStyle HorizontalAlign="Center" />
      <Footer>
      </Footer>
      </igtbl:TemplatedColumn>
      <igtbl:UltraGridColumn BaseColumnName="Name" Key="Name" IsBound="True" >
      <Header Caption="Name" ></Header>
      </igtbl:UltraGridColumn>
      Columns>
      <RowTemplateStyle BackColor="Window" BorderColor="Window" BorderStyle="Ridge">
      <BorderDetails WidthBottom="3px" WidthLeft="3px" WidthRight="3px" WidthTop="3px" />
      </RowTemplateStyle>
      <RowEditTemplate>
      <br />
      </RowEditTemplate>
      igtbl:UltraGridBand></Bands>
      and following is the scriptfunction checkall()
      var frm = document.forms[0];for (i=0;i<frm.elements.length;i++)
      if (frm.elementsIdea.name.lastIndexOf("CheckBox1")!= -1)
      frm.elementsIdea.checked = document.getElementById(
      "UltraWebGrid1_ctl01_cbSelectAll").checked;//document.getElementById(id).checked;
       and following is the code for checking which text boxes are checked or uncheked.for (int i = 0; i < UltraWebGrid1.Rows.Count; i++)
      Response.Write(UltraWebGrid1.RowsIdea.Cells[0].Value);
      this code returns me always blank value though i have tick some of the checkboxes.
       Plz help me.
      Thanks.
        Matthew Kraft
        Matthew Kraft answered on May 16, 2008 9:51 PM
        A few things first:
        Try to avoid hard coding any ids in your script
        [quote user="amol123"]
        [/quote]
        instead render out the clientID to a global javascript variable for the page like I did here:
        [quote user="mkraft"]
        [/quote]
        so anywhere in the javascript I can reference the grid and the HeaderCheckBox.  I've also seen others render an array of the id's of the checkboxes in the cells to the client in the same manner so they can just call document.getElementById(x) where "x" is the id from the array.
        On the client I showed how to do access the checkbox in my HeaderCheckedChange function which looked like this:
        </script>
        [/quote]
        On the Server if you want access the CheckBox in the CellTemplate it would look like this:
        //create a variable for the templated column in the WebGrid
        TemplatedColumn  templatedColumn = (TemplatedColumn) this.UltraWebGrid1.Columns.FromKey("TemplatedColumn");
        //get a cellitem reference in the cellitems collection
        CellItem cellItem = (CellItem) templatedColumn.CellItems[myRowIndex];
        //find the control
        Control cs = cellItem.FindControl("CheckBox1");
        //cast the control into the correct type
        CheckBox myCheckBox = (CheckBox) cs;
        Now you have a reference to the CheckBox control that is in the cell… interrogate the value of the checked property or set it as you see fit.
        Adrian
        Adrian answered on Jun 4, 2008 12:31 PM
        Hi Matthew
        Thank you very  much for this article! It's one of the better articles i have ever read about how to solve something special with UltraWebGrid!
        Hope to read more such articles from you Matthew, for example how to synchronize values from Controls in TempaltedColumns with the underlying DataSource as this doesn't work automatically (by my actual understanding of the things about TemplatedColumns).
        Adrian
      Saravanan
      Saravanan answered on Feb 17, 2009 5:47 PM
      Hi Mathew,
          I tried using the code given by you. When I bind the grid for the second time, the checkbox in the Header column disappears. Any suggestion??  Appreciate your help.
      Saran
      Saravanan
      Saravanan answered on Feb 17, 2009 6:14 PM
      Mathew
      When binding the second time.. one thing which I noticed is "InstantiateIn" of GridHeaderTemplate doesn't fire, because of which the checkbox is not getting added. Another thing is the reference to "col.HeaderItem.FindControl("headerCB").ClientID" is not available which again because the HeaderCB didn't get added. Any help?
      Saran
        [Infragistics] Rumen Stankov
        [Infragistics] Rumen Stankov answered on Feb 18, 2009 7:59 AM
        Hello Saran,
        Can you move the code that dynamically sets up the templated column from Page_Load to OnInit and see if this works better for you ?
        Matthew Kraft
        Matthew Kraft answered on Feb 18, 2009 2:17 PM
        Excellent point, I should have done that in the first place.  The setup needs to be completed in the OnInit as Page_Load happens too late in the page lifecycle.  I've updated the code to reflect this change.
        Seth
        Seth answered on Nov 19, 2009 4:23 PM
        I'm using more or less the same code to create a checkbox in the CellItem instead of the Header.  It works fine the first time it renders, but on post back the checkbox is no longer accessible when I iterate through the rows of the grid, and disappears when the page renders after the post back.
        I put the code for inserting the checkbox in the OnInit event of the page, but it appears to behave the same as it did in OnLoad.
        Is the checkbox not getting stored in the ViewState for the UltraWebGrid?   If so, do I need to do something to ensure that it's state is maintained between post backs?
        Saravanan
        Saravanan answered on Feb 18, 2009 3:33 PM
        Hi Rumen
        I moved the code that dynamically sets up the templated column to OnInit. I am still having the same problem. Following is the code I have written.
        Imports System.Data
        Imports Infragistics.WebUI.UltraWebGrid
        Imports Infragistics.WebUI.UltraWebNavigator
        Partial Class View_Edit_Surcharge
            Inherits System.Web.UI.Page
                MyBase.OnInit(e)
                If (Not IsPostBack()) Then
                    AddGridColumns()
                End If
            End Sub
                    LoadData()
                End If
            End Sub
            Protected Sub LoadData()
                PopulateCustomerGridView()
            End Sub
            Protected Sub AddGridColumns()
                col.Key = "Select"
            End Sub
            Private Sub PopulateFilteredCustomerGridView(ByVal custName As String, ByVal type As String, ByVal grade As String)
                Dim surchargeCustDs As DataSet = CType(Session.Item("surchargeCustDs"), DataSet)
                Dim filteredDT As DataTable = CType(Session.Item("filteredDT"), DataTable)
                Dim whereClause As String = ""
                Dim custNameClause As String = "1=1"
                Dim typeClause As String = "1=1"
                Dim gradeClause As String = "1=1"
                Try
                    If (custName <> "") Then
                        custNameClause = "CUSTOMER_NAME='" + custName + "'"
                    End If
                    If (type <> "") Then
                        typeClause = "charge_code='" + type + "'"
                    End If
                    If (grade <> "") Then
                        gradeClause = "AISIXXCODE='" + grade + "'"
                    End If
                    whereClause = custNameClause + " And " + typeClause + " And " + gradeClause
                    filteredDT = surchargeCustDs.Tables(0).Clone
                    For Each tmpRow As DataRow In surchargeCustDs.Tables(0).Select(whereClause)
                        filteredDT.ImportRow(tmpRow)
                    Next
                    Session.Item("isBinding") = True
                    UltraWebGrid1.DataSource = filteredDT
                    Session.Item("isBinding") = False
                    Session.Item("filteredDT") = filteredDT
                Catch ex As Exception
                End Try
            End Sub
            Private Sub PopulateCustomerGridView()
                Dim isRefreshed As Boolean = CType(Session.Item("isRefreshed"), Boolean)
                Try
                    If (surchargeCustDs Is Nothing Or isRefreshed) Then
                        surchargeCustDs = DataAccess.GetCustomerSurchargeDetails()
                        Session.Item("surchargeCustDs") = surchargeCustDs
                        Session.Item("isRefreshed") = False
                    End If
                    For Each tmpRow As DataRow In surchargeCustDs.Tables(0).Rows
                    Next
                End Try
            End Sub
            Protected Sub UltraWebTree1_NodeSelectionChanged(ByVal sender As Object, ByVal e As Infragistics.WebUI.UltraWebNavigator.WebTreeNodeEventArgs) Handles UltraWebTree1.NodeSelectionChanged
                Dim uTNode As Node
                Dim uTSelLevel As Integer
                Try
                    'hasToBeFocused = False
                    uTNode = e.Node
                    uTNode.Expand(False)
                    uTSelLevel = uTNode.Level
                    Select Case uTSelLevel
                        Case 0
                        Case 1
                            PopulateFilteredCustomerGridView(uTNode.Text, "", "")
                        Case 2
                            PopulateFilteredCustomerGridView(uTNode.Parent.Text, uTNode.Text, "")
                        Case 3
                            PopulateFilteredCustomerGridView(uTNode.Parent.Parent.Text, uTNode.Parent.Text, uTNode.Text)
                    End Select
                End Try
            End Sub
            Protected Sub UltraWebGrid1_InitializeLayout(ByVal sender As Object, ByVal e As Infragistics.WebUI.UltraWebGrid.LayoutEventArgs) Handles UltraWebGrid1.InitializeLayout
                Dim col As TemplatedColumn = DirectCast((e.Layout.Bands(0).Columns.FromKey("Select")), TemplatedColumn)
                e.Layout.Bands(0).Columns.FromKey("CHARGE_TYPE").Hidden = True
                e.Layout.Bands(0).Columns.FromKey("CUST_ID").Hidden = True
                e.Layout.Bands(0).Columns.FromKey("SURCHARGE_ID").Hidden = True
                e.Layout.Bands(0).Columns.FromKey("FUT_SURCHARGE_ID").Hidden = True
                e.Layout.Bands(0).Columns.FromKey("CUSTOMER_NUMBER").Header.Caption = "ACCOUNT"
                e.Layout.Bands(0).Columns.FromKey("CUSTOMER_NUMBER").Move(0)
                e.Layout.Bands(0).Columns.FromKey("CUSTOMER_NUMBER").CellStyle.Font.Name = "MS Sans Serif"
                e.Layout.Bands(0).Columns.FromKey("CUSTOMER_NUMBER").CellStyle.Font.Size = FontSize.Medium
                e.Layout.Bands(0).Columns.FromKey("CUSTOMER_NAME").Header.Caption = "NAME"
                e.Layout.Bands(0).Columns.FromKey("CUSTOMER_NAME").Move(1)
                e.Layout.Bands(0).Columns.FromKey("CUSTOMER_NAME").CellStyle.Font.Name = "MS Sans Serif"
                e.Layout.Bands(0).Columns.FromKey("CUSTOMER_NAME").CellStyle.Font.Size = FontSize.Medium
                e.Layout.Bands(0).Columns.FromKey("CHARGE_CODE").Header.Caption = "Charge"
                e.Layout.Bands(0).Columns.FromKey("CHARGE_CODE").Move(2)
                e.Layout.Bands(0).Columns.FromKey("CHARGE_CODE").CellStyle.Font.Name = "MS Sans Serif"
                e.Layout.Bands(0).Columns.FromKey("CHARGE_CODE").CellStyle.Font.Size = FontSize.Medium
                e.Layout.Bands(0).Columns.FromKey("AISIXXCODE").Header.Caption = "AISIXX"
                e.Layout.Bands(0).Columns.FromKey("AISIXXCODE").Move(3)
                e.Layout.Bands(0).Columns.FromKey("AISIXXCODE").CellStyle.Font.Name = "MS Sans Serif"
                e.Layout.Bands(0).Columns.FromKey("AISIXXCODE").CellStyle.Font.Size = FontSize.Medium
                e.Layout.Bands(0).Columns.FromKey("AMT").Header.Caption = "AMT"
                e.Layout.Bands(0).Columns.FromKey("AMT").Move(4)
                e.Layout.Bands(0).Columns.FromKey("AMT").CellStyle.Font.Name = "MS Sans Serif"
                e.Layout.Bands(0).Columns.FromKey("AMT").CellStyle.Font.Size = FontSize.Medium
                e.Layout.Bands(0).Columns.FromKey("AMT").CellStyle.BackColor = Drawing.Color.FromArgb(204, 255, 204)
                e.Layout.Bands(0).Columns.FromKey("UOM").Header.Caption = "UOM"
                e.Layout.Bands(0).Columns.FromKey("UOM").Move(5)
                e.Layout.Bands(0).Columns.FromKey("UOM").CellStyle.Font.Name = "MS Sans Serif"
                e.Layout.Bands(0).Columns.FromKey("UOM").CellStyle.Font.Size = FontSize.Medium
                e.Layout.Bands(0).Columns.FromKey("UOM").CellStyle.BackColor = Drawing.Color.FromArgb(204, 255, 204)
                e.Layout.Bands(0).Columns.FromKey("START_DATE").Header.Caption = "Start"
                e.Layout.Bands(0).Columns.FromKey("START_DATE").Move(6)
                e.Layout.Bands(0).Columns.FromKey("START_DATE").CellStyle.Font.Name = "MS Sans Serif"
                e.Layout.Bands(0).Columns.FromKey("START_DATE").CellStyle.Font.Size = FontSize.Medium
                e.Layout.Bands(0).Columns.FromKey("START_DATE").CellStyle.BackColor = Drawing.Color.FromArgb(204, 255, 204)
                e.Layout.Bands(0).Columns.FromKey("END_DATE").Header.Caption = "End"
                e.Layout.Bands(0).Columns.FromKey("END_DATE").Move(7)
                e.Layout.Bands(0).Columns.FromKey("END_DATE").CellStyle.Font.Name = "MS Sans Serif"
                e.Layout.Bands(0).Columns.FromKey("END_DATE").CellStyle.Font.Size = FontSize.Medium
                e.Layout.Bands(0).Columns.FromKey("END_DATE").CellStyle.BackColor = Drawing.Color.FromArgb(204, 255, 204)
                e.Layout.Bands(0).Columns.FromKey("FUT_AMT").Header.Caption = "AMT"
                e.Layout.Bands(0).Columns.FromKey("FUT_AMT").Move(8)
                e.Layout.Bands(0).Columns.FromKey("FUT_AMT").CellStyle.Font.Name = "MS Sans Serif"
                e.Layout.Bands(0).Columns.FromKey("FUT_AMT").CellStyle.Font.Size = FontSize.Medium
                e.Layout.Bands(0).Columns.FromKey("FUT_AMT").CellStyle.BackColor = Drawing.Color.FromArgb(255, 255, 153)
                e.Layout.Bands(0).Columns.FromKey("FUT_UOM").Header.Caption = "UOM"
                e.Layout.Bands(0).Columns.FromKey("FUT_UOM").Move(9)
                e.Layout.Bands(0).Columns.FromKey("FUT_UOM").CellStyle.Font.Name = "MS Sans Serif"
                e.Layout.Bands(0).Columns.FromKey("FUT_UOM").CellStyle.Font.Size = FontSize.Medium
                e.Layout.Bands(0).Columns.FromKey("FUT_UOM").CellStyle.BackColor = Drawing.Color.FromArgb(255, 255, 153)
                e.Layout.Bands(0).Columns.FromKey("FUT_START_DATE").Header.Caption = "Start"
                e.Layout.Bands(0).Columns.FromKey("FUT_START_DATE").Move(10)
                e.Layout.Bands(0).Columns.FromKey("FUT_START_DATE").CellStyle.Font.Name = "MS Sans Serif"
                e.Layout.Bands(0).Columns.FromKey("FUT_START_DATE").CellStyle.Font.Size = FontSize.Medium
                e.Layout.Bands(0).Columns.FromKey("FUT_START_DATE").CellStyle.BackColor = Drawing.Color.FromArgb(255, 255, 153)
                e.Layout.Bands(0).Columns.FromKey("FUT_END_DATE").Header.Caption = "End"
                e.Layout.Bands(0).Columns.FromKey("FUT_END_DATE").Move(11)
                e.Layout.Bands(0).Columns.FromKey("FUT_END_DATE").CellStyle.Font.Name = "MS Sans Serif"
                e.Layout.Bands(0).Columns.FromKey("FUT_END_DATE").CellStyle.Font.Size = FontSize.Medium
                e.Layout.Bands(0).Columns.FromKey("FUT_END_DATE").CellStyle.BackColor = Drawing.Color.FromArgb(255, 255, 153)
                'e.Layout.Bands(0).Columns.FromKey("Select").Move(12)
                'e.Layout.Bands(0).FilterOptions.FilterRowStyle.BackColor = Drawing.Color.FromArgb(254, 254, 254)
                'The boolean parameter inserts this header into viewstate, so that the grid will maintain
                ' it over a postback if it is not recreated.
                Dim colHead As ColumnHeader
                For i As Integer = 0 To e.Layout.Bands(0).HeaderLayout.Count – 1
                    colHead = e.Layout.Bands(0).HeaderLayout(i)
                    colHead.RowLayoutColumnInfo.OriginY = 1
                Next
                Dim customerGroup As New ColumnHeader(True)
                Dim chargeParametersGroup As New ColumnHeader(True)
                Dim currentPricesGroup As New ColumnHeader(True)
                Dim futurePricesGroup As New ColumnHeader(True)
                Dim restGroup As New ColumnHeader(True)
                customerGroup.Caption = "Customer"
                customerGroup.Style.HorizontalAlign = HorizontalAlign.Center
                customerGroup.RowLayoutColumnInfo.OriginX = 0
                customerGroup.RowLayoutColumnInfo.OriginY = 0
                chargeParametersGroup.Caption = "Charge Parameters"
                chargeParametersGroup.Style.HorizontalAlign = HorizontalAlign.Center
                chargeParametersGroup.RowLayoutColumnInfo.OriginX = 2
                chargeParametersGroup.RowLayoutColumnInfo.OriginY = 0
                currentPricesGroup.Caption = "Current Prices"
                currentPricesGroup.Style.HorizontalAlign = HorizontalAlign.Center
                currentPricesGroup.Style.BackColor = Drawing.Color.FromArgb(204, 255, 204)
                currentPricesGroup.RowLayoutColumnInfo.OriginX = 4
                currentPricesGroup.RowLayoutColumnInfo.OriginY = 0
                futurePricesGroup.Caption = "Future Prices"
                futurePricesGroup.Style.HorizontalAlign = HorizontalAlign.Center
                futurePricesGroup.Style.BackColor = Drawing.Color.FromArgb(255, 255, 153)
                futurePricesGroup.RowLayoutColumnInfo.OriginX = 8
                futurePricesGroup.RowLayoutColumnInfo.OriginY = 0
                restGroup.Caption = " "
                restGroup.RowLayoutColumnInfo.OriginX = 12
                restGroup.RowLayoutColumnInfo.OriginY = 0
                ' Add the newly created Header object to the HeaderLayout object
                e.Layout.Bands(0).HeaderLayout.Add(customerGroup)
                e.Layout.Bands(0).HeaderLayout.Add(chargeParametersGroup)
                e.Layout.Bands(0).HeaderLayout.Add(currentPricesGroup)
                e.Layout.Bands(0).HeaderLayout.Add(futurePricesGroup)
                e.Layout.Bands(0).HeaderLayout.Add(restGroup)
                e.Layout.Bands(0).HeaderStyle.Height = Unit.Point(15)
                e.Layout.Bands(0).HeaderStyle.Font.Name = "MS Sans Serif"
                e.Layout.Bands(0).HeaderStyle.Font.Bold = True
                e.Layout.Bands(0).HeaderStyle.Font.Size = FontSize.Large
                customerGroup.RowLayoutColumnInfo.SpanX = 2
                chargeParametersGroup.RowLayoutColumnInfo.SpanX = 2
                currentPricesGroup.RowLayoutColumnInfo.SpanX = 4
                futurePricesGroup.RowLayoutColumnInfo.SpanX = 4
            End Sub
            Protected Sub UltraWebGrid1_InitializeRow(ByVal sender As Object, ByVal e As Infragistics.WebUI.UltraWebGrid.RowEventArgs) Handles UltraWebGrid1.InitializeRow
                Try
                    Dim isBinding As Boolean = CType(Session.Item("isBinding"), Boolean)
                    If (isBinding) Then
                        'e.Row.Cells("Select").Value = False
                        For Each cl As UltraGridCell In e.Row.Cells
                            If (cl.Column.Header.Caption = "Select") Then
                                cl.AllowEditing = AllowEditing.Yes
                            End If
                            If (Not (cl.Column.Header.Caption = "Select")) Then
                                cl.AllowEditing = AllowEditing.No
                            End If
                        Next
                    End If
                    'showMessage(ex.Message + " ** in function UltraGrid1_InitializeRow", "")
                End Try
            End Sub
        End Class
            Public Sub InstantiateIn(ByVal container As Control) Implements System.Web.UI.ITemplate.InstantiateIn
                cb.ID = "headerCB"
                'cb.Text = "Select"
            End Sub
        End Class
                cb.ID = "cellCB"
            End Sub
        End Class
        Saran
Groove
16 years, 11 months ago
Feb 11, 2026 2:24 PM
