Infragistics Community Forum / Web / Ultimate UI for ASP.NET Web Forms / Procedure or function X has too many arguments specified
Angela Gunderson
Angela Gunderson asked on Apr 26, 2016 11:48 AM
I’m getting an error when trying to insert a parent and/or child record. The error says “Procedure or function usp_ins_Chart_Review_Claim has too many arguments specified.” I’ve checked the stored procedures and they both have the same number of parameters that are in their section.
Here is what the datasource code looks like:
<ig:WebHierarchicalDataSource ID=”WHDS_Claims_and_Diags” runat=”server”>
<DataViews>
<ig:DataView ID=”dsClaims_DefaultView” DataMember=”DefaultView” DataSourceID=”dsClaims” />
<ig:DataView ID=”dsDiags_DefaultView” DataMember=”DefaultView” DataSourceID=”dsDiags” />
DataViews>
<DataRelations>
<ig:DataRelation ChildColumns=”Original_Claim_ID” ChildDataViewID=”dsDiags_DefaultView” ParentColumns=”Original_Claim_ID” ParentDataViewID=”dsClaims_DefaultView” />
DataRelations>
ig:WebHierarchicalDataSource>
<asp:SqlDataSource ID=”dsClaims” runat=”server” ConnectionString=”<%$ ConnectionStrings:cs_CHP_EDPS %>“ InsertCommand=”usp_ins_Chart_Review_Claim” InsertCommandType=”StoredProcedure” OnInserting=”dsClaims_Inserting” SelectCommand=”usp_get_Chart_Review_Claims_in_Prev_Year” SelectCommandType=”StoredProcedure”>
<InsertParameters>
<asp:Parameter Name=”Member_ID” Type=”String” />
<asp:Parameter DbType=”Date” Name=”Start_Date” />
<asp:Parameter DbType=”Date” Name=”End_Date” />
<asp:Parameter Name=”User_Name” Type=”String” />
InsertParameters>
<SelectParameters>
<asp:QueryStringParameter Name=”Member_ID” QueryStringField=”Member_ID” Type=”String” />
<asp:QueryStringParameter Name=”HCC” QueryStringField=”HCC” Type=”Int32″ />
SelectParameters>
asp:SqlDataSource>
<asp:SqlDataSource ID=”dsDiags” runat=”server” ConnectionString=”<%$ ConnectionStrings:cs_CHP_EDPS %>“ DeleteCommand=”usp_del_Chart_Review_Diag” DeleteCommandType=”StoredProcedure” OnDeleting=”dsDiags_Deleting” InsertCommand=”usp_ins_Chart_Review_Diag” InsertCommandType=”StoredProcedure” OnInserting=”dsDiags_Inserting” SelectCommand=”usp_get_Chart_Review_Claim_Diags” SelectCommandType=”StoredProcedure”>
<SelectParameters>
SelectParameters>
<DeleteParameters>
<asp:Parameter Name=”Row_ID” Type=”Int32″ />
DeleteParameters>
<InsertParameters>
<asp:Parameter Name=”Claim_ID” Type=”String” />
<asp:Parameter Name=”Diag” Type=”String” />
InsertParameters>
asp:SqlDataSource>
    Tihomir Iliev
    Tihomir Iliev answered on Apr 20, 2016 12:38 PM
    Hello algunderson,
    Thank you for contacting Infragistics support.
    Everything looks correct. Could you send us a working isolated sample demonstrating the issue so I could further investigate?
    Tihomir Iliev
    Tihomir Iliev answered on Apr 21, 2016 10:02 AM
    Hello Angela,
    Thank you for your sample.
    Could send me a sample database to help me get the project working?
    I also noticed that one of the insert parameters in the usp "usp_ins_Chart_Review_Diag" should be "Original_Claim_ID" but you are passing "Claim_ID" to it.
    Angela Gunderson
    Angela Gunderson answered on Apr 21, 2016 2:51 PM
    Sorry about that. When I was posting the initial question, I was trying to "simplify" the parameters by making the parameter Claim_ID instead of Original_Claim_ID. When I was running it and receiving the error, it was set to Original_Claim_ID. I have corrected it and attached the corrected logic for you. What format should I send the data in? What will work best for you?
    Tihomir Iliev
    Tihomir Iliev answered on Apr 22, 2016 3:17 PM
    Hello Angela,
    Thank you for sending the files.
    I will get back to you once I have a solution or question regarding your issue.
    Please let me know if there is anything else.
    Tihomir Iliev
    Tihomir Iliev answered on Apr 25, 2016 9:36 AM
    Hello Angela,
    Thank you for your patience.
    Do you get the same error once you fix your parameters?
    An .mdf and .ldf files would do fine. This is all I need to get the sample working.
    Angela Gunderson
    Angela Gunderson answered on Apr 25, 2016 9:37 PM
    I apologize. I'm going to have to move to something else and come back to this. I work for a healthcare organization and the data contained in the tables is personal health information, so I am not allowed to send it out. I had started creating a separate database and with only the tables you needed with dummy data in the tables, but before I could finish I was asked to get another project finished first.
    Zdravko Kolev
    Zdravko Kolev answered on Apr 26, 2016 11:48 AM
    We are looking forward for your reply.
Angela Gunderson
10 years, 4 months ago
Feb 26, 2026 7:14 PM
