Infragistics Community Forum / Web / Ignite UI for jQuery / How to type new line into grid cell?
Brash Solutions
Brash Solutions asked on Mar 20, 2014 12:09 PM
Hi
Ignite ui 13.2
I can’t figure out how to type a new line into a grid cell.
eg I am using cell edit mode nad I want to enter this:
Line 1
Line 2
Line 3
Whenever I hit the enter key it ends the edit. Same with ctrl+enter and alt+enter.
Is there a special key combination that I need to use?
I have set up a column formatter to convert new lines into
tags as described here:
http://www.infragistics.com/community/forums/p/80503/406279.aspx#406279
and it is being called for the column in question, I just can’t figure out how to type them into the cell.
Graeme Hart
    [Infragistics] Nikolay
    [Infragistics] Nikolay answered on Mar 20, 2014 9:01 AM
    Hello Graeme,
    I would suggest you to use a text editor provider for the grid columns where you will need line breaks. Set the editor's textMode to multiline: http://help.infragistics.com/jQuery/2013.2/ui.igtexteditor#options
    http://help.infragistics.com/Help/Doc/jQuery/2013.2/CLR4.0/html/igGrid_Updating.html#example_usage_of_columnsettings
    Hope this helps.
      Brash Solutions
      Brash Solutions answered on Mar 20, 2014 11:02 AM
      Hi
      Thanks very much for the pointer. I now have it working.
      For completeness, I am setting up the grid model in my controller so I have the following setting for this column:
      oUpdating.ColumnSettings.Add(new ColumnUpdatingSetting() { ColumnKey = JobViewModel.COL_NOTE_NoteText, EditorType = ColumnEditorType.Text, EditorOptions="textMode:'multiline'" });
      I have to press shift+enter to type a new line into a cell.
      Graeme
        [Infragistics] Nikolay answered on Mar 20, 2014 12:09 PM
        Hi Graeme,
        Thank you for sharing your code with the community.
        If you have any further questions on the matter, please let me know.
Brash Solutions
12 years, 8 months ago
Feb 25, 2026 9:07 AM
