Infragistics Community Forum / Desktop / Ultimate UI for Windows Forms / Add Bands, Groups, or Rows Programmatically in UltraGrid
ARIEL MAISONET
ARIEL MAISONET asked on Dec 28, 2018 7:35 PM
I am trying to add a new definition to the ultragrid control at run time.
I am not using dataset.
I want something like this
But I don’t know how to make it on code.
My code is:
Private Sub ShowOneEmpleado()
ToV = 0 : ToE = 0
SetGridVacUnoSolo()
With UltraGrid1
tbCodigo.Text = lbCodigos.SelectedItem : CodigoEnUso = lbCodigos.SelectedItem
‘mostrar lo pagado de vac y de enf
CalVacacionesUnSolo()
‘calcular cuanto tiene disponible Vac y Enf
CalVacaciones() : If answer = 255 Then answer = 0 : GoTo 90
c1 = Amt : Amt = 0 : If c1 > mi Then c1 = mi
CalEnfermedad() : If answer = 255 Then answer = 0 : GoTo 90
c2 = Amt : Amt = 0 : If c2 > mt Then c2 = mt
‘Totalizar
Dim row As DataRow = dataTable.NewRow()
row(“Fecha Pago”) = “Gran Total”
row(“Número Cheque”) = “”
row(“Horas Vac”) = THV
row(“Pago Vac”) = FormatNumber(ToV, 2)
row(“Horas Enf”) = THE
row(“Pago Enf”) = FormatNumber(ToE, 2)
dataTable.Rows.Add(row)
90:   ‘ bind DataTable to UltraWebGrid
.DisplayLayout.Bands(0).Header.Caption = CodigoEnUso & ”     Vac Disponibles: ” & c1 & ”    Enf Disponibles: ” & c2
UltraGrid1.DataSource = dataTable : UltraGrid1.DataBind() : tbCodigo.Enabled = True : ub5.Visible = True : ub11.Visible = True
100:  ub2.Visible = False : ub3.Visible = True : answer = 0
tbCodigo.Enabled = False : lbCodigos.Visible = False
End With
End Sub
Private Sub SetGridVacUnoSolo()
Dim bnd As UltraGridBand = UltraGrid1.DisplayLayout.Bands(0)
With UltraGrid1.DisplayLayout
With .Bands(0)
.HeaderVisible = True
.Header.Caption = “VACACIONES Y ENFERMEDAD”
.Header.Appearance.BackColor = Color.CornflowerBlue
.Header.Appearance.ForeColor = Color.White
.Override.AllowUpdate = DefaultableBoolean.False
End With
.Override.CellClickAction = CellClickAction.RowSelect
.Override.RowSelectors = DefaultableBoolean.False
.Override.RowAppearance.BackColor = Color.WhiteSmoke
.Override.RowAlternateAppearance.BackColor = Color.FromArgb(254, 228, 209)
.Override.CellAppearance.TextHAlign = HAlign.Right
.Override.CellAppearance.TextVAlign = VAlign.Middle
.Override.SelectedRowAppearance.BackColor = Color.Beige
.Override.SelectedRowAppearance.ForeColor = Color.Black
.Override.DefaultRowHeight = 30
End With
‘formar la tabla
dataTable.Columns.Clear() : dataTable.Rows.Clear()
UltraGrid1.DataSource = dataTable : UltraGrid1.DataBind() : UltraGrid1.Layouts.Clear()
Dim col As New DataColumn
col = New DataColumn(“Fecha Pago”, GetType(String)) : dataTable.Columns.Add(col)
col = New DataColumn(“Número Cheque”, GetType(String)) : dataTable.Columns.Add(col)
col = New DataColumn(“Horas Vac”, GetType(String)) : dataTable.Columns.Add(col)
col = New DataColumn(“Pago Vac”, GetType(String)) : dataTable.Columns.Add(col)
col = New DataColumn(“Horas Enf”, GetType(String)) : dataTable.Columns.Add(col)
col = New DataColumn(“Pago Enf”, GetType(String)) : dataTable.Columns.Add(col)
col = Nothing
UltraGrid1.DisplayLayout.PerformAutoResizeColumns(True, PerformAutoSizeType.AllRowsInBand)
End sub
I want to show an information on top first line then add another band or group or child, whatever with the rest of the data.
Ariel Maisonet
Using 17.1
    Divya Jain
    Divya Jain answered on Dec 26, 2018 7:30 PM
    Hello ,
    Thank you for posting. You can refer these online help documents describing step by steps, how to add row programmatically at runtime.
    https://www.infragistics.com/help/winforms/wingrid-adding-rows-to-wingrid-programmatically
    https://www.infragistics.com/help/winforms/wingrid-adding-new-rows-to-wingrid
    If you need to add more than one row, it is recommended that you add the rows directly to the DataSet for better performance.
    Or for adding single row add a row to a particular band like this :
    Me.UltraGrid1.DisplayLayout.Bands(0).AddNew()
    Me.UltraGrid1.DisplayLayout.Bands(1).AddNew()
    Also for having a hieratical structure of the data , your underline data source should be designed like that.
    Divya Jain
      ARIEL MAISONET
      ARIEL MAISONET answered on Dec 27, 2018 1:35 PM
      Hi
      It is not working. Sorry
      Can you send me a small Project in VB.
      I only need one header with few fields
      One row below filling those fields
      Then another header below
      And few rows filling the data of that header.
      Like:
      Two header
      header:
      Name               | Join Date     | Hours Available
      Ariel Maisonet | 10/20/1954 | 40
      second Header:
      Hours by Month | Amount Paid
      10                           50.00
      Can be done?
        Divya Jain
        Divya Jain answered on Dec 28, 2018 7:35 PM
        Thank you for the update.As per your request, I created a sample of UltraGrid, binding it with flat data and with the hierarchical data source having two bands.
        On load, I bind the grid with flat data source and on button click I changed the data source to hierarchical data. For hierarchical datasource I created two DataTables, setting the Relationship between these tables in a DataSet and binding the Hierarchical result to the WinGrid.
        This sample is based on this online help document, here we provided the code snippet for c# and VB both . I created a sample using c# and attached it here for your reference.
        https://www.infragistics.com/help/winforms/wingrid-binding-to-program-generated-hierarchical-data
        If you do not want to create a datatable and have tables available in the data source/sql server then refer to this online development guide.
        https://www.infragistics.com/help/winforms/wingrid-binding-wingrid-to-a-hierarchical-data-source-clr2
        WinGrid.zip
ARIEL MAISONET
7 years, 11 months ago
Feb 12, 2026 9:01 AM
