Infragistics Community Forum / Desktop / Ultimate UI for Windows Forms / UltraTree 'Parameter not valid' error
Steve Fusaro
Steve Fusaro asked on Sep 4, 2018 2:24 PM
We are currently using an UltraTree in an application. We have a customer (that I believe is always using a remote desktop connection) that randomly experiences a "Parameter not valid" error.
Here is the stack trace:
System.ArgumentException: Parameter is not valid.
   at System.Drawing.Image.get_Width()
   at System.Drawing.Image.get_Size()
   at Infragistics.Win.EditorWithTextUIElement.GetImageSize(Image img, Size& imageSize)
   at Infragistics.Win.EditorWithTextUIElement.PositionChildElements()
   at Infragistics.Win.UIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive)
   at Infragistics.Win.UIElement.VerifyChildElements(Boolean recursive)
   at Infragistics.Win.UIElement.VerifyChildElements()
   at Infragistics.Win.UltraWinTree.UltraTree.SetActiveNode(UltraTreeNode node, Boolean bringIntoView, Boolean adjustHorizontalPosition, NodeActivationReason reason)
   at Infragistics.Win.UltraWinTree.UltraTree.Infragistics.Win.ISelectionManager.ActivateItem(ISelectableItem item)
   at Infragistics.Win.SelectionStrategySingle.OnMouseDown(ISelectableItem item, MouseMessageInfo& msginfo, Boolean forceDrag)
   at Infragistics.Win.SelectionStrategySingle.OnMouseDown(ISelectableItem item, MouseMessageInfo& msginfo)
   at Infragistics.Win.SelectionStrategySingle.OnMouseMessage(ISelectableItem item, MouseMessageInfo& msginfo)
   at Infragistics.Win.ControlUIElementBase.ProcessMouseDownHelper(Object sender, MouseEventArgs e)
   at Infragistics.Win.ControlUIElementBase.ProcessMouseDown(Object sender, MouseEventArgs e)
   at Infragistics.Win.Utilities.ProcessEvent(Control control, ProcessEvent eventToProcess, EventArgs e)
   at Infragistics.Win.UltraWinTree.UltraTree.OnMouseDown(MouseEventArgs e)
   at System.Windows.Forms.Control.WmMouseDown(Message& m, MouseButtons button, Int32 clicks)
To be honest, I haven't gotten a good read on what is actually causing the error, was hoping that something would jump out given the stack trace.
I believe the following is the version of Infragistics being referenced.
11.2.20112.2050
Thanks in advance!
Steve
    Mike Bowshewicz
    Mike Bowshewicz answered on Jan 18, 2017 8:57 PM
    Hi Steve,
    The call stack does look somewhat familiar. It's possible that you are running into an issue that has since been resolved. Are you able to test your application in the latest version of Infragistics? Please try this out and let me know if the issue is resolved in 16.2.
    I am looking for more detailed information about the specific issue. Please let me know if you would like to know more about what I find out.
      Steve Fusaro
      Steve Fusaro answered on Jan 18, 2017 10:11 PM
      If you could keep me in the loop that would be great! I was hoping the stack trace would be able to tie to a specific bug fix.
      I'm going to have to see what we can do to upgrade the controls, rebuild and get the application to the customer in a reproducible scenario, but sometimes that's not always easy. But I will for sure try and report results if we're able to. In the meantime, if any new information comes up, please let  me know!
        Mike Bowshewicz
        Mike Bowshewicz answered on Jan 19, 2017 9:08 PM
        Hi Steve,
        I will keep you informed on this issue.
        We aren't sure of the exact issue from the available information, but we do have a few ideas of development items that might be related. All of these items that we think might be the one you encountered are fixed in 16.2, so we believe that there is a high probability that upgrading to 16.2 will resolve this in your application.
        If you are able to perform this upgrade, please let us know the results. If it is possible, I recommend creating a reproduction sample on which to test your upgrade. It will be much easier to switch versions on a sample, and you will already have a sample to send to us for further investigation in the event that the issue persists.
        Shawn Quillman
        Shawn Quillman answered on Jan 25, 2017 9:06 PM
        If it helps, I'm having a very similar issue with an UltraWinGrid.  The control crashes, Red X, etc…  The stack trace is very similar as well:
           at Infragistics.Win.EmbeddableImageRendererUIElement.PositionChildElements()
           at Infragistics.Win.UIElement.DrawElement(UIElementDrawParams& defaultDrawParams)
           at Infragistics.Win.UIElement.DrawChildElements(UIElementDrawParams& drawParams)
           at Infragistics.Win.UIElement.DrawHelper(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Boolean clipText, Boolean forceDrawAsFocused, Boolean preventAlphaBlendGraphics)
           at Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode, Size elementSize, Boolean preventAlphaBlendGraphics)
           at Infragistics.Win.ControlUIElementBase.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode)
           at Infragistics.Win.UltraWinGrid.UltraGridUIElement.Draw(Graphics graphics, Rectangle invalidRectangle, Boolean doubleBuffer, AlphaBlendMode alphaBlendMode)
           at Infragistics.Win.UltraControlBase.OnPaint(PaintEventArgs pe)
           at Infragistics.Win.UltraWinGrid.UltraGrid.OnPaint(PaintEventArgs pe)
           at System.Windows.Forms.Control.PaintWithErrorHandling(PaintEventArgs e, Int16 layer)
           at System.Windows.Forms.Control.WmPaint(Message& m)
        I am using the UltraGrid on a UserControl which is hosted inside an Excel CommonTaskPane (the project is an Excel 2013 VSTO project).
        I have been struggling with this for months and months now because it's only happening on a very small number of user machines.  It wasn't until today that I have been able to get a hold of one of the machines to debug (they're mostly people around the world and debugging remotely is not an option…)
        The "awesome" thing for my issue is that it only happens within the user's profile.  If I log in on the machine using my own Windows profile and run the add-in everything works fine.  I've done a detect and repair on Office, I've repaired .NET (4.6.1), I've removed all other Excel add-ins, etc.
        You've given me hope!  I'm currently using the UltraGrid 16.1, but am now going to update to 16.2 to see if your suspicions about the problem being resolved in that version pan out!
        -Shawn Quillman
        Shawn Quillman
        Shawn Quillman answered on Jan 25, 2017 9:36 PM
        I just upgraded to 16.2 in my project, but unfortunately it didn't resolve the issue for me.  The UltraGrid still crashes.
        Something else that might be of benefit is that in my case the crash does not happen until the content of the grid is enough to force the grid to scroll, either vertically or horizontally.  It's fine as long as the grid container can full encompass the content.  Once the content expands beyond the horizontal or vertical bounds of the control size and the horizontal or vertical scrollbars appear the grid crashes.
        And additionally, somewhat related to Steve's problem, I'm using the UltraGrid as a tree.  Expanding the bands works great, until I expand enough to make the grid scroll.
        In my case I don't think that providing a code sample will be of any benefit since it seems to be related to the user profile…
        -Shawn Quillman
        Steve Fusaro
        Steve Fusaro answered on Jan 26, 2017 2:29 PM
        Thanks for the info Shawn. I think I ran into something similar a while back (if I recall, using the UltraTree, if the nodes were off the screen and the scrollbar was visible, doing something with them programmatically caused a null ref exception, but that's assuming my memory is correct).
        As far as my issue goes, I haven't been able to line up a time to upgrade and roll it out to our customer, so I have no new update.
        Shawn Quillman
        Shawn Quillman answered on Jan 26, 2017 2:59 PM
        After doing some more digging I was able to narrow my problem down a bit more last night.  It seems that it's not necessarily an issue with the Infragistics control in my case (but the control is also not catching the exception that bubbles up).
        In my project I have a class that binds to the grid rows.  This class contains Image properties that get read during grid row initialization and used as the image icons for button cells.  The images in this class are loaded by the resource manager from PNG images embedded in the project's .resx file.  In my case, something is either corrupting these images in memory or causing them to be disposed.
        I was able to implement a workaround to this by creating a static class that holds cloned instances of these images.  Here is some code that illustrates it:
        ImageLibrary (static class holding clones of images from the resource file):
        public static class ImageLibrary
            static ImageLibrary()
                Image1 = (Bitmap)Resources.Image1.Clone();
                Image2 = (Bitmap)Resources.Image2.Clone();
            public static Image Image1 { get; private set; }
            public static Image Image2 { get; private set; }
        TreeItem class (binds to grid rows)
        public class TreeItem {
            public TreeItem() {}
            public Image Image1 {
                get { return ImageLibrary.Image1; }
            public Image Image2 {
                get {return ImageLibrary.Image2; }
        I don't yet know what is causing the images from the resource file to go away.  I'm working on that one right now.  Hopefully this helps you with your problem as well.  If it doesn't, I'm sorry to have hijacked your thread!
        John
        John answered on Sep 4, 2018 2:24 PM
        I'm glad you hijacked the thread. This was the case for us as well. Used an image from a resource file.
        Static image wrapper worked perfectly!
Steve Fusaro
8 years, 2 months ago
Sep 4, 2018 2:24 PM
Sep 4, 2018 2:24 PM
