The type ‘Infragistics.WebUI.UltraWebGrid.UltraWebGrid’ exists in both "…" and "…"
New DiscussionI just created a new web project and after I add the infragistics into the project, I got the error as:
Error 3 The type ‘Infragistics.WebUI.UltraWebGrid.UltraWebGrid’ exists in both ‘c:\Program Files (x86)\Infragistics\NetAdvantage for .NET 2009.1\ASP.NET\CLR3.5\Bin\Infragistics35.WebUI.UltraWebGrid.v9.1.dll’ and ‘c:\Windows\assembly\GAC_MSIL\Infragistics2.WebUI.UltraWebGrid.v9.1\9.1.20091.1015__7dd5c3163f2cd0cb\Infragistics2.WebUI.UltraWebGrid.v9.1.dll’ ….
Here is my web.config:
<add assembly=”Infragistics2.WebUI.UltraWebGrid.v9.1, Version=9.1.20091.1015, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB”/>
<add assembly=”Infragistics2.WebUI.Shared.v9.1, Version=9.1.20091.1015, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB”/>
in default.aspx:
<%@ Register Assembly=”Infragistics2.WebUI.UltraWebGrid.v9.1, Version=9.1.20091.1015, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb”
Namespace=”Infragistics.WebUI.UltraWebGrid” TagPrefix=”igtbl” %>
In references folder, I have all needed .dlls ….
In the properties folder, there is a license file as:
Infragistics.WebUI.UltraWebGrid.UltraWebGrid, Infragistics2.WebUI.UltraWebGrid.v9.1, Version=9.1.20091.1015, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
I am not sure, I am missing something. Searching through this forum, there are several similar cases but I still could not figure out the solution.
Please help.
Bests
le9569
