Update to latest Version 21.2.52 broke IgbDataGrid
New DiscussionAfter update to Version 21.2.52 can't load IgbDataGrid.
The same source code with a previous Version 21.2.1 works without problems.
Error stack trace:
Error: System.InvalidOperationException: Unable to set property 'DataSource' on object of type 'IgniteUI.Blazor.Controls.IgbDataGrid'. The error was: Object reference not set to an instance of an object. ---> System.NullReferenceException: Object reference not set to an instance of an object. at IgniteUI.Blazor.Controls.JsonDataSourceItem.GetDateCacheAsJson(Utf8JsonWriter writer, String parentKey) at IgniteUI.Blazor.Controls.JsonDataSource.GetDateCacheAsJson() at IgniteUI.Blazor.Controls.BaseRendererControl.OnRefChanged(String refName, Object refValue) at IgniteUI.Blazor.Controls.DataSourceManager.OnRefChanged(String path, Object data) at IgniteUI.Blazor.Controls.BaseRendererControl.OnRefChanged(String propertyName, Object oldValue, Object newValue, Boolean isScript, Boolean isElement, Action`3 refChanged) at IgniteUI.Blazor.Controls.BaseRendererElement.OnRefChanged(String propertyName, Object oldValue, Object newValue, Boolean isScript, Boolean isElement, Action`3 refChanged) at IgniteUI.Blazor.Controls.BaseRendererElement.FlushRefs() at IgniteUI.Blazor.Controls.BaseRendererElement.set_Parent(Object value) at IgniteUI.Blazor.Controls.IgbDataGrid.set_DataSource(Object value) at Microsoft.AspNetCore.Components.Reflection.PropertySetter.CallPropertySetter[TTarget,TValue](Action`2 setter, Object target, Object value) at Microsoft.AspNetCore.Components.Reflection.ComponentProperties.g__SetProperty|2_0(Object target, PropertySetter writer, String parameterName, Object value) --- End of inner exception stack trace --- at Microsoft.AspNetCore.Components.Reflection.ComponentProperties. g__SetProperty|2_0(Object target, PropertySetter writer, String parameterName, Object value) at Microsoft.AspNetCore.Components.Reflection.ComponentProperties.SetProperties(ParameterView& parameters, Object target) at Microsoft.AspNetCore.Components.ParameterView.SetParameterProperties(Object target) at Microsoft.AspNetCore.Components.ComponentBase.SetParametersAsync(ParameterView parameters) at Microsoft.AspNetCore.Components.Rendering.ComponentState.SetDirectParameters(ParameterView parameters) at Microsoft.AspNetCore.Components.RenderTree.RenderTreeDiffBuilder.InitializeNewComponentFrame(DiffContext& diffContext, Int32 frameIndex) at Microsoft.AspNetCore.Components.RenderTree.RenderTreeDiffBuilder.InitializeNewSubtree(DiffContext& diffContext, Int32 frameIndex) at Microsoft.AspNetCore.Components.RenderTree.RenderTreeDiffBuilder.InsertNewFrame(DiffContext& diffContext, Int32 newFrameIndex) at Microsoft.AspNetCore.Components.RenderTree.RenderTreeDiffBuilder.AppendDiffEntriesForRange(DiffContext& diffContext, Int32 oldStartIndex, Int32 oldEndIndexExcl, Int32 newStartIndex, Int32 newEndIndexExcl) at Microsoft.AspNetCore.Components.RenderTree.RenderTreeDiffBuilder.AppendDiffEntriesForFramesWithSameSequence(DiffContext& diffContext, Int32 oldFrameIndex, Int32 newFrameIndex) at Microsoft.AspNetCore.Components.RenderTree.RenderTreeDiffBuilder.AppendDiffEntriesForRange(DiffContext& diffContext, Int32 oldStartIndex, Int32 oldEndIndexExcl, Int32 newStartIndex, Int32 newEndIndexExcl) at Microsoft.AspNetCore.Components.RenderTree.RenderTreeDiffBuilder.ComputeDiff(Renderer renderer, RenderBatchBuilder batchBuilder, Int32 componentId, ArrayRange`1 oldTree, ArrayRange`1 newTree) at Microsoft.AspNetCore.Components.Rendering.ComponentState.RenderIntoBatch(RenderBatchBuilder batchBuilder, RenderFragment renderFragment) at Microsoft.AspNetCore.Components.RenderTree.Renderer.RenderInExistingBatch(RenderQueueEntry renderQueueEntry) at Microsoft.AspNetCore.Components.RenderTree.Renderer.ProcessRenderQueue()
Sign In
to post a reply
3 Created On
Mar 31, 2022 Last Post
4 years, 5 months ago
