Infragistics Community Forum / Web / Ultimate UI for ASP.NET Web Forms / Add button inside webdatagrid columns from code behind
achraf gharbi
achraf gharbi asked on May 14, 2019 10:59 AM
Hi , how can i add a button inside webdatagrid column from code behind ?
    Hristo Popov
    Hristo Popov answered on May 9, 2019 1:20 PM
    Thank you for contacting us!
    Adding a button column through the code is described in this help topic – https://www.infragistics.com/help/aspnet/webdatagrid-using-item-template
    I also made a sample based on your requirement.Wbdg_5F00_add_5F00_button_5F00_on_5F00_column.zip
    Please, take a look at the topic and the sample and let me know if you have any questions.
    Hristo Popov
      achraf gharbi
      achraf gharbi answered on May 10, 2019 7:44 AM
      hi , thank you but this not what iam looking for its more like adding a button inside a data row like this  :
      in the first column along side with the data i need to display a button from code behind with every data load !
        Hristo Popov
        Hristo Popov answered on May 14, 2019 10:59 AM
        To add a button alongside a data item in a cell, you can add this code snippet in the CustomTemplate class:
                    Label label = new Label();
                    label.ID = "TemplateLabel";
                    label.CssClass = "id-label";
                    label.Text = ((DataRowView)((TemplateContainer)container).DataItem)["id"].ToString();
                    container.Controls.Add(label);
        Your InstantiateIn method in the CustomTemplate should look like this:
                    Button delete = new Button();
                    delete.ID = "TemplateButton";
                    delete.Text = "Delete";
                    delete.OnClientClick = "return deleteRow()";
                    container.Controls.Add(delete);
        This way you are filling the container with a label that contains the respective id of the cell.
        Here is a help topic for your reference – https://www.infragistics.com/help/aspnet/webdatagrid-refrence-a-cell-when-creating-an-item-template.
        Hristo Popov
achraf gharbi
7 years, 6 months ago
Feb 20, 2026 12:47 PM
