Infragistics Community Forum / Web / Ultimate UI for ASP.NET Web Forms / WebDataGrid and SelectedRow Server Side
John
John asked on Nov 24, 2017 5:59 AM
 How can I access the the rows selected in a WebDataGrid on the server side?
For example, I have a WebDataGrid and I've enabled the Selection behavior fot it.  I want the user to be able to select a row in the WebDataGrid then click a button which calls server side code to process the selected row (i.e. getting the values of some of the columns of the selected row).
 I think I need to use the SelectedRowsCollection somehow, but not sure how to use it with my WebDataGrid.
John
    Alex Kartavov
    Alex Kartavov answered on Nov 20, 2008 8:13 PM
    Hi John,
    It's off the Selection behavior:
    grid.Behaviors.Selection.SelectedRows;
      John
      John answered on Nov 20, 2008 11:38 PM
       Alex,
       I'm one step closer, but I can't seem to read the records in the SelectedRows collection.  Here's my sample code.  When I run it, the selectedRow variable returns null.  When I'm debugging, I do see one record selected in wdgFabric.Behaviors.Selection.SelectedRows.
       Am I doing something wrong?
      // inside my button_clicked method – after I've selected a row
               string tmp;
              if (wdgFabric.Behaviors.Selection.SelectedRows.Count > 0)
                  foreach (GridRecord selectedRow in wdgFabric.Behaviors.Selection.SelectedRows)     // errors out here with selectedRow returning null
                      tmp = selectedRow.Items.GetValue(1).ToString();
                      foreach (GridRecordItem selectedRowItem in selectedRow.Items)
                          Label2.Text = selectedRowItem.Text.ToString();
        Darrell Kress
        Darrell Kress answered on Nov 21, 2008 4:26 AM
        I tried out similar code in a quick sample
        <%@ Page Language="C#" AutoEventWireup="true" CodeFile="Default.aspx.cs" Inherits="_Default" %>
        <%@ Register Assembly="Infragistics35.Web.v8.3, Version=8.3.20083.1, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
            Namespace="Infragistics.Web.UI.GridControls" TagPrefix="ig" %>
        <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"&gt;
        <head runat="server">
            <title></title>
        </head>
        <body>
            <div>
                </asp:ScriptManager>
                <ig:WebDataGrid ID="WebDataGrid1" runat="server" Height="350px" Width="400px"
                    AutoGenerateColumns="False" DataSourceID="SqlDataSource1">
                    <Behaviors>
                        <ig:Selection CellClickAction="Row" RowSelectType="Multiple">
                        </ig:Selection>
                    </Behaviors>
                    <Columns>
                        <ig:BoundDataField DataFieldName="CustomerID" Key="CustomerID">
                            <Header Text="CustomerID" />
                        </ig:BoundDataField>
                        <ig:BoundDataField DataFieldName="CompanyName" Key="CompanyName">
                            <Header Text="CompanyName" />
                        <ig:BoundDataField DataFieldName="ContactName" Key="ContactName">
                            <Header Text="ContactName" />
                    </Columns>
                </ig:WebDataGrid>
                <asp:Button runat=server onclick="Unnamed1_Click" />
                <asp:SqlDataSource ID="SqlDataSource1" runat="server"
                    ConnectionString="<%$ ConnectionStrings:NORTHWNDConnectionString %>"
                    SelectCommand="SELECT [CustomerID], [CompanyName], [ContactName] FROM [Customers]"></asp:SqlDataSource>
            </div>
            </form>
        </body>
        </html>
        With the following code behind in the button click
        protected void Unnamed1_Click(object sender, EventArgs e)
        foreach (GridRecord row in this.WebDataGrid1.Behaviors.Selection.SelectedRows)
        if (row != null)
        and the row was != null in my tests. Could you try a really small sample and see if it works for you?
        Stijn René Cumps
        Stijn René Cumps answered on Nov 26, 2008 1:42 PM
        I am encountering the same problem. The row is alway, in my case, Nothing. I can assure you that it is really frustrating to do something so simple when it isn't working. I hope you can find my problem.
        I pass you the code behind:
        Protected Sub lnkbtnEditar_Clicked(ByVal sender As Object, ByVal e As EventArgs)
                For Each row As GridRecord In WebDataGrid1.Behaviors.Selection.SelectedRows
                    If Not (row Is Nothing) Then
                        Dim iCount As Integer = row.Items.Count
                    End If
                Next
        End Sub
        The aspx page code:
        <ig:WebDataGrid ID="WebDataGrid1" runat="server" DataKeyFields="ID" StyleSetName="Claymation" AutoGenerateColumns="False" Width="260px" StyleSetPath="~/ig_res">
        <Columns>
            <ig:TemplateDataField Key="Año" Width="50px">
                <ItemTemplate>
                    <asp:Label ID="lblAño" runat="server"><%#DataBinder.Eval(CType(Container, Infragistics.Web.UI.TemplateContainer).DataItem, "Año")%></asp:Label>
                </ItemTemplate>
                <Header Text="Año" />
            </ig:TemplateDataField>
            <ig:TemplateDataField Key="Fecha inicial" Width="81px">
                <ItemTemplate>
                    <asp:Label ID="lblIniVig" runat="server"><%#DataBinder.Eval(CType(Container, Infragistics.Web.UI.TemplateContainer).DataItem, "IniVig")%></asp:Label>
                </ItemTemplate>
                <Header Text="Fecha inicial" />
            <ig:TemplateDataField Key="Fecha final" Width="81px">
                <ItemTemplate>
                    <asp:Label ID="lblFinVig" runat="server"><%#DataBinder.Eval(CType(Container, Infragistics.Web.UI.TemplateContainer).DataItem, "FinVig")%></asp:Label>
                </ItemTemplate>
                <Header Text="Fecha final" />
        </Columns>
        <Behaviors>
            <ig:Selection RowSelectType="Single" CellClickAction="Row">
            <SelectionClientEvents RowSelectionChanged="WebDataGrid1_RowSelectionChanged" />
            </ig:Selection>
            <ig:Sorting SortingMode="Single" Enabled="true"></ig:Sorting>
        </Behaviors>
        </ig:WebDataGrid>
        <asp:LinkButton ID="lnkbtnEditar" runat="server" CausesValidation="false" OnClick="lnkbtnEditar_Clicked">Editar</asp:LinkButton>
        <script language="javascript" type="text/javascript">
                function WebDataGrid1_RowSelectionChanged(webDataGrid, evntArgs) {
                    //for the moment do nothing
        </script>
        Thomas
        Thomas answered on Dec 2, 2008 10:32 AM
        public string GetSelValTemp(WebDataGrid g, string col)
        if (g.Behaviors.Selection.SelectedRows.Count < 1) return "";
        foreach ( GridRecord row in g.Behaviors.Selection.SelectedRows)
        if (row != null)
        int countItems = row.Items.Count;for (int i = 0; i < countItems; i++)
        GridRecordItem gi = row.Items[i];if (F.EqualsIC(gi.Column.Footer.FieldKey, col)) return F.ToString(gi.Text);
        return "";
        the foreach does not work, i think because of the forgotten implementation of ienumerable function.
        dominique
        dominique answered on Dec 18, 2008 1:49 PM
        I have the same issue.
        First point
        Could you tell me please the equivalance  webdatagrid of this line working correctly with a GridView? :
        num_oc =long.Parse(GridView1.Rows[GridView1.SelectedIndex].Cells[1].Text);
        Second Point
        I am not a specialist of Infragistics but I would like to know  what is the mean to find in my webdatagrid the value of the first column in the row selected  by the user example : 27
        In my code below the row is null !!!!!
        foreach (GridRecord row in this.WebDataGridPlanting.Behaviors.Selection.SelectedRows)
        if (row != null)
        int i=+1;
        Darrell Kress
        Darrell Kress answered on Dec 18, 2008 6:16 PM
         I am going to ask that someone who is able to reproduce this issue submit an issue to Developer Support so that the issue can be tracked down.  Please include a sample project that shows this issue.
        I tried this from the code posted in the forum and could not reproduce this behavior.
        John
        John answered on Dec 18, 2008 8:00 PM
         I think the reason for getting null for the SelectedRows collection is when using a SQLDataSource as opposed to a dataset to load the WebDataGrid.  I loaded data with the SQLDataSource and I can retrieve my selected row fine.  When I use a dataset, the selected row is null.
        Here's my source that does both the SQLDataSource & DataSet.  The WebDataGrid1 uses the SQLDataSource and the WebDataGrid2 uses a dataset.
        <%@ Register Assembly="System.Web.Extensions, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"
            Namespace="System.Web.UI" TagPrefix="asp" %>
        <%@ Register Assembly="Infragistics2.Web.v8.3, Version=8.3.20083.1009, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
            <title></title>
        </head>
        <body>
            <div>
                    <Behaviors>
                        <ig:RowSelectors>
                        </ig:RowSelectors>
                        <ig:Selection CellClickAction="Row" RowSelectType="Single">
                        </ig:Selection>
                    </Behaviors>
                    <Columns>
                        <ig:BoundDataField DataFieldName="AssemblyGroup" Key="AssemblyGroup">
                            <Header Text="AssemblyGroup" />
                        <ig:BoundDataField DataFieldName="AssemblyType" Key="AssemblyType">
                            <Header Text="AssemblyType" />
                        <ig:BoundDataField DataFieldName="FullChair" Key="FullChair">
                            <Header Text="FullChair" />
                    </Columns>
                </ig:WebDataGrid>
            </div>
                ConnectionString="<%$ ConnectionStrings:SOIApplicationsConnectionString %>"
                SelectCommand="spBDC_GetAssemblyGroupType" SelectCommandType="StoredProcedure">
            <asp:Button ID="Button1" runat="server" Text="Button" onclick="Button1_Click" />
            <br />
            <asp:Label ID="Label1" runat="server" Text="Label"></asp:Label>
            <br />
            <ig:WebDataGrid ID="WebDataGrid2" runat="server" Height="350px" Width="400px">
                <Behaviors>
                    </ig:Selection>
                    <ig:RowSelectors>
                    </ig:RowSelectors>
                </Behaviors>
            </ig:WebDataGrid>
            <asp:Button ID="Button2" runat="server" onclick="Button2_Click" Text="Button" />
            <asp:Label ID="Label2" runat="server" Text="Label"></asp:Label>
            <br />
            </form>
        </body>
        </html>
          using System;
        using System.Web;
        using System.Web.UI;
        using Infragistics.Web.UI;
        using Infragistics.Web.UI.GridControls;
        using System;
        using System.Configuration;
        using System.Collections;
        using System.Data;
        public partial class _Default : System.Web.UI.Page
                if (!IsPostBack)
                    Fill_AssemblyGroupType_Grid();
            protected void Fill_AssemblyGroupType_Grid()
                string spName = "spBDC_GetAssemblyGroupType";
                WebDataGrid.DataManager myDataManager = new WebDataGrid.DataManager("MS_SQL_ConnectionString", "DatabaseType");
                DataTable myDataTable = new DataTable();
                myDataTable = myDataManager.GetDataTableFromSP(spName);
                WebDataGrid2.DataSource = myDataTable;
                WebDataGrid2.DataBind();
                WebDataGrid2.Visible = true;
            protected void Button1_Click(object sender, EventArgs e)
                string tmp;
                if (WebDataGrid1.Behaviors.Selection.SelectedRows.Count > 0)
                    foreach (GridRecord selectedRow in WebDataGrid1.Behaviors.Selection.SelectedRows)     // errors out here with selectedRow returning null
                        Label1.Text = tmp;
            protected void Button2_Click(object sender, EventArgs e)
                string tmp;
                if (WebDataGrid2.Behaviors.Selection.SelectedRows.Count > 0)
                    foreach (GridRecord selectedRow in WebDataGrid2.Behaviors.Selection.SelectedRows)     // errors out here with selectedRow returning null
                        Label2.Text = tmp;
        Alex Kartavov
        Alex Kartavov answered on Dec 18, 2008 8:12 PM
        If you're assigning the data source only once the EnableDataViewState
        property must be set to True. That way the data will be serialized into
        the view state and available after the post back.
        Having EnableDataViewState set to False saves tons of view state bytes,
        but the data source must be assigned on every post back in that case.
        dominique
        dominique answered on Dec 29, 2008 3:06 PM
        Ok It works now.
        I loaded data with the SQLDataSource and I can retrieve my selected row fine. It is oK I can have the value of my row selected and put it in session variable.
        Could help me for a global problem :
        I would like to update my data  from my ultrawebgrid to  my linqdatasource.
         What is the best way to put a submit button.. a special function..
        Do you have some example please?
        Thank for your help.
        Alex Kartavov
        Alex Kartavov answered on Jan 6, 2009 2:11 PM
        If your linqdatasource supports auto updating both WebDataGrid and
        UltraWebGrid will update it automatically.
        If you prefer to handle updates manually the WebDataGrid has the
        AutoCRUD property off the EditingCore behavior. You can set it to False
        and then the grid will only fire updating events without attempting to
        update the data source. You can take it from there. UltraWebGrid does
        not have this option.
        Hope this info helps.
        dominique
        dominique answered on Jan 7, 2009 3:14 PM
        Thank for your anwser.
        But  When I change the value in my ultrawebgrid, there is no change in the database (SQL).
        I would like to have an automatic update without code for this example.
        This is the source if you see some anomalies :
        Thank in advance for your help.
        <%@ Page Language="C#" MasterPageFile="~/MasterPageOc.master" AutoEventWireup="true" CodeFile="Germplasm.aspx.cs" Inherits="Germplasm" Title="Page sans titre" %>
        @ Register assembly="Infragistics35.WebUI.UltraWebGrid.v8.3, Version=8.3.20083.1009, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.WebUI.UltraWebGrid" tagprefix="igtbl" %><%@ Register assembly="Infragistics35.Web.v8.3, Version=8.3.20083.1009, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb" namespace="Infragistics.Web.UI.GridControls" tagprefix="ig" %>
        asp:Content ID="Content1" ContentPlaceHolderID="ContentPlaceHolder1" Runat="Server"><igtbl:UltraWebGrid ID="UltraWebGrid1" runat="server" Browser="Xml"
        DataSourceID="LinqDataSource1" Height="200px" Width="325px">
        <Bands><igtbl:UltraGridBand AddButtonCaption="inscription" BaseTableName="inscription"
        Key="inscription" AllowUpdate="Yes">
        <Columns><igtbl:UltraGridColumn BaseColumnName="ins_inscription_sys" IsBound="True"
        Key="ins_inscription_sys" AllowUpdate="No">
        <Header Caption="ins_inscription_sys">
        </Header>
        </igtbl:UltraGridColumn><igtbl:UltraGridColumn BaseColumnName="ins_cytopl" IsBound="True"
        Key="ins_cytopl" AllowUpdate="Yes">
        <Header Caption="ins_cytopl">
        <RowLayoutColumnInfo OriginX="1" />
        </Header>
        <Footer>
        </Footer>
        </Columns>
        <AddNewRow View="NotSet" Visible="NotSet">
        </AddNewRow>
        </igtbl:UltraGridBand>
        </Bands><DisplayLayout AllowColSizingDefault="Free" AllowColumnMovingDefault="OnServer"
        AllowSortingDefault="OnClient" AllowUpdateDefault="Yes" BorderCollapseDefault="Separate" HeaderClickActionDefault="SortMulti"
        LoadOnDemand="Xml" Name="UltraWebGrid1" RowHeightDefault="20px" RowSelectorsDefault="No" SelectTypeRowDefault="Extended"
        StationaryMargins="Header" StationaryMarginsOutlookGroupBy="True"
        TableLayout="Fixed" Version="4.00"><FrameStyle BackColor="Window" BorderColor="InactiveCaption"
        BorderStyle="Solid" BorderWidth="1px" Font-Names="Microsoft Sans Serif"
        Font-Size="8.25pt" Height="200px" Width="325px">
        </FrameStyle>
        <Pager MinimumPagesForDisplay="2">
        <PagerStyle BackColor="LightGray" BorderStyle="Solid" BorderWidth="1px"><BorderDetails ColorLeft="White" ColorTop="White" WidthLeft="1px"
        WidthTop="1px" />
        </PagerStyle>
        </Pager>
        <EditCellStyleDefault BorderStyle="None" BorderWidth="0px">
        </EditCellStyleDefault>
        <FooterStyleDefault BackColor="LightGray" BorderStyle="Solid" BorderWidth="1px"><BorderDetails ColorLeft="White" ColorTop="White" WidthLeft="1px"
        WidthTop="1px" />
        </FooterStyleDefault><HeaderStyleDefault BackColor="LightGray" BorderStyle="Solid"
        HorizontalAlign="Left"><BorderDetails ColorLeft="White" ColorTop="White" WidthLeft="1px"
        WidthTop="1px" />
        </HeaderStyleDefault><RowStyleDefault BackColor="Window" BorderColor="Silver" BorderStyle="Solid"
        BorderWidth="1px" Font-Names="Microsoft Sans Serif" Font-Size="8.25pt">
        <Padding Left="3px" />
        <BorderDetails ColorLeft="Window" ColorTop="Window" />
        </RowStyleDefault>
        <GroupByRowStyleDefault BackColor="Control" BorderColor="Window">
        </GroupByRowStyleDefault>
        <GroupByBox>
        <BoxStyle BackColor="ActiveBorder" BorderColor="Window">
        </BoxStyle>
        </GroupByBox>
        <AddNewBox><BoxStyle BackColor="Window" BorderColor="InactiveCaption" BorderStyle="Solid"
        WidthTop="1px" />
        </BoxStyle>
        </AddNewBox>
        <ActivationObject BorderColor="" BorderWidth="">
        </ActivationObject>
        <FilterOptionsDefault><FilterDropDownStyle BackColor="White" BorderColor="Silver" BorderStyle="Solid"
        BorderWidth="1px" CustomRules="overflow:auto;" Font-Names="Verdana,Arial,Helvetica,sans-serif" Font-Size="11px" Height="300px"
        Width="200px">
        <Padding Left="2px" />
        </FilterDropDownStyle>
        <FilterHighlightRowStyle BackColor="#151C55" ForeColor="White">
        </FilterHighlightRowStyle><FilterOperandDropDownStyle BackColor="White" BorderColor="Silver"
        BorderStyle="Solid" BorderWidth="1px" CustomRules="overflow:auto;"
        Font-Names="Verdana,Arial,Helvetica,sans-serif" Font-Size="11px">
        </FilterOperandDropDownStyle>
        </FilterOptionsDefault>
        </DisplayLayout>
        </igtbl:UltraWebGrid><asp:LinqDataSource ID="LinqDataSource1" runat="server"
        ContextTypeName="DataClassesDataContext" Select="new (ins_inscription_sys, ins_cytopl)" TableName="inscription"
        EnableUpdate="True">
        </asp:LinqDataSource>
        </asp:Content>
        Alex Kartavov
        Alex Kartavov answered on Jan 7, 2009 4:45 PM
        I;d suggest you to contact dev support. Sorry for inconvenience. Thanks.
        Mike
        Mike answered on Apr 27, 2009 10:53 PM
        I am having an urgent issue with WebDatGrid and retrievng the selected row.
        I have a single WDG on my page, and depending on the users' selection from a WebListBar, I redraw the contents of the WDG – using a 32 teir architecture (no direct DB access from the presentation layer)
        More specifcally, I create a DataTable and set the WDG.DataSource to it.
        I have everything working well for displaying the data… except I cannot get the selected row from the control when I need to.
        When the user clicks my "Edit…" button, I *want* to retrieve the selected row, and display a WebDialogWindow with the data to edit…
        but this fails everytime…
        if
        (WebDataGrid1.Behaviors.Selection.SelectedRows.Count > 0) {
        foreach (GridRecord row in this.WebDataGrid1.Behaviors.Selection.SelectedRows) {
        if (null == row)
        _log.Debug(
        "SelectedRow is null");  // this always logs!
        Since I am re-assigning DataSource regularly to the WDG, I cannot set EnableDataViewState to True.
        This is a showstopper for me – please advise!
        Mike
        Mike answered on Apr 28, 2009 1:15 AM
        Anyone else having this problem – I found the obvious answer – through talking it through with a colleague –
        The WebDataGrid does not have any data in it until I (re)add the datasource to it.
        I had previously had
        protected void EditButton_Click(object sender, EventArgs e) {
          // get selected row
          // do stuff…
          // generate DataTable and set the WDG datasource;
        By changing that order, so that I set the WDG datasource FIRST, I have a valid GridRow in SelectedRows.
        Ramya
        Ramya answered on Jan 10, 2011 10:32 AM
        Am  facing issue in
        foreach (GridRecord row in this.availableTasks.Behaviors.Selection.SelectedRows)//in row am getting NULL
        int wiid = Int32.Parse(row.Items[this.availableTasks.Columns["WorkflowInstanceId"].Index].Value.ToString());
        EnableDataView property is true for webdatagrid and am binding Data in
        Public void PopulateTable()
        dt =
        AvailableTaskManagement.GetAvailableTasksTable(aTasksWfRoles, aTasksQueue, aTasksResultSize, workflowRoles);
        if
        (updateCounts)
        //todo: update available tasks count
        availableTasks.DataSource = dt;
        availableTasks.DataBind();
        availableTasks.Visible =
        true;
        Abhishek
        Abhishek answered on Sep 17, 2011 10:53 PM
        Hi Everyone,
        i found a workaround to get the current row in index in Server Side, Hope the following code will help
        string currentRowIndex = this.WebDataGrid1.Behaviors.Activation.ActiveCell.Row.Index.ToString();
        Abhishek
        goussarova
        goussarova answered on Aug 9, 2017 10:19 PM
        thank you, this helped.
        Kristy
        Kristy answered on Mar 26, 2010 3:54 PM
        My company just brought Infragistics product a few months ago. I encounted the same issue as other people have. I have a webdatagrid and enabled rowselect ='multiple'. However, when I check which rows are selected, the null value is returned from selectedRow. I use dataset as my webdatagrid datasource.  What can I do to get the value? I am able to get correct rowselection count.
        protected void WebImageButtonAdd_Click(object sender, Infragistics.WebUI.WebDataInput.ButtonEventArgs e) {
        string temp = string
        .Empty;
        if
        (CheckBoxCustomer.Checked)
        InsertNews(Server.HtmlEncode(TextEditorTitle.Text), Server.HtmlEncode(TextEditorDescription.Text),
        true, true, WindowsIdentity.GetCurrent().Name, DateTime.Now, WindowsIdentity.GetCurrent().Name, DateTime
        .Now);
        else
        if
        (WebDataGridCustomers.Behaviors.Selection.SelectedRows.Count>0)
        WebDataGridCustomers.Behaviors.Selection.SelectedRows)
        John
        John answered on Mar 26, 2010 5:29 PM
        Kristy
        Kristy answered on Mar 26, 2010 5:34 PM
        Thanks for your reply. I have received help from one of their developers. The answer is pretty simple, set  webdatagrid property "EnableDataViewState" to true since I only bind my datasource once.
        Thanks you very much for your reply!
        Ramya
        Ramya answered on Jan 10, 2011 10:39 AM
        Am not binding datasource in source page am binding in server side.and EnableDataViewState is true then also when i select a row its passing null value
        foreach (GridRecord r in thi.availableTasks.Behaviors.Selection.SelectedRows)
        int wiid = Int32.Parse(r.Items[this.availableTasks.Columns["WorkflowInstanceId"].Index].Value.ToString());
        Please give solution as soon as possible.Its urgent.Thanks in advance
        [Infragistics] Olga Kerchentseva
        [Infragistics] Olga Kerchentseva answered on Jan 25, 2011 7:21 PM
        Can you please post a simple website reproducing the issue?  Its hard to tell what is going on from the code snipet.
        Thank You,
        Olga
    HSU MIN YANG
    HSU MIN YANG answered on Nov 24, 2017 5:59 AM
    this may be a  other solution: in WebDataGrid  You must set
    EnableDataViewState="True"  ViewStateMode="Enabled"  AND Open selection option
    <ig:Selection CellClickAction="Row" RowSelectType="Single" ….>
    foreach (Infragistics.Web.UI.GridControls.GridRecord r in WebDataGrid1.Behaviors.Selection.SelectedRows)
       if (r != null)
           XX = r.Items[WebDataGrid1.Columns["Name"].Index].Value.ToString(); //well be get Cell value or text
John
8 years, 11 months ago
