Where is version upgrade utility?
Dorn
Dorn asked on Nov 9, 2010 4:00 PM
I've installed 2010.3 (via "NetAdvantage_ASPNETWithSamplesAndHelp_20103.exe") and there's no "Version Upgrade Utility" anywhere!  Nothing in the Start / All Programs Infragistics / NetAdvantage 2010.3 / ASP.NET / Utilities folder, nothing in the C:\Program Files\Infragistics\NetAdvantage 2010.3\ASP.NET subfolders… where is it, please?  The documentation clearly shows it's supposed to be somewhere – see "ms-help://NetAdvantage_ASPNET103/Web_ASPNET103/WebElements/Web_Using_Version_Upgrade_Utility.html"
    Elizabeth Albert
    Elizabeth Albert answered on Nov 8, 2010 10:56 PM
    Hello dornegley,
    There should be a shortcut to the Version Utility in the Start menu under Start / All Programs / Infragistics / NetAdvantage 2010.3.  It's not specific to the product (ASP.NET), but to the NetAdvantage version.
    You can also run it from the .exe located here:
    C:\Program Files\Common Files\Infragistics\NetAdvantage 2010.3\Version Utility
    Please let me know if you have other questions about this.
    Elizabeth Albert
    Localization Engineer
      Dorn
      Dorn answered on Nov 8, 2010 11:17 PM
      Hello Elizabeth – small problem:  there IS no C:\Program Files\Common Files\Infragistics\NetAdvantage 2010.3\Version Utility.  Pretty sure I did a plain-vanilla install…
        Elizabeth Albert
        Elizabeth Albert answered on Nov 8, 2010 11:25 PM
        The screenshot you attached shows the C:\Program Files\Infragistics\NetAdvantage 2010.3 folder.
        Could you please check the C:\Program Files\Common Files\Infragistics\NetAdvantage 2010.3 folder?
        I have attached a screenshot.
        Dorn
        Dorn answered on Nov 9, 2010 3:53 PM
        Son of a gun!  There it is – you were entirely correct!  No link was created in the Start / All Programs hierarchy at install time, but the code sure is there.  I'd love to know why y'all decided to put this tool in 'Common Files' instead of "C:\Program Files\Infragistics\NetAdvantage 2010.3\ASP.NET", but I'm not gonna complain…  Thanks a bunch!
        Elizabeth Albert
        Elizabeth Albert answered on Nov 9, 2010 4:00 PM
        The reason why it is put into the 'Common Files' folder is that the utility is shared between products.  For example, if I install ASP.NET and Windows Forms, I will have one copy of the utility instead of two.
        Glad you found it. 🙂  Let me know if you have any other questions.
Dorn
16 years ago
Nov 9, 2010 4:00 PM
Nov 9, 2010 4:00 PM
