ClickOnce Publication Issues
Rapid Apps
Rapid Apps asked on Aug 7, 2018 6:21 PM
We just updated our Windows Forms to the latest Infragistics 18.1 version. We did that through Microsoft Visual Studio 2017.
When our application is attempted to be installed/upgraded ona remote client machine, the following error message comes up and prevents the installation to take place successfully.
“Value does not fall within the expected range.”
Here is the entire error log:
PLATFORM VERSION INFO
Windows : 10.0.17134.0 (Win32NT)
Common Language Runtime : 4.0.30319.42000
System.Deployment.dll : 4.7.3056.0 built by: NET472REL1
clr.dll : 4.7.3131.0 built by: NET472REL1LAST
dfdll.dll : 4.7.3056.0 built by: NET472REL1
dfshim.dll : 10.0.17134.1 (WinBuild.160101.0800)
SOURCES
Deployment url : file:///C:/Users/Vesko%20Kehayov/AppData/Roaming/Microsoft/Internet%20Explorer/Quick%20Launch/User%20Pinned/TaskBar/Rapid%20ERP%20Systems.appref-ms%7C
Server : Microsoft-IIS/8.5
X-Powered-By : ASP.NET
Deployment Provider url : prealpha.rapidappsinc.com/Rapid Apps.Pump Magic.application
Application url : prealpha.rapidappsinc.com/…/Rapid Apps.Pump Magic.exe.manifest
IDENTITIES
Application Identity : Rapid Apps.Pump Magic.exe, Version=1.1808.6.9, Culture=neutral, PublicKeyToken=34ad0424c939035d, processorArchitecture=msil, type=win32
ERROR SUMMARY
Below is a summary of the errors, details of these errors are listed later in the log.
* Activation of C:\Users\Vesko Kehayov\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\User Pinned\TaskBar\Rapid ERP Systems.appref-ms| resulted in exception. Following failure messages were detected:
+ Value does not fall within the expected range.
COMPONENT STORE TRANSACTION FAILURE SUMMARY
No transaction error was detected.
WARNINGS
There were no warnings during this operation.
OPERATION PROGRESS STATUS
* [8/6/2018 1:19:52 PM] : Activation of C:\Users\Vesko Kehayov\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\User Pinned\TaskBar\Rapid ERP Systems.appref-ms| has started.
* [8/6/2018 1:19:52 PM] : Performing necessary update check as specified by the deployment.
* [8/6/2018 1:19:52 PM] : Consuming new update.
* [8/6/2018 1:19:52 PM] : Installation of the application has started.
* [8/6/2018 1:19:53 PM] : Processing of application manifest has successfully completed.
* [8/6/2018 1:19:53 PM] : Found compatible runtime version 4.0.30319.
* [8/6/2018 1:19:53 PM] : Detecting dependent assembly System.Runtime.InteropServices.RuntimeInformation, Version=4.0.2.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A, processorArchitecture=msil using System.Runtime.InteropServices.RuntimeInformation, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a, processorArchitecture=msil.
* [8/6/2018 1:19:53 PM] : Detecting dependent assembly Infragistics4.Win.UltraWinGrid.ExcelExport.v18.1, Version=18.1.20181.88, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB, processorArchitecture=msil using Infragistics4.Win.UltraWinGrid.ExcelExport.v18.1, Version=18.1.20181.88, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb, processorArchitecture=msil.
* [8/6/2018 1:19:53 PM] : Detecting dependent assembly Infragistics4.Win.v18.1, Version=18.1.20181.88, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB, processorArchitecture=msil using Infragistics4.Win.v18.1, Version=18.1.20181.88, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb, processorArchitecture=msil.
* [8/6/2018 1:19:53 PM] : Detecting dependent assembly Infragistics4.Win.UltraWinListView.v18.1, Version=18.1.20181.88, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB, processorArchitecture=msil using Infragistics4.Win.UltraWinListView.v18.1, Version=18.1.20181.88, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb, processorArchitecture=msil.
* [8/6/2018 1:19:53 PM] : Detecting dependent assembly Infragistics4.Win.UltraWinStatusBar.v18.1, Version=18.1.20181.88, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB, processorArchitecture=msil using Infragistics4.Win.UltraWinStatusBar.v18.1, Version=18.1.20181.88, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb, processorArchitecture=msil.
* [8/6/2018 1:19:53 PM] : Detecting dependent assembly Infragistics4.Win.UltraWinToolbars.v18.1, Version=18.1.20181.88, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB, processorArchitecture=msil using Infragistics4.Win.UltraWinToolbars.v18.1, Version=18.1.20181.88, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb, processorArchitecture=msil.
* [8/6/2018 1:19:53 PM] : Detecting dependent assembly Infragistics4.Documents.Excel.v18.1, Version=18.1.20181.88, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB, processorArchitecture=msil using Infragistics4.Documents.Excel.v18.1, Version=18.1.20181.88, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb, processorArchitecture=msil.
* [8/6/2018 1:19:53 PM] : Detecting dependent assembly Infragistics4.Win.UltraWinTabControl.v18.1, Version=18.1.20181.88, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB, processorArchitecture=msil using Infragistics4.Win.UltraWinTabControl.v18.1, Version=18.1.20181.88, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb, processorArchitecture=msil.
* [8/6/2018 1:19:53 PM] : Detecting dependent assembly Infragistics4.Win.Misc.v18.1, Version=18.1.20181.88, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB, processorArchitecture=msil using Infragistics4.Win.Misc.v18.1, Version=18.1.20181.88, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb, processorArchitecture=msil.
* [8/6/2018 1:19:53 PM] : Detecting dependent assembly Infragistics4.Documents.Core.v18.1, Version=18.1.20181.88, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB, processorArchitecture=msil using Infragistics4.Documents.Core.v18.1, Version=18.1.20181.88, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb, processorArchitecture=msil.
* [8/6/2018 1:19:53 PM] : Detecting dependent assembly Infragistics4.Win.UltraWinExplorerBar.v18.1, Version=18.1.20181.88, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB, processorArchitecture=msil using Infragistics4.Win.UltraWinExplorerBar.v18.1, Version=18.1.20181.88, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb, processorArchitecture=msil.
* [8/6/2018 1:19:53 PM] : Detecting dependent assembly Infragistics4.Shared.v18.1, Version=18.1.20181.88, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB, processorArchitecture=msil using Infragistics4.Shared.v18.1, Version=18.1.20181.88, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb, processorArchitecture=msil.
* [8/6/2018 1:19:53 PM] : Detecting dependent assembly Infragistics4.Win.UltraWinEditors.v18.1, Version=18.1.20181.88, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB, processorArchitecture=msil using Infragistics4.Win.UltraWinEditors.v18.1, Version=18.1.20181.88, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb, processorArchitecture=msil.
* [8/6/2018 1:19:53 PM] : Detecting dependent assembly Infragistics4.Win.UltraWinGrid.v18.1, Version=18.1.20181.88, Culture=neutral, PublicKeyToken=7DD5C3163F2CD0CB, processorArchitecture=msil using Infragistics4.Win.UltraWinGrid.v18.1, Version=18.1.20181.88, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb, processorArchitecture=msil.
* [8/6/2018 1:19:53 PM] : Request of trust and detection of platform is complete.
ERROR DETAILS
Following errors were detected during this operation.
* [8/6/2018 1:19:54 PM] System.ArgumentException
– Value does not fall within the expected range.
– Source: System.Deployment
– Stack trace:
at System.Deployment.Internal.Isolation.IStore.LockApplicationPath(UInt32 Flags, IDefinitionAppId ApId, IntPtr& Cookie)
at System.Deployment.Application.ComponentStore.LockApplicationPath(DefinitionAppId definitionAppId)
at System.Deployment.Application.SubscriptionStore.LockApplicationPath(DefinitionAppId definitionAppId)
at System.Deployment.Application.FileDownloader.PatchFiles(SubscriptionState subState)
at System.Deployment.Application.FileDownloader.Download(SubscriptionState subState, X509Certificate2 clientCertificate)
at System.Deployment.Application.DownloadManager.DownloadDependencies(SubscriptionState subState, AssemblyManifest deployManifest, AssemblyManifest appManifest, Uri sourceUriBase, String targetDirectory, String group, IDownloadNotification notification, DownloadOptions options)
at System.Deployment.Application.ApplicationActivator.DownloadApplication(SubscriptionState subState, ActivationDescription actDesc, Int64 transactionId, TempDirectory& downloadTemp)
at System.Deployment.Application.ApplicationActivator.InstallApplication(SubscriptionState& subState, ActivationDescription actDesc)
at System.Deployment.Application.ApplicationActivator.ConsumeUpdatedDeployment(SubscriptionState& subState, ActivationDescription actDesc)
at System.Deployment.Application.ApplicationActivator.PerformDeploymentUpdate(SubscriptionState& subState, String& errorPageUrl)
at System.Deployment.Application.ApplicationActivator.ProcessOrFollowShortcut(String shortcutFile, String& errorPageUrl, TempFile& deployFile)
at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl, Uri& deploymentUri)
at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivationWithRetry(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl)
— End of stack trace from previous location where exception was thrown —
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker(Object state)
COMPONENT STORE TRANSACTION DETAILS
No transaction information is available.
    Divya Jain
    Divya Jain answered on Aug 7, 2018 6:21 PM
    Thank you for posting to our forum.
    You had a duplicate case CAS-197315-Q9Q6K8, through which you informed that the issue was with your custom DLL that contained older version of Infragistics controls.
    When you upgraded the custom DLL and rebuild the solution, everything is working as expected.
    I am glad you found your solution working, please let me know if you still need further assistance on this matter.
Rapid Apps
8 years, 3 months ago
Aug 7, 2018 6:21 PM
Feb 12, 2026 4:02 PM
