Ultimate UI for WPF
New DiscussionXamPivotGrid FlatDataSource Sorting Rows and Columns ✓ Answered
I have a dataSource with ProjectData and I created a FlatDataSource with the following code: dataSo…
XamTreeGrid: customize dimmed ancestor/descendant opacity ✓ Answered
We are using XamTreeGrid in a WPF application targeting .NET 10, with the RoyalLight theme. <igD…
XamDatagrid: make column visible – header creates second row
Hi, in a XamDatagrid I allow the user to make columns visible or hide them. The first image shows t…
XamCheckBox Editor in XamDataGrid toggling when clicking anywhere in cell
Hello. I am using a XamCheckEditor as a field in a XamDataGrid. The current (what I assume to be de…
List inside XamDatagrid with Drag&Drop support
Hello, I have a XamDatagrid and implemented the Drag& Drop between cells so far. Now I need to …
WPF Excel Engine: Adding line chart currupts excel File
Hi all, i am working on a WPF application, which also uses the WPF Excel Engine.. I am using the l…
IgRibbon Toggle Button background style on IsChecked
I want to keep Background of toggle button transparent on style trigger “Is checked = true…
