Hi Scott,
If you assign a new DataSource to the grid, or your DataSource sends a Reset notification, then the grid has no choice by to throw away all of the rows and re-bind to the new DataSource. There is no way for the grid to match up the old rows with the new rows in the data source.
So, in general, the best thing to do is – don't do that. If you can achieve what you need by changing the existing data source instead of Resetting or creating a new one, that's generally the best way to go.
If that's not an option for you, then there are a number of issues you will need to deal with in order to save and restore the state of the grid.
First, you will want to store the ActiveRow/Cell. It seems that you are already on your way down this path, storing the Index of the active row. But that might not be reliable. Can you assume that the active row will always be in the same position? Is is possible that the new DataSource you are using will have other rows before the active row? Or that some of the rows above the active row will not be there? If so, the index of the row will have changed. In fact… can you even be certain that the ActiveRow still exists in the new data source at all?
If you can make those assumptions, then it once again begs the question of why you are resetting your data source. But it also means that you can use the index of the row and that will be reliable. If not, then you would be better off storing some better information about the row in order to identify it – like the Primary Key, for example. If you do that, then when you go to restore the grid's state, you would have to loop through the rows in order to find the matching row. This is a better approach in a lot of ways, because it's more reliable and you could handle the case where the row no longer exists.
Once you get over that hurdle, I think you probably want to activate the cell (like you are doing) and then use grid.PerformAction(EnterEditMode) to put the cell into edit mode, rather than selecting it.
The next issue is the grid's scroll position. Activating the row will bring it into view, but the row could be anywhere within the visible area, so it's unlikely that it will end up in exactly the same scroll position. Here again, we run into the same sort've problem – if the data source has changed, it may not be possible to scroll to the same position. If there have been any additions or deletions above the active row, then scrolling to the same position might not be possible. But if the rows are the same, then you can store the first visible row and then restore it just as you do with the ActiveRow. Again, you will want to use some primary key information to identify the row. The only difference in this case is that you will use grid.ActiveRowScrollRegion.FirstRow instead of grid.ActiveRow.
Finally, there's likely to be some flickering while you reset the data source, scroll the grid, and re-enter edit mode on the cell. But you can minimize this by surrounding the code with BeginUpdate and EndUpdate to prevent the grid from painting.
So the basic process would look something like this:
grid.BeginUpdate();
try
// store the primary key or some other unique identifier for the FristRow
// store the primary key or some other unique identifier for the ActiveRow
// Reset the grid's DataSource
// Restore the FirstRow
// Restore the ActiveRow and put the grid into edit mode. Actually… I'm not entirely sure that you will be able to EnterEditMode inside a BeginUpdate/EndUpdate block. You might have to call PerformAction AFTER the EndUpdate.
finally
grid.EndUpdate();
