Data Grid cell tabindex
Steve Hildebrand
Steve Hildebrand asked on Apr 14, 2020 9:46 AM
Is there a way to skip over cells that are not editable?  I was thinking tabindex might achieve this, but haven’t been able to get it to work.
I’ve tried the following, but when I look in inspector, it still has a tabindex of 0.
<igx-column field=”invoiceDate” header=”Invoice Date” dataType=”date”>
<ng-template igxCell let-cell=”cell” let-value>
<span tabIndex=”-1″></span>{{ value | date: “MM/dd/yy” }}</span>
</ng-template>
</igx-column>
    Martin Asenov
    Martin Asenov answered on Apr 10, 2020 2:19 PM
    I have created and attached a small sample demonstrating how to skip cells that are not editable using igxGrid's onGridKeydown event. Please test this sample on your side and let me know whether it resolves your issue.
    Additionally, this thread in our GitHub repository could be of help to you.
    4341.Sample.zip
      Steve Hildebrand
      Steve Hildebrand answered on Apr 10, 2020 5:45 PM
      Hi Martin, thanks for the sample.  It worked perfectly.  I did make a few changes to capture arrow right/left.  I don't suppose there's a way to capture tab left?
      customKeydown(e) {
      if (
      e.targetType === "dataCell" &&
      (e.event.key.toLowerCase() === "tab" ||
      e.event.key.toLowerCase() === "arrowright" ||
      e.event.key.toLowerCase() === "arrowleft")
      e.event.preventDefault();
      e.cancel = true;
      let cellPosition: ICellPosition = null;
      if (
      cellPosition = this.grid.getNextCell(
      e.target.rowIndex,
      e.target.visibleColumnIndex,
      (col) => col.editable
      if (e.event.key.toLowerCase() === "arrowleft") {
      cellPosition = this.grid.getPreviousCell(
      e.target.rowIndex,
      this.grid.navigateTo(
      cellPosition.rowIndex,
      cellPosition.visibleColumnIndex,
      (obj) => obj.target.nativeElement.focus()
        Martin Asenov
        Martin Asenov answered on Apr 13, 2020 12:54 PM
        Hi Steve,
        Indeed there is. You can check if the shift key is pressed during the keyboard event together with the tab key:
        if (e.event.key.toLowerCase() === 'arrowleft' || (e.event.shiftKey && e.event.key.toLowerCase() === 'tab')) {
        		e.target.rowIndex,
        Steve Hildebrand
        Steve Hildebrand answered on Apr 13, 2020 8:55 PM
        Worked perfectly.  Thanks for all of your help!
        Martin Asenov
        Martin Asenov answered on Apr 14, 2020 9:46 AM
Steve Hildebrand
6 years, 7 months ago
Feb 19, 2026 9:21 AM
