Infragistics Community Forum / Web / Ignite UI for jQuery / How to format an integer column without comma in IgGrid?
Dean
Dean asked on Jul 23, 2013 6:37 PM
How can I format an integer column without comma separator?
    [Infragistics] Troy Rodda
    [Infragistics] Troy Rodda answered on Jul 15, 2013 7:53 PM
    Hi Dean,
    This is an initial update to let you know that I have received your inquiry. I will look into this for you and will have an update on or before Thursday.
      [Infragistics] Troy Rodda answered on Jul 18, 2013 7:52 PM
      Hi Dean,
      For this you can use the ‘format’ option which you can set on the colum. The ‘format’ option applies for number datatypes and can be set to format as a’number; currency; percent; int; double, etc. You set it like this:
      columns: [
              { headerText: "Product ID", key: "ProductID", dataType: "number", format: "number" },
              { headerText: "Production Date", key: "ProductionDate", dataType: "date", format: "ddd, MMM-d-yy HH:mm" },
      You can see more on this by referencing tbe API (help.infragistics.com/jQuery/2013.1/ui.iggrid)–> Options -> Columns -> Format
      Let me know if you need any additional assistance.
        Dean
        Dean answered on Jul 18, 2013 8:16 PM
        Hi Troy,
        Your suggested solution does not works.  Here is the link to the image to show the result. sdrv.ms/18nfL7E
        Dean
        [Infragistics] Troy Rodda answered on Jul 23, 2013 4:24 PM
        Hi Dean,
        Yes, I see the issue…
        What you can do use use a column 'formatter' and strip-out the "," comma seperator.
        For example, you can try the following:
        function formatNumber (val) {    if (typeof val !== "number" || isNaN(val)) {        return "Not set";    }    return "$" + val.toString().replace(/\,/g,'');
           …..and then set the formatter in your column settings:
           columns: [ { headerText: "Number", key: "Number", formatter: formatNumber} ]
        This should do the trick to strip out the comma from the integer column. Let me know if you need any additional assistance.
        Thanks!
        Dean
        Dean answered on Jul 23, 2013 5:49 PM
        Formatter approach does not work either. The val variable is a number type so there is no comma to strip even if you toString the value.
        sdrv.ms/12zjR8i
        Dean
        Dean answered on Jul 23, 2013 6:33 PM
        I found a solution. Just remove dataType and format.
        { headerText: 'Id', key: 'ID', width:'50px' }
        [Infragistics] Troy Rodda answered on Jul 23, 2013 6:37 PM
        Hi drchip,
        I am pleased to see that you found a solution.  Let us know if you need any additional assistance!
        Thanks!
Dean
13 years, 4 months ago
Feb 11, 2026 2:19 PM
