Infragistics Community Forum / Desktop / Ultimate UI for Windows Forms / How to Loop through UltraGrid Columns by Display Order
Brian Gerdes
Brian Gerdes asked on Jan 28, 2016 4:23 PM
Is it possible to loop through the columns of the UltraGrid in display order.  Say a user manually moves one of the columns.  I would like to be able to loop through the columns in that new order.
      Sahaja Kokkalagadda
      Sahaja Kokkalagadda answered on Jan 28, 2016 4:10 PM
      Hi Brain,
       I’m glad you resolved your issue, I was going to share you the below link which pretty much did the same thing.
      http://help.infragistics.com/Help/Doc/WinForms/2012.1/CLR2.0/HTML/Infragistics2.Win.UltraWinGrid.v12.1~Infragistics.Win.UltraWinGrid.UltraGridColumn~GetRelatedVisibleColumn.html
      Please let me know if you have any other questions.
      Sahaja Kokkalagadda
      Associate Software Developer, Windows Forms
      http://www.infragistics.com/
        Mike Saltzman answered on Jan 28, 2016 4:23 PM
        Both of the links here related to getting a related visible column from an existing column. But the StackOverflow article makes the assumption that Columns[0] is the first visible column, which is not always true. You should use the GetFirstVisibleColumn method on the band to get the first column. And then use GetRelatedVisibleColumn after that.
Brian Gerdes
10 years, 9 months ago
Feb 24, 2026 2:20 AM
