Setting Active Tab on Page load
Rob
Rob asked on Jul 26, 2011 7:38 PM
I have a Set of tabs(5 total), each tab has a listview on it.  Control works fine when switching tabs and loading data.  The problem arrises when I try to change the selected tab when the user first request the page and has a value in the request url.  Example MYPage.aspx?t=3, so the page defaults to tab 3 instead of the first tab.  The error the pops up is the listview on the tab doesn’t exist
The error I get says it can’t find the listview control on the page…
Error Message
IPageableItemContainer ‘listview3’ not found.
Description: An unhandled exception occurred during the execution of the current web request.  Exception Details: System.InvalidOperationException: IPageableItemContainer ‘listview3’ not found.
Sample Code in page_init
If Not Request.Item(“t”) Is Nothing Then
If IsNumeric(Request.Item(“t”)) Then
WebTab1.SelectedIndex = CInt(Request.Item(“t”))
End If
Else
WebTab1.SelectedIndex = 0
End If
Strip down sample of webtab, I have removed the tabs/control in tab since the code is huge.
HTML/Control
<ig:WebTab ID=”WebTab1″ runat=”server” Height=”550px” Width=”100%” onselectedindexchanged=”WebTab1_SelectedIndexChanged” StyleSetName=”Default”>
<tabs>
</tabs>
<PostBackOptions EnableLoadOnDemandUrl=”true” EnableLoadOnDemand=”true” EnableReloadingUnselectedTab=”true” EnableAjax =”true”/>
<AutoPostBackFlags SelectedIndexChanged =”On”/>
</ig:WebTab>
I am hoping I am just setting the active tab wrong, or at the wrong time, or there is something else I am missing.
    [Infragistics] Deni Vangjeli
    [Infragistics] Deni Vangjeli answered on Jun 3, 2011 3:04 PM
    Hi Rob,
    As far as I understand, this might be a problem with the page life cycle in which the WebTab resides. Your sample code in page_init I think should be implemented during page load and not during its initialization when the controls are loaded.
    If you are working in C#, you can try this in the Target page's behind code:
                string s = Request.QueryString["t"];
                if (s != null)
                    WebTab1.SelectedIndex = int.Parse(s);
                else
                    WebTab1.SelectedIndex = 0;
    Regards
      Rob
      Rob answered on Jun 8, 2011 1:59 PM
      Moved the logic to Page_Load but getting the same error.
        If Not Page.IsPostBack Then
         'First Load
         If Not Request.Item("t") Is Nothing Then
          If IsNumeric(Request.Item("t")) Then
           WebTab1.SelectedIndex = CInt(Request.Item("t"))
          End If
         Else
         End If
        Else
         'Post Back
        End If
       End Sub
        Rob
        Rob answered on Jul 26, 2011 7:38 PM
        Hopefully the following info will help someone else.  I was finally able to determine why I couldn't set the SelectedIndex on pageload.  It's definitely a Infragistics bug, but at least I figure it out and found a way around it.
        The Problem… a review
        On each of the tabs I had there was a just a listview control, whenever I tried to specify the tab it would say it couldn't find this control "IPageableItemContainer 'listview' not found"  and the page would bomb.
        Work Around … the real problem
        I figured out it wasn't the listview, it was the datapager above the listview.  The datapager refers to the listview, but apparently something it not loading properly when I set the selectedindex server side.  If I remove the pager or move the pager to be only under the listview the selectedindex setting works.  Its not a perfect fix since I always have my paging at the top and bottom of listviews but at least there is a work around.
        Hopefully someone from Infragistics can reproduce this problem now that I have more info and can fix it.
        <asp:DataPager ID="datapageernamehere" runat="server" PagedControlID="listviewnamehere" PageSize="20">
                   <Fields>
                    <asp:NumericPagerField ButtonType="Link" />
                   </Fields>
                  </asp:DataPager>
Rob
15 years, 3 months ago
Rob
Feb 23, 2026 1:10 PM
