Infragistics Community Forum / Web / Ignite UI for Angular / Make tab active at run time
Amit Kohli
Amit Kohli asked on Jul 22, 2019 12:50 PM
Below is the HTML setup for the tab component with a template reference variable #notes assigned to one of the tabs.
In the ngOnInit – for certain route parameters, would like to make one of the non-first tabs the active one e.g. –
ngOnInit() {
// debugger;
this.notes.select();
// this.notes.isSelected = true;
There is only one router-outlet for the application
<!– operational\components\analyzer\analyzer.component.html –>
<div class=”layout-box-container”>
<div class=”layout-box-top” igxLayout igxLayoutDir=”row”>
<span><a [routerLink]=”””>Operational</a></span>
<span class=”atitle”>Analyzer Diagnostics</span>
</div><!– /.layout-box-top –>
<div class=”tabs” igxLayout igxLayoutDir=”row” igxLayoutJustify=”space-between”>
<igx-tabs style=”width: 100%”>
<igx-tabs-group label=”STREAM” name=”stream”>
<stream></stream>
</igx-tabs-group>
<igx-tabs-group label=”NOTES” name=”notes” #notes>
<notes></notes>
</igx-tabs-group>
</igx-tabs>
</div><!– /.tabs –>
</div><!– /.layout-box-container –>
Thanks and regards,
Amit Kohli
    Nadia Robakova
    Nadia Robakova answered on Jul 22, 2019 10:56 AM
    Hi Amit,
    If you want to set selected tan on ngOnInit you can use the selectedIndex input of the tab component.
    Here is a sample with this.
      Amit Kohli
      Amit Kohli answered on Jul 22, 2019 12:50 PM
      That worked thank you.
      Amit
Amit Kohli
7 years, 3 months ago
Feb 12, 2026 4:09 PM
