Hi Hristo,
Thank you for your helpful reply. Finally, I am able to bind the data to the grid and display it in browser.
One suggestion, I am not sure whether this is documented anywhere, but this issue is likely to be missed. You guys should also focus on increasing the samples to cover such scenarios.
I am able to export the grid as well now, but still there are few issues:
1) I export the grid successfully, but without doing any postback, if I try to export it again, I export starts, but I get the error message: Export Failed, No file.
2) When I try to export Hierarchical grid, I get the error message: Uncaught TypeError: Cannot read property 'length' of undefined
I am using the below code:
$.ig.GridExcelExporter.exportGrid($("#grid11"));
