Hi Mike,
Fresh entry means when i save a record in the form , system does not throw any error and i can see all the data in combo boxes. when i close and open the form and select the record which entered, then this error appears.
akram
Hi Mike,
Last piece of code refers to "SearchOnUserCodesAdapterShowDialog("RunningNum",cbxRunningNum);" line.
when i re load the form the data in the combo boxes (field ) does not appear.
When i create a fresh entry everything is normal, data appears in the combo boxes. when i re load the form with same projectid , data in combo boxes does not appear. so wrote below code. When i comment "SearchOnUserCodesAdapterShowDialog("RunningNum",cbxRunningNum);" error does not appear. for "SearchOnUserCodesAdapterShowDialog("DepIdent",cbxDepart);" data apears after form reload also.
private void edvProject_EpiViewNotification(EpiDataView view, EpiNotifyArgs args)
if ((args.Row > -1))
if (dept_selected == false)
akram
Hi mike,
This code has no issues until i add the last piece of code . when i re load the form my combo boxes does not appear , i wrote the below code to see the data in combo boxes, the first line of code is fine (SearchOnUserCodesAdapterShowDialog("DepIdent",cbxDepart);), there is no error upto this point, where as when write the next line (SearchOnUserCodesAdapterShowDialog("RunningNum",cbxRunningNum);) error comes here.
This is the actual method..
private void SearchOnUserCodesAdapterShowDialog(string TypeID,Epicor.Mfg.UI.FrameWork.EpiUltraCombo Ctr)
UserCodesAdapter UserCodesAdapter = new UserCodesAdapter(oTrans);
UserCodesAdapter.BOConnect();
bool avail = UserCodesAdapter.GetByID(TypeID);
if(avail)
Ctr.ValueMember = "CodeID";
if(TypeID == "RunningNum")
Ctr.ValueMember = "CodeDesc";
string str1 ="";
DataRow row = this.edvProject.CurrentDataRow;
if(row!=null)
str1= row["ShortChar01"].ToString();
Ctr.DataSource = UserCodesAdapter.UserCodesData.UDCodes.Select("CodeID = '" + str1 + "'");
if(((DataRow[])Ctr.DataSource).Length>0)
((DataRow[])Ctr.DataSource)[0]["CodeDesc"] = Convert.ToDouble(((DataRow[])Ctr.DataSource)[0]["CodeDesc"]) + 1;
else if(TypeID =="DepIdent")
string str ="";
if(row!=null)
str= row["ShortChar01"].ToString();
Ctr.DataSource = UserCodesAdapter.UserCodesData.UDCodes.Select("Character01 = '" + str + "'");
else
Ctr.DataSource = UserCodesAdapter.UserCodesData.UDCodes;
Ctr.DisplayMember = "CodeDesc";
string[] fields = new string[] {"CodeDesc"};
Ctr.SetColumnFilter(fields);
UserCodesAdapter.Dispose();
please suggest .
Akram
Hi mike,
The data types of the fields are char only but i am populating a number field in the char field and converting to double +1; my application provides standard char fields only, that i why i am converting to double and adding.
Hope you understand..
regards,
akram
Hi ,
Adding to that in my case the data value and display member both are number only , i want to display number itself.How could i acheive this.
akram
Could you please help me with the code. What to replace this code with ,
((DataRow[])Ctr.DataSource)[0]["CodeDesc"] = Convert.ToDouble(((DataRow[])Ctr.DataSource)[0]["CodeDesc"]) + 1.
akram
