Hi
I already set the 'GridReports.UseAppStyling = False' in order to be able to change the color set of the grid.
The idea, should be not to reset the appearance, but to show the Grid without any highlighted row. It is like when you open an excel file: you don't see any row selected until you click on the screen
Maybe this is not how Infrgistics is working in this way (one line is always highlighted). Pls, let me know in case I'm wrong
The only solution I found to "clear" definetively the grid is the following
GridReports.DisplayLayout.Override.ActiveRowAppearance.BackColor = Color.Transparent
GridReports.Refresh()
I noticed that you need to refreshm in order to apply the changes
Alberto
