I do not know why grid row height is increasing, but I am able to get fixed headers, and number of rows are large in my requirement, so i am continuing with it
I am also not able to reproduce this issue
The whole structure is as follow-
<div class="container-fluid">
<div class="row">
<div style="height:25px;">
<!– Contentr of this div, contains a date picker, a button>
</div>
<div class="dataDiv">
<div id="chartCotainer" style="height:47%;width:99%;">
<div id="chart" style="float:left;min-width: 400px; width:100%;margin-left: 20px auto"></div>
</div>
<div style="height:53%; overflow:none;">
<div id = "gridContainer" style="width:67%;height:100%;float:left;"> <!– I want grid to be in 67% of width –>
<table id="hierarchicalGrid"></table>
</div>
<div id="childChart" style="float:left;overflow:auto;width:33%;padding-left:10px;padding-right:10px"></div>
</div>
</div>
</div>
<div>
function setHeight(){
//Called when my javascript is loaded
var p = $( "body" );
$(".row").width(p.outerWidth()-15).height(p.innerHeight()-125);// I have 125px height banner, so assigning remaining to my row
$(".dataDiv").height($(".row").height()-25);// row – height of first div that contains datepicker and button
function getHeight(){
return $("#gridContainer").height();//It should return height of grid container which is 53% dataDiv
I do not know what the issue is, but this is what happening, 2 rows are adjusting their heights to take all the height of grid
I am not using virtualzation. What is happening is suppose i gave grid height of 300px, and there are 3 rows in it, then all the rows are getting 100px height to cover all the available height of grid. I am not able to upload the pic
I tried the same with the sample in Fiddle, there it is working fine, may be this is the issue with version I am using 2013.1, and 'ighierarchicalGrid' with load on demand (initial data-bind =0), and auto-generated columns are false
This is my configuration:
var jsonData = new $.ig.JSONPDataSource({
dataSource: "myUrl",
type: "remoteUrl"
var configs={
width: "100%",
initialDataBindDepth: 0,
dataSource: jsonData,//the URL
autoGenerateColumns:false,
key:"myDate",
primaryKey:"id",
height:getHeight(),
rowExpanding : function(e, ui) {
//collapse other rows
var grid = ui.owner, expandedRows, i;
expandedRows = $(ui.parentrow).closest('tbody').find('tr[state=e]');
for (i = 0; i < expandedRows.length; i++){
grid.collapse(expandedRows[i]);
rowExpanded: function(e,ui){
//do something
columns:getDefaultColumns(),
columnLayouts:=getColumnLayouts(0,configs,levels-1)
function getColumnLayouts(i,configs,levels){
var layouts=[];
var layout1={};
layout1["autoGenerateColumns"]= false;
layout1["primaryKey"]='id';
layout1["key"]=getKey(configs,i),
layout1["columns"]=getColumns(configs,i);
if(i<levels){
layout1["columnLayouts"]=getColumnLayouts(++i,configs,levels);
layouts.push(layout1);
return layouts;
