Hello – I am trying to get this to work for the cell editing, and I cannot get it to function. I have verified that the handler I assigned for event editCellStarting does get fired, and it does return false. I have used the debugger in Chrome to verify this. But it still allows the edit box to appear and be able to change the values in the grid. I am using Cell Edit model with MVC. Any thoughts on why the editing would still proceed?
In Controller (MVC)
GridUpdating updating = new GridUpdating();
//Add client event that gets fired after call updated ended. This will allow to enable the save button to function
updating.ClientEvents.Add("editCellStarting", "HandleGridCellUpdatedStart(evt,ui);");
//Javascript
function HandleGridCellUpdatedStart(evt, ui)
//Purpoe: This gets called when Infragistics grid is starting to get updated
// alert('starting to update a cell');
if ((ui.rowAdding == false) && (ui.columnKey == "PartnerName"))
//if not adding a row and the partner Name is trying to be updated, return right away
return false;
