Baba Goud Gadiga
Baba Goud Gadiga answered on Jan 31, 2022 6:07 PM
Thank you Michael.
Baba
Baba Goud Gadiga
Baba Goud Gadiga answered on Jan 31, 2022 5:39 PM
Hi Michael,
I am was looking for something out of the box Datagrid which supports adding/deleting a row from the UI. And yes I already have code which are ObeservableCollections which add/remove values from my entity types.
If you look at the Syncfusion Datagrid they support this feature quite well. Are you guys planning to add this feature in future release of Datagrid?
Baba
Baba Goud Gadiga
Baba Goud Gadiga answered on Oct 2, 2018 7:35 PM
Thank you Divya.
The above logic does not work for my scenario. I was able to achieve my need using a different workaround.  Added another panel to the status bar control and set its style to Control container. This panel holds the ActivityIndicator control which shows the progress of my long running process.
Baba Goud Gadiga
Baba Goud Gadiga answered on Oct 2, 2018 3:31 PM
Thank you Mike.
This is what exactly I was looking at. Maybe I could not put my question in proper words, but you got my problem [emoticon:c4563cd7d5574777a71c318021cbbcc8]
Thank you for providing me a sample code as well, below is the code more or less I was looking for.
for (int i = 0; i <= 265; i++)
double percentageD = ((double)i / (double)265) * 100;
int percentage = (int)percentageD;
progressBarPanel1.ProgressBarInfo.Value = percentage;
this.ultraStatusBar1.Refresh();
A quick question though, when I set the ShowLabel property of the ProgressBarInfo to false, is there a way for me to  still show the progress without displaying any value/percentage of the process running? something like a UltraProgressBar control does?
Baba Goud Gadiga
Baba Goud Gadiga answered on Sep 28, 2018 7:31 PM
Thank you Divya.
Setting the maximum value to 265 will surely increment the ProgressBarInfo value, but I do not want the user to see that the loop runs for 265 times. The value should be displayed between 1-100  when though the loop runs for 265 times. Its like process running and the user wants to see how much % of processing is left.
