UltraGrid provide 2 mode when click Header: Sort or Select Column
In order to disable Sor, set property HeaderClickAction = Select.
Ex: UltraWinGrid.DisplayLayout.Override.HeaderClickAction = Select
If you dont want to Select column after set HeaderClickAction = Select, set property:
UltraWinGrid.DisplayLayout.Override.SelectTypeCol = None
Goodluck
