thank you very much for your helper
here is my code from your sample code
$(function () {
$("#grid").igGrid({
columns: [
{ headerText: "ID", key: "ProductID", dataType: "number", width:"50px" },
{ headerText: "Product Name", key: "Name", dataType: "string", width:"200px", hidden: false },
{ headerText: "Make Flag", key: "MakeFlag", dataType: "bool", width:"80px" },
{ headerText: "Sell Start Date", key: "SellStartDate", dataType: "date", width:"350px" },
{ headerText: "Price", key: "ListPrice", dataType: "number", width:"100px" },
autoGenerateColumns: false,
autofitLastColumn : true,
autoCommit:true,
dataSource: adventureWorks ,
width: "1000px",
height: "600px",
primaryKey: "ProductID",
features: [
editRowEnding: function(evt, ui){
$.ajax({
url: "http://www.igniteui.com/data-files/adventureworks.min.js",
}).done(function(data) {
ui.values["Name"] = "NEW VALUE";
the cell was not changed after the ajax request was completed
if i used the setcellvalue method then it works ok. but when i hide that column. it threw error "The specified record or property was not found. Verify the criteria for your search and adjust them if necessary."
can you give me some solution to resolve this problem?
thanks you very much!
hello
because i have an ajax function within the event. so after the ajax function completed. i set value for coulmn. it throws that error
i use 14.1 version
thanks for help,
i use Unbound column and .formula function, it done!!
thanks you so much!!
thanks for helps,
if i use 'FormatterFunction', how can i get other column of gridview??
because it recieve 1 parameter
please!
it not working
my code:
<div>
<h4>Pending Buy Transactions</h4>
@(Html.Infragistics() _
.Grid(Of TPG.WebPortfolio.Models.sp_webGetPortfolioOpens_Results)() _
.ID(“grdPortfolioOpen” + item.oPortfolio.ctintCustomerSetupID.ToString()) _
.Width(“100%”) _
.AutoGenerateColumns(False) _
.AutoGenerateLayouts(False) _
.RenderCheckboxes(True) _
.Columns(Sub(column)
column.For(Function(x) x.TransNo).Width(80).HeaderText(“Transaction ID”)
column.For(Function(x) x.CusipID).HeaderText(“CUSIP”).Template(“<a href=’#’ onclick=’openCusipDetail(“”${CusipID}””, 0, “”${PortfolioID}””)’>${CusipID}</a>”).Width(70)
column.For(Function(x) x.BuyAmount).HeaderText(“Original Face”).DataType(“number”).Format(“#,##0.00”)
column.For(Function(x) x.BuyPrice).HeaderText(“Price”).DataType(“number”).Format(“#,##0.00”)
column.For(Function(x) x.SettlementDate).HeaderText(“Settlement”).DataType(“date”).Format(“MM/dd/yyyy”)
column.For(Function(x) x.TradeDate).HeaderText(“Trade Date”).DataType(“date”).Format(“MM/dd/yyyy”)
column.For(Function(x) x.fsstrDescription).HeaderText(“FAS 115”)
column.For(Function(x) x.amstrDescription).HeaderText(“Accounting Method”)
column.For(Function(x) x.ParValue).HeaderText(“Par Value”).DataType(“number”).Format(“#,##0.00”)
column.For(Function(x) x.Principal).HeaderText(“Principal”).DataType(“number”).Format(“#,##0.00”)
column.For(Function(x) x.Interest).HeaderText(“Interest”).DataType(“number”).Format(“#,##0.00”)
column.For(Function(x) x.NetCostsOrProceeds).HeaderText(“Net Costs Or Proceeds”).DataType(“number”).Format(“#,##0.00”)
column.For(Function(x) x.CreatedUser).HeaderText(“Created By”)
column.For(Function(x) x.CreatedDate).HeaderText(“Date Created”).DataType(“date”).Format(“MM/dd/yyyy”)
column.For(Function(x) x.Actions).HeaderText(“Actions”).width(100).Formatter(“CheckPermission”)
column.For(Function(x) x.PortfolioID).hidden(True)
End Sub) _
.Features(Sub(features)
features.Paging().PageSize(10)
End Sub) _
.DataSource(item.oPortfolioOpen) _
.DataBind() _
.Render()
$(function () {
var strName = “#grdPortfolioOpen” + @item.oPortfolio.ctintCustomerSetupID.ToString();
$(document).delegate(strName, ‘@(“iggrid” & Infragistics.Web.Mvc.GridClientEvents.HeaderCellRendered.ToLower())’, function (evt, ui) {
$(ui.th).css(“text-align”, “center”);
$(ui.th).css(“text-decoration”, “underline”);
$(document).delegate(strName, ‘@(“iggrid” & Infragistics.Web.Mvc.GridClientEvents.DataRendered.ToLower())’, function (evt, ui) {
ui.owner.element.find(“tr td:nth-child(1)”).css(“text-align”, “left”);
ui.owner.element.find(“tr td:nth-child(2)”).css(“text-align”, “left”);
ui.owner.element.find(“tr td:nth-child(3)”).css(“text-align”, “right”);
ui.owner.element.find(“tr td:nth-child(4)”).css(“text-align”, “right”);
ui.owner.element.find(“tr td:nth-child(5)”).css(“text-align”, “right”);
ui.owner.element.find(“tr td:nth-child(6)”).css(“text-align”, “right”);
ui.owner.element.find(“tr td:nth-child(7)”).css(“text-align”, “left”);
ui.owner.element.find(“tr td:nth-child(8)”).css(“text-align”, “left”);
ui.owner.element.find(“tr td:nth-child(9)”).css(“text-align”, “right”);
ui.owner.element.find(“tr td:nth-child(10)”).css(“text-align”, “right”);
ui.owner.element.find(“tr td:nth-child(11)”).css(“text-align”, “right”);
ui.owner.element.find(“tr td:nth-child(12)”).css(“text-align”, “right”);
ui.owner.element.find(“tr td:nth-child(13)”).css(“text-align”, “left”);
ui.owner.element.find(“tr td:nth-child(14)”).css(“text-align”, “left”);
ui.owner.element.find(“tr td:nth-child(15)”).css(“text-align”, “center”);
ui.owner.element.find(“tr td:nth-child(2)”).css(“text-decoration”, “underline”);
ui.owner.element.find(“tr td:nth-child(15)”).css(“text-decoration”, “underline”);
function CheckAction(value, row){
return row[“CusipID”];
</script>
</div>
my error
Description: An error occurred during the compilation of a resource required to service this request. Please review the following specific error details and modify your source code appropriately.
Compiler Error Message: BC30456: ‘Formatter’ is not a member of ‘Infragistics.Web.Mvc.GridColumnWrapper(Of TPG.WebPortfolio.Models.sp_webGetPortfolioOpens_Results)’.
Source Error:
Line 244: column.For(Function(x) x.CreatedUser).HeaderText("Created By")
Line 245: column.For(Function(x) x.CreatedDate).HeaderText("Date Created").DataType("date").Format("MM/dd/yyyy")
Line 246: column.For(Function(x) x.Actions).HeaderText("Actions").width(100).Formatter("CheckPermission")
Line 247: column.For(Function(x) x.PortfolioID).hidden(True)
Line 248: End Sub) _
my data worked fine, but the grid is not working
can you help me!!
i want to call function from column of gridview to handle process value of column, i am used to FormatterFunction but it can be only 1 paremater, i want to get other column of gridview
my code:
column.For(Function(x) x.Actions).HeaderText("Actions").width(100).Formula("CheckAction")
function CheckAction(data,grid){
return data["CusipID"];
it not work
