Danko Valkov
Danko Valkov answered on Apr 9, 2012 9:49 AM
Hello Locp,
Here the message meaning is different than the one reported in the first post of this forum thread. Most probably here the issue is with the version of the NetAdvantage controls that are being used in your application under test.
When you are performing tests with TestAdvantage 2011 vol.1 against applications built with NetAdvantage controls, than the version should match. In other words, the application being tested should use NetAdvantage for Windows Forms 2011 vol 1 as well.
For more information about this please take a look at the following link from our online documentation:
http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.Aspx?ArticleID=10045
If you have any other questions with this matter please feel free to let us know.
Danko Valkov
Danko Valkov answered on Apr 9, 2012 9:38 AM
Hello Sanshy99,
I have been looking into this forum thread, and it seems to me that your Application under test throws this message. It might be because of the following matters:
1. Please first clear the Infragistics content from the Licenses.licx folder of the application.
2. Make sure that the "Specific Version" of the Infragistics assemblies has been set to False.
3. Clean and rebuild your application.
4. Also it is important that the assemblies in the application are installed locally on that machine or they are being referred from a specific folder.
Once you perform the mentioned steps, run the application one more time and try to perform the desired  operations in the script.
If you have any other questions please feel free to let us know.
Danko Valkov
Danko Valkov answered on Mar 28, 2012 7:44 AM
Hello Edmac,
If you believe that this might be connected with the registry entries in your machine, you could take a look at the following forum thread where the registry keys created after an installation are mentioned:
http://community.infragistics.com/forums/p/52530/340148.aspx#340148
Danko Valkov
Danko Valkov answered on Mar 23, 2012 3:43 PM
Hello jschramm,
I have been looking into this forum thread, and what I could suggest here is taking a look at the following link from our web site, describing what are the currently supported environments for each platform:
http://www.infragistics.com/support/supported-environments.aspx#SupportedEnvironments
Please feel free to let us know if you have any other questions.
Danko Valkov
Danko Valkov answered on Mar 23, 2012 10:10 AM
Hello Caroline Lapointe,
Thank you for your detailed feedback.
I am glad that we were able to assist you with this matter.
If you have any questions in the future please feel free to let us know.
Danko Valkov
Danko Valkov answered on Mar 22, 2012 3:35 PM
I have been looking into your forum thread, and there is a similar forum thread discussing the installation of Data and Calendar Widgets, whcih might be helpful for you:
http://forums.infragistics.com/forums/p/52530/320151.aspx
Also please take a look at our supported environments page in order to verify what are the currently supported environments at:
