Milko,
I was able to successfully install after I made the following changes on the Windows 7 machine that I have been using.
— I added a registry key to allow msi file to be run as Administrator (https://www.howtogeek.com/178826/how-to-force-an-msi-package-to-install-using-administrator-mode/).
— Overcame the following error: Infragistics Error – "Could Not Access Network Location %SystemDrive%\inetpub\wwwroot\" by following the instructions at this URL (http://ayanigamage.blogspot.com/2011/04/infragistics-error-could-not-access.html).
So all seems to be working! Thank you for your great support!
As an update, I was able to log onto the Infragistics site and access my account. My account has the product keys and the ability to download the software. I was able to download NetAdvantage for Windows Forms 2006 Vol.3 [.NET 2.0]. When I attempted the install from the newly downloaded file and associated product key, I received the invalid CD-Key message again.
Alan,
I did restart the computer and received the same error message, which I noticed is not visible–I pasted in a screenshot. The error message is just telling me that I have entered an invalid CD-Key. The msg says "The Infragistics NetAdvantage for .NET 2006 Vol. 3 CLS 2.0 CD-Key you have entered is not valid."
I have "NetAdvantage for .NET 2006 Vol 3 Corporate" installation msi. Do I have the correct version that contains “Windows Forms 2006 volume 3” or I still need to request a Back key from sales?
thank you for your help…
Under my Infragistics account, I have the following licenses (see below). I tried to install NetAdvantage_20063_CLR2x_NET.msi using the highlighted key, but I this error. Do I have the correct version that contains “Windows Forms 2006 volume 3” or I still need to request a Back key from sales?
NetAdvantage Select 2009 Vol 1 Corporate
NetAdvantage Select 2008 Vol 3 Corporate
NetAdvantage Select 2008 Vol 2 Corporate
NetAdvantage for .NET 2008 Vol 1 Corporate
NetAdvantage for .NET 2007 Vol 3 Corporate
NetAdvantage for .NET 2007 Vol 2 Corporate
NetAdvantage for WPF 2007 Vol 1 Corporate
NetAdvantage for .NET 2007 Vol 1 Corporate
NetAdvantage for .NET 2006 Vol 2 Corporate
NetAdvantage 2006 Volume 1 Corporate
NetAdvantage 2005 Volume 3 Corporate
NetAdvantage 2005 Volume 2 Corporate
