Gregory Fernander
Gregory Fernander answered on Feb 19, 2013 2:47 PM
I actually figured out after further investigation using your answer by doing the following.
Thanks for your help,
column.Unbound("Download").Formula("testIG");
<script>
function testIG(data,grid)
return data["DocumentId"];
</script>
Gregory Fernander
Gregory Fernander answered on Feb 19, 2013 2:29 PM
Thanks for the response.  This seems to be what I am looking for. I am using the grid in a MVC application.  Can you tell me how this should be written in that scenario?
For instance, I have the following just to test that the javascript function testIG gets called.  But it does not and I am not sure of the correct syntax as I would think it would be correct following the example you provided above.
column.Unbound("Download").HeaderText("Download").Formula("function(data,grid){return testIG(true)}");
