I found an area where small icons are being placed into a grid.
As the form is closed, the grid's datasource is set to nothing and then mygrid.dispose is being called.
This doesn't seem to have fixed the issue. Should we be doing something else to clear out the graphic icons that were used in the grid before removing the datasource and calling dispose?
Thank you!
