Kindly let us know the status of the above issue.
Thanks in advance
I am stuck with the firewall issues and unable to move forward. A quick response/resolution will be of great help.
Thank you
Hello, We are already using EnableAjaxViewState and EnableDataViewState to true for the webdatagrid control.
As suggested by Hristo, we have disabled them and Ediitorproviders were not loaded in the Grid.
By default, ViewState is enabled for all controls and we are not setting the ViewState to false for any of the controls.
Kindly let us know on the below for Directory Traversal Issue.
“../” is not changed even after moving ig_res folder to the directory where the page resides for one particular post variable “res”.
Please find the attached screenshot for reference.
Changes made in the code:
Reflection in Response:
The inference is that “../” in res variable in the response is not for StyleSetPath and is used for some other purpose. Image paths are not shown in the control if the images are within the folder itself.
What is the content that is getting accessed (requiring directory traversal) by this entry in the post value?
And is there a way that this directory traversal can be avoided, by using any relevant property for the control – similar to StyleSetPath property for WebDataTree control?
Thanks in advance
We have managed to get rid of ../ symbols by updating the infragistics.web config section in the Web.config file by providing the absolute path instead of relative path in styleSetPath Except for WebDataTree control
<infragistics.web styleSetName=”Default” styleSetPath=”http://<domainname>/eFACiLiTY_Dev_Latest/ig_res” />
For View State Issue, When setting EnableAjaxViewState and EnableDataViewState properties as false on the Grid, the existing functionalities of Grid such as Editor Providers assigned to columns are not appearing in the Grid. We are binding DataSet to the grid server side.
Please find the attached screenshot for WebDataTree containing ../ in “res” parameter.
Thanks in Advance
For the second issue, the PFA screenshot
../../ Found In : post-parameters Offset : 1022 Dictionary Name
Kindly help us to resolve the issue
