Hi Sahaja,
here are the answers
I am setting the DataSource at runtime
i.e
var cmd =new MySqlCommand("Select * from test"), _systemState.Connection);
var cb = new MySqlCommandBuilder(da);
da.Fill(payerActivityRptDataSet.results);
No Column Style has been aded
only style which is added is
this.resultsGrid.CalcManager = this.ultraCalcManager;
this.resultsGrid.DataMember = "results";
this.resultsGrid.DataSource = this.payerActivityRptDataSetBindingSource;
appearance16.BackColor = System.Drawing.Color.White;
appearance16.BackColor2 = System.Drawing.Color.FromArgb(((int)(((byte)(168)))), ((int)(((byte)(167)))), ((int)(((byte)(191)))));
appearance16.BackGradientStyle = Infragistics.Win.GradientStyle.ForwardDiagonal;
this.resultsGrid.DisplayLayout.Appearance = appearance16;
no layout file has been used
I am still not able figure it out why the group is showing but column is not added and doesn't show and although it shows the additional row column no the extereme left but again with blank values where as it has values
Hi Sahaja,
thanks for getting back but still its not able to do
I had tried all possible ways but still having problem..
let me update here the code behind
how I am binding to Dataset
payerActivityRptDataSet.results.Clear();
var cmd =
new MySqlCommand("CALL get_payeractivity_rpt (@curStartDate, @curEndDate, @prevStartDate, @prevEndDate)", _systemState.Connection);
cmd.Parameters.Clear();
cmd.Parameters.AddWithValue("@curStartDate", startDateTimeEditor.DateTime.Date);
cmd.Parameters.AddWithValue("@curEndDate", endDateTimeEditor.DateTime.Date.AddDays(1));
cmd.Parameters.AddWithValue("@prevStartDate", startDateTimeEditor.DateTime.Date.AddYears(-1));
cmd.Parameters.AddWithValue("@prevEndDate", endDateTimeEditor.DateTime.Date.AddDays(1).AddYears(-1));
var da = new MySqlDataAdapter(cmd);
Here is the Designer.cs
Infragistics.Win.UltraWinGrid.UltraGridColumn ultraGridColumn59 = new Infragistics.Win.UltraWinGrid.UltraGridColumn("Units", -1, null, 956897496, 1, 0);
Infragistics.Win.UltraWinGrid.UltraGridGroup ultraGridGroup15 = new Infragistics.Win.UltraWinGrid.UltraGridGroup("Units", 956897496);
Adding into Band
ultraGridColumn59.Header.Caption = "Units";
ultraGridColumn59.Width = 75;
ultraGridBand1.Columns.AddRange(new object[]
ultraGridColumn1,
ultraGridColumn2,
ultraGridColumn3,
ultraGridColumn4,
ultraGridColumn5,
ultraGridColumn6,
ultraGridColumn7,
ultraGridColumn8,
ultraGridColumn9,
ultraGridColumn10,
ultraGridColumn11,
ultraGridColumn12,
ultraGridColumn13,
ultraGridColumn14,
ultraGridColumn15,
ultraGridColumn16,
ultraGridColumn17,
ultraGridColumn18,
ultraGridColumn19,
ultraGridColumn20,
ultraGridColumn21,
ultraGridColumn22,
ultraGridColumn23,
ultraGridColumn24,
ultraGridColumn25,
ultraGridColumn26,
ultraGridColumn27,
ultraGridColumn57,
ultraGridColumn58, ultraGridColumn59
Adding into Group
ultraGridGroup15.Header.VisiblePosition = 14;
ultraGridGroup15.Key = "Units";
ultraGridBand1.Groups.AddRange(new Infragistics.Win.UltraWinGrid.UltraGridGroup[]
ultraGridGroup1,
ultraGridGroup2,
ultraGridGroup3,
ultraGridGroup4,
ultraGridGroup5,
ultraGridGroup6,
ultraGridGroup7,
ultraGridGroup8,
ultraGridGroup9,
ultraGridGroup10,
ultraGridGroup11,
ultraGridGroup12,
ultraGridGroup13,
ultraGridGroup14, ultraGridGroup15
now doing this it shows the Group but when I get the data its now showing the Units Column
