lily lily
lily lily answered on Oct 16, 2026 4:10 AM
I had the same question when looking for the React Data Grid in Ignite UI. It seems the grid component may be available through a separate npm package rather than the main package. It would be helpful if the documentation clearly explained which package to install and provided a simple example of importing and using the React Data Grid. This would make it much easier for developers to get started.  sunpass login
lily lily
lily lily answered on Oct 15, 2026 6:48 AM
To build a fast, high-performance image grid in React, combine CSS Grid or Flexbox for a responsive layout with modern performance optimizations. Use loading=”lazy” on your <img> tags to defer loading offscreen images, implement responsive image sizing using srcset to serve appropriately scaled files, and leverage CSS object-fit: cover to maintain uniform aspect ratios without distortion. For massive catalogs containing hundreds of items, integrate a virtualization library like react-window or react-virtualized to only render the images currently visible in the viewport, ensuring smooth scrolling and minimal memory usage.
sunpass login
