Hello Jeff,
I am glad that you find my suggestion helpful and were able to solve your issue.
Malin Hadzhiev,
Hello Jeff,
Thank you for contacting Infragistics Support.
I believe you will find the following sample very helpful in order to achieve your requirement. As you can observe, I am using the cell's role attribute which is ‘gridcell’ as follow:
[role=”gridcell”]{
border-left: solid 1px black;
border-right: solid 1px black;
In case you want to add vertical border lines to the cells in the header row you can use the classes ‘igx-grid__th–fw’ and ‘igx-grid__td–fw’. This approach I left as a comment on the provided sample.
Please have a look at the provided sample and if it is not an accurate demonstration of what you are trying to achieve please feel free to modify it and send it back to me for further investigation.
Malin Hadzhiev
Hello Frank,
I have been looking into your question and prepared a small sample that you might consider useful. It could be found here. Following the guidelines provided in the Template section of the Select topic, I am using the [(ngModel)] and I defined a global variable where is stored the default value in order to achieve your requirement.
Please test the sample on your side and let me know how it behaves. If this is not an accurate demonstration of what you are trying to achieve please feel free to modify it and send it back to me along with steps to reproduce. Alternatively, if the behavior cannot be replicated please feel free to provide your own small isolated sample. Remove any external dependencies and code that is not directly related to the issue, zip your application and attach it in this case.
Malin Hadzhiev
