Marcelo Rizzo
Marcelo Rizzo answered on Mar 6, 2017 9:31 PM
This is great Hristo. I will be able to test it out sometime this week and confirm that all is resolved.
Thanks so much.
Marcelo Rizzo
Marcelo Rizzo answered on Mar 1, 2017 2:57 PM
Hi Hristo,
When I use the dropdown the 'onrowupdating' function is not firing but am not sure why (might have to do with an unbound checkbox that I've added/need in the table?)
I think the drowdown does need at least the partial postback since the values are being set on the server side programatically.
I will look into using manual CRUD and see if I can manage it okay.
Any other info, examples or tutorials you can point me to on persisting data through user changes and then saving that to a DB would be great!
Thanks so much
Marcelo Rizzo
Marcelo Rizzo answered on Feb 28, 2017 4:50 PM
Hello Hristo,
I hope you can help me with one more question on this. I've gotten the dropdowns to work correctly to show the unique data for each row. The issue now becomes that whenever attempting to select an item from the dropdown a postback is triggered and the DataGrid goes through another DataBinding and the selected value of the DropDown is effectively lost. For instance in the example you provided when I select "Data 1" after the post back the text/value for the field is still "Pat" although the dropdown will correctly display "Data 1".
Is there any way to keep this information through postback so that a user can select several different dropdowns and eventually click a button to save the values selected to a Database?
Just let me know if you need any clarification or if you have any advice on this.
Thanks so much.
Marcelo Rizzo
Marcelo Rizzo answered on Feb 22, 2017 6:22 PM
Thanks so much Hristo – I'll take a look at this today and tomorrow and see if I have any other issue that needs to be cleared up.
Marcelo Rizzo
Marcelo Rizzo answered on Feb 17, 2017 2:41 PM
Hi Hristo,
This example makes is very good but my issue is that for each row the DropDown will need to contain unique values depending on the Item. Is the only way to do this to add a Unique DropDownProvider for each Row?
The following would be an example (adapted from your example and the following does not work but would love to figure out how it can) — I need a situation where if WebDataGrid is populated by "MakeTable_2" and in MakeTable_2 if "MakeTable" is passed the Value "1" then the dropdown for that Row with have 20 values "Data 0" to "Data 19" and if "MakeTable" is passed the value "2" then that row would have a drop down with only "Data 0" to "Data 5"
Does this issue make sense? is there a way to do this programmatically/on the server side? Do I just need to make unique DropDownProviders for each row?
public partial class _Default : System.Web.UI.Page
        this.WebDataGrid1.DataSource = MakeTable_2();
    private DataTable MakeTable(int x)
        // Create a new DataTable.
        System.Data.DataTable table = new DataTable("Table");
        // Declare variables for DataColumn and DataRow objects.
        DataColumn column;
        DataRow row;
        // Create new DataColumn, set DataType,
        // ColumnName and add to DataTable.
        column = new DataColumn();
        column.DataType = System.Type.GetType("System.Int32");
        column.ColumnName = "id";
        column.ReadOnly = true;
        // Add the Column to the DataColumnCollection.
        table.Columns.Add(column);
        // Create second column.
        column.ColumnName = "Item";
        column.AutoIncrement = false;
        column.Caption = "Item";
        column.ReadOnly = false;
        column.Unique = false;
        // Add the column to the table.
        // Create third column.
        column.DataType = System.Type.GetType("System.String");
        column.ColumnName = "Data";
        column.Caption = "Data";
        // Make the ID column the primary key column.
        DataColumn[] PrimaryKeyColumns = new DataColumn[1];
        PrimaryKeyColumns[0] = table.Columns["id"];
        table.PrimaryKey = PrimaryKeyColumns;
        if (x == 1)
            for (int i = 0; i <= 20; i++)
                row = table.NewRow();
                row["id"] = i;
                row["Item"] = i;
                row["Data"] = "Data " + i;
                table.Rows.Add(row);
        if (x == 2)
            for (int i = 0; i <= 5; i++)
                row["id"] = i;
                row["Item"] = i;
        return table;
    private DataTable MakeTable_2()
        DataColumn column;
        DataRow row;
        DataRow row2;
        row["id"] = 1;
        row["Item"] = "This is Item 1";
        row["Data"] = "Select…";
        DropDownProvider dropdownprovider = (DropDownProvider)WebDataGrid1.EditorProviders["DropDownProvider1"];
        dropdownprovider.EditorControl.DataSource = MakeTable(1);
        row2 = table.NewRow();
        row2["id"] = 2;
        row2["Item"] = "This is Item 2";
        row2["Data"] = "Select…";
        dropdownprovider.EditorControl.DataSource = MakeTable(2);
        table.Rows.Add(row2);
        return table;
Thanks so much.
