Marcus Turnbull
Marcus Turnbull answered on Feb 21, 2014 5:16 AM
Thanks rayc1234!
We were having the same issue though our error was to do with converting Decimal to Double – even though we had the field's datatype set to System.Double.  Only happened when adding a row where a non-integer number was entered.
Even though the column was defined as…
<ig:BoundDataField DataFieldName="UserAmount" Key="UserAmount" Width="70px" DataFormatString="{0:C0}" DataType="System.Double">
…we still needed to add this to the RowAdding event.
            object x = e.Values["UserAmount"];
            if (x is System.Decimal)
                e.Values["UserAmount"] = Convert.ToDouble(x);
Probably a bug so I will submit to IG when I have a chance to build a sample project.
