The difference between Infragistics45 and Infragistics4 is that the Infragistics45 is built with .Net Framework 4.5 and the Infragistics4 is built with the .Net framework 4.0
They have same functionality, just use different .Net framework.
If you project uses .Net framework4.5 or higher it is better to use Infragistics45.
