Thanks for your quick response. I tried the below code from the help topic , But still sorting is not working for me
This is my Page load code I am adding after binding data into the grid
this.WebHierarchicalDataGrid.RowIslandDataBinding += new RowIslandEventHandler(WebHierarchicalDataGrid_RowIslandDataBinding); in page load.
WebHierarchicalDataGrid is my grid ID,
MessageControl.HideMessage();
if (!IsPostBack)
this.WebHierarchicalDataGrid.Columns.Clear(true);
BindToGrid();
if (IsPostBack)
this.WebHierarchicalDataGrid.EnsureTemplates();
After initializing the RowsIslandDataBinding event , I am creating the event method
void WebHierarchicalDataGrid_RowIslandDataBinding(object sender, RowIslandEventArgs e)
// Sort a Column in PARENT BAND
if (e.RowIsland.DataMember == "SqlDataSource1_DefaultView")
Sorting sort = e.RowIsland.Behaviors.Sorting;
sort.SortedColumns.Add("vchMainSection", Infragistics.Web.UI.SortDirection.Ascending);
// Sort a Column in CHILD BAND
if (e.RowIsland.DataMember == "SqlDataSource2_DefaultView"
&& e.RowIsland.ParentRow == this.WebHierarchicalDataGrid.GridView.Rows[1])
sort.SortedColumns.Add(e.RowIsland.Columns[2], Infragistics.Web.UI.SortDirection.Ascending);
Still Sorting is not working.
ScreenShot of my Grid
Red highlighted one vchSubsection as per my requirement 1. Trip Objective should come first.
I tried to sort by iSectionID which identity is column(1,2,3..). But it was not working ,then I have appended 1 and 2 before each vchSubSection column to sort in ascending order in the grid.That one also not sorting properly.
Below one is screenshot of my Dataset to bind Grid
I am doing grouping by Column[1].ie, vchMainSection after grouping I am trying to do sorting by
Column[2] .ie, vchSubSection
I am using infragistics assembly version –> Assembly="Infragistics45.Web.v16.2, Version=16.2.20162.2013, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb"
Please help out how to do sorting after grouping by vchMainSection Column.
I have do sorting by sub section marked in red first screenshot or another other option also fine for me to achieve sorting.
Please also suggest me if any other options.
I am waiting for your help.
Thanks for reply.Its working fine.
I have some issue related to Sorting WebHierarchicalDataGrid .. Below is my code where I am binding dynamically generated columns to WebHierarchicalDataGrid .
WebHierarchicalDataGrid.DataSource = ds;
GenerateBoundFieldColumn();
GenerateTemplatedColumn(xmlConfigSection, dtBindConfig, isSaved);
this.WebHierarchicalDataGrid.GroupingSettings.GroupedColumns.Add("vchMainSection");
this.WebHierarchicalDataGrid.GroupingSettings.GroupAreaVisibility = Infragistics.Web.UI.GridControls.Visibility.Hidden;
WebHierarchicalDataGrid.DataBind();
The below code I am dynamically creating BoundField
public void GenerateBoundFieldColumn()
BoundDataField boundField = new BoundDataField();
boundField.Key = "vchMainSection";
boundField.Header.Text = "Section Name";
boundField.Width = Unit.Percentage(18);
BoundDataField boundFieldSubSection = new BoundDataField();
boundFieldSubSection.Key = "vchSubSection";
boundFieldSubSection.Header.Text = "Section Name";
boundField.Hidden = true;
BoundDataField boundFieldSectionID = new BoundDataField();
boundFieldSectionID.Key = "iSectionID";
boundFieldSectionID.Header.Text = "";
boundFieldSectionID.Hidden = true;
boundField.Width = Unit.Percentage(0);
boundField.CssClass = "clmDisabled";
this.WebHierarchicalDataGrid.Columns.Add(boundField);
this.WebHierarchicalDataGrid.Columns.Add(boundFieldSubSection);
this.WebHierarchicalDataGrid.Columns.Add(boundFieldSectionID);
My issue is, I want to sort by specific integer column (iSectionID) which is already hidden.
I want override Groupsettings order by. I want to default sorting based on iSectionID.
Please help me out how to do sorting after grouping or suggest me the possible way to customize based on specific integer column.
int count = 0;
foreach(var col in dtBindConfig.Columns)
if (count > 3)
string colName = Regex.Replace(col.ToString(), @"\s+", "");//removing spaces from the TempColumns
templateCol.Key = colName.ToString();
templateCol.Header.Text = colName.ToString();
templateCol.Width = Unit.Percentage(8);
templateCol.ItemTemplate = new CustomItemTemplate();
this.WebHierarchicalDataGrid.Columns.Add(templateCol);
count = count + 1;
string columnKey = (((GridRecordItem)(((TemplateContainer)container).Item)).Column).Key;
CheckBox checkbox = new CheckBox();
checkbox.ID = "chk" + spaceFreeColumnKey;
checkbox.Checked = (bool)DataBinder.Eval(((TemplateContainer)container).DataItem, spaceFreeColumnKey);
container.Controls.Add(checkbox);
private int UpdateCheckBoxValuetoDatabase(WebHierarchicalDataGrid grdCtrl)
foreach (GridRecord row in grdCtrl.Rows)
List<TemplateColumn> TempColumn =GetDynamicTemplateColumns(); //Getting all dynamic check box columns will returns all checkbox column names
int cnt = 0;
foreach (var columnName in TempColumn)
string tripfocus = Regex.Replace(tripFocus.vchTripFocusName, @"\s+", "");
string ID = "chk" + columnName;
string templateName = columnName;
CheckBox chkTripFocus = UIHelper.GetWebGridControl(row, ID, templateName) as CheckBox;//this method to find the checkbox by Template key and CheckBoxID but here returns null
if (chkTripFocus.Checked)
bActive = true;
configureSection.vchTripFocusName = tripFocus.vchTripFocusName;
configureSection.iSectionID = SectionId;
configureSection.bActive = bActive;
// ntmClient.UpdateTripSectionMapped(configureSection);
if (templateName != null)
return row.Items.FindItemByKey(templateName).FindControl(cntName);
else
return row.Items.FindItemByKey(cntName).Value;
Thanks for you swift response.The Sample which you have shared been working fine.
But I have another issue while getting the checkbox control or
how to get checkbox control and check whether it has checked or not. I am getting object reference error while getting checkbox control.
Please find below code which I have tried to get control but checkbox returning null.
public static object GetWebGridControl(Infragistics.Web.UI.GridControls.GridRecord row, string cntName, string templateName = null)
else
//I am passing row and controlid,template key)
CheckBox cpFocus = UIHelper.GetWebGridControl(row, "chk-" + tripFocus.vchTripFocusName, null) as CheckBox;
"CpFocus" returning null. Because it is not getting control.
sample html code for one dynamic checkbox I got from view source of the grid page
<input name="ctl00$ctl00$ctl00$TopHeader$MainMenu$AdminPageContent$WebHierarchicalDataGrid$ctl00$it4_2$chk-MedFit"
id="ctl00_ctl00_ctl00_TopHeader_MainMenu_AdminPageContent_WebHierarchicalDataGrid_ctl00_it4_2_chk-MedTest"
type="checkbox" checked="checked">
Please assist me how to get the dynamic template check control code behind and I need to store it into database.
Thanks in Advance. Please help me out to resolve the issue ASAP.
