Thanks Georgi for the response. Yes, I was using the Windows specific package. I am now using the web related package. I am using the following packages:
Infragistics.Web.Documents.Excel
Infragistics.Web.Documents.Core
I also had to update the SkiaSharp.NativeAssets.Linux.NoDependecies library as I was getting dependency error.
I see the excel export is working now but the generated excel is broken.
Would it be possible for you to share the sampe code? I am looking for following:
1. Angular UI sends requests to .Net 8 API for the excel generation
2. API will generate excel and will send the byte arrary of the excel to UI
3. First rows should froze, highlight rows based on some condition
Rahul
