Hi Ivan,
Thank you for looking into the issue.
As you said there were few old controls that were commented in the code. Therefore, I removed them and the application is being upgraded successfully.
However, I am using skin file for look and feel. Whenever, I drop following to my skin file
<igddl:WebDropDown runat="server" SkinID="g" AutoPostBack="false" StyleSetName="MYSET"
Width="220px" Height="22px" Font-Size="12px" Font-Bold="false" ForeColor="#131313"
backcolor="white">
<Items>
<igddl:DropDownItem CssClass="igdd_ListItem"></igddl:DropDownItem>
</Items>
</igddl:WebDropDown>
I get Ambiguous match found error. I tried this on a dummy project which have a default.aspx (Microsoft asp.net template) and have dropped webdropdown on it and one skin file with only one control in it.
Hi Ivan,
On running Version Utility below message is being written in the log.
We have determined this solution/project/website to have retired ASP.NET controls in the following file.
NOTE: There could be retired controls in other files too. The utility cannot proceed any further.
Thank you Ivan for your quick reply.
On using Version Utility ,
Below error message is being written in the log .
NOTE: There could be retired controls in other files too. The utility cannot proceed any further. Please refer to the following blog post on how retired controls are being handled.
Below is the code snippet of one of the control that the log might be referring to .
<xyzgrid:WebDataGrid ID="XYZSearch" runat="server" Width="99%" Height="150px" SkinID="Sort">
<Columns>
<xyzgrid:BoundDataField DataFieldName="ID" Header-Text="ID" Key="ID" Width="60px" Hidden="true" />
<xyzgrid:BoundDataField DataFieldName="Code" Header-Text=" Group Code" Key="GroupCode" Width="150px" />
<xyzgrid:BoundDataField DataFieldName="RCode" Header-Text="Remittance Advice Remark Code" Key="RCode" Width="250px" />
<xyzgrid:BoundDataField DataFieldName="RCodeDescription" Header-Text="RCode Description" Key="RCodeDescription" Width="250px" />
<xyzgrid:BoundCheckBoxField DataFieldName="IsDefault" Key="IsDefault" Header-Text="IsDefault" ToolTipChecked="" ToolTipUnchecked="" ToolTipPartial="" />
<xyzgrid:BoundDataField DataFieldName="FromDate" Header-Text="From Date" Key="FromDate" Width="80px" Header-CssClass="fromDate" CssClass="fromDate" DataFormatString="{0:MM/dd/yyyy}" />
<xyzgrid:BoundDataField DataFieldName="ToDate" Header-Text="To Date" Key="ToDate" Width="80px" Header-CssClass="toDate" CssClass="toDate" DataFormatString="{0:MM/dd/yyyy}" />
<xyzgrid:BoundDataField DataFieldName="CreatedDate" Header-Text="Created Date" Key="CreatedDate" DataFormatString="{0:MM/dd/yyyy HH:mm:ss}" Header-CssClass="h" CssClass="h" Width="110px" />
<xyzgrid:BoundDataField DataFieldName="LastModifiedDate" Hidden="true" Header-Text="Last Modified Date" Key="LastModifiedDate" Width="110px" Header-CssClass="igHC" CssClass="igC" />
</Columns>
</xyzgrid:WebDataGrid>
In the Web.config, I have registered the tagprefix as
<add tagPrefix="xyzgrid" namespace="Infragistics.Web.UI.GridControls" assembly="Infragistics45.Web.v21.1, Version=21.1.20211.2 />
