Ngát Trần
Ngát Trần answered on Oct 29, 2026 6:58 AM
Geometry Dash is a rhythm-based platformer where one mistimed jump can send you back to the start! The catchy soundtrack, tricky obstacles, and satisfying level clears make every attempt exciting. Give it a try!
Ngát Trần
Ngát Trần answered on Oct 29, 2026 6:54 AM
Web Components are especially useful when you need reusable UI elements across different frameworks. They work well for shared design systems and micro-frontends, though framework-specific solutions may be easier to integrate into a single-framework project.
Space Waves
Ngát Trần
Ngát Trần answered on Oct 29, 2026 6:50 AM
I’d use CSS Grid for the layout and keep the image data in an array of objects. That makes sorting and filtering easy later without changing the UI structure. React state can handle the filters and sorting, while each image is rendered through a reusable component.
